Michael
    9
Everything posted by Michael
  1. My car's theme also keeps changing. Originally it was, "garage queen with lots of potential, soon to get back on the road". Now the theme is, "garage queen with ambiguous potential, trying to get on the road sometime before the 22nd century".
  2. Planning is great, and planning for the unforeseen is even better, but there are situations where no amount of planning can adequately prepare one to address the unforeseen! Taking Mikelly’s example, suppose that one finds that a “custom engine†built by a “custom builder†to actually be a pile of mismatched, cheap hodgepodge with a wiped cam, oil-puking rings and knocking bearings? Unforeseen indeed! But it’s SUPPOSED to be built by a pro, and it cost a pretty penny! Well, if one has the financial resources, and the contacts with machine shops, etc., then this “unforeseen†can be successfully solved. But lacking the spare $8K and the Rolodex full of business cards, the unforeseen becomes a showstopper. The real cost of these projects isn’t buying the parts or the tools, or even paying a pro to do the job right the first time. The real cost is paying for one’s mistakes, and sometimes for the mistakes of others. The time that is takes to complete the project isn’t the time necessary to do the job right, at a relaxed and measured pace; then most projects would get done in a year or two! No, the reason that these projects take multiple decades is that minor, entirely innocent mistakes or defects become intractable nightmares. Like that small spot of rust that turns out to be a structurally unsound frame rail. Or the momentary loss of oil pressure in that fresh, high-dollar engine, which wipes a crank bearing and back to the machine shop you go! In hindsight, I did learn one thing: considering my investment in money, let alone time, it would have been cheaper to buy a new Z06, and be done with it.
  3. I just came across an interesting technical paper on automotive aerodynamics; it’s in the journal, “Experiments in Fluidsâ€, Vol. 37, 2004, pp. 763-768. its a good review of car aerodynamics in general. Evidently, the large majority (quoted as 75% in some cases) of automobile drag is due to flow separation off the aft end – the hatch, the base, the rear bumper, and underneath. This means that the front end – the hood, the grill, the windshield – contribute relatively little. For cars with a shallow hatch slope angle, such as the Z, a major contribution to drag (and to unwanted lift) is a pair of counter-rotating vortices emanating off the roof edges, where they pass into the rear hatch. These are like the wingtip vortices of airplanes. The paper talks about measurements in a large water tunnel, at Reynolds numbers not too far from real life. This is reminiscent of my experiments with a wooden Z model in my water tunnel, but at much lower Reynolds numbers, where laminar separations dominate and the wake is too thick (so the flow separation is worse than in real life).
  4. I bought Harbor Freight’s 13†tabletop drill press, for around $140. In my view, a sub-$200 Chinese drill press is a sub-$200 Chinese drill press, regardless of the brand name or the vendor name. They're all essentially the same. And a Made-in-USA (or Japan, or Western Europe) drill will be $$$! The main trouble with the Chinese drill presses is stability of the platform on which the workpiece is mounted (I can’t recall the technical term for this part). The other weak link is the chuck, but that’s replaceable. The motor, pulley system and feed are actually pretty good. I agree that the best option is to purchase professional-quality used equipment at auction. But, that stuff tends to get pricey, and the insiders will nearly always scoop you. Also, there’s lots of brand-name machinery that’s been abused. An abused Bridgeport is no better than a late-model Chinese mill.
  5. Judging from the posts so far, one would get the impression that the only reason to deviate from the JTR method of mounting the engine via setback plates from the steering crossmember is some yearning for originality or customization. I disagree. Reasons for and against mounting directly to the frame rails.... Pros: * If the engine is mounted directly to the frame rails, instead of the steering crossmember, the point of application of the engine’s weight is closer to the firewall, thus reducing the strain on the frame rails, and how much the chassis would twist upon application of full-throttle. * The engine isn’t cantilevered on setback plates from the steering crossmember, so in principle the mounting arrangement is stronger, for the same amount of metal. * With enough setback, the engine mounts get close to the mounting location of the tension/compression rods (front suspension), where the frame rails are already beefed up. This is a great place to carry a point-load like the engine’s weight. So, you can take advantage of structural synergism. * You can remove the steering cross-member and service the front suspension without worrying about having to first unbolt the engine and supporting it separately * Since the there are no setback plates to interfere with the fuel pump area, using a stock mechanical fuel pump becomes possible. Cons: * Once you decide on the engine’s location, you can’t vary it as easily as you conceivably could with a setback plate system * Requires welding * Requires local reinforcement of the frame rails * More likelihood of exhaust header interference, or steering shaft interference * Engine removal and reinstallation can be more cumbersome, as the transmission bellhousing has to clear the gap between the engine mounts as the engine is lowered into place. * Requires cutting and grinding steel, whereas setback plates can be from aluminum. My car (also a 78 280Z) has a big block, with setback way beyond JTR. That much weight, with that much setback, would probably be impractical to carry as a cantilevered load, so welding mounting attachments directly to the frame rails was the only reasonable approach. The steering shaft actually passes through the driver’s-side engine mount structure.
  6. Where in the world of SCCA would belong a car with an engine swapped from a different manufacturer, and chassis reinforcements that penetrate the firewall? I looked into this about 5 years ago, and was told... “nowhereâ€. Ain’t no class that would accommodate such a car, except maybe informal club racing. Is this [still] correct?
  7. Just out of curiosity, what did you eat during June 2000 – March 2003? I tried starvation – lost some weight, but didn’t make a dent in recouping my stock losses. The S&P 500 is knocking on the 1200 barrier. That’s pretty impressive – until we consider that it’s a long, long climb to hit 1500+, where it was 4 years ago.
  8. The difference in cost of living between an “inexpensive†area and an expensive one is largely illusory. With a few exceptions, taxes (state and local income, sales, property, etc.) aren’t all that different, unless you compare Anchorage with New York City. Food, clothes, books, furniture, whatever – prices are pretty much the same, for comparable items. The main difference is the cost of housing. A $150K house in one of the “better†neighborhoods of Dayton, Ohio, will cost around $400K in a mediocre neighborhood in Fairfax County, VA – and maybe about $250K in Fredericksburg, VA. But, here’s the catch: that Dayton house cost about $140 5 years ago, whereas at Fairfax County house was maybe $275K 5 years ago. And if the demographic, business and employment trends continue, the price curves will continue to diverge in the future. What this means is that indeed, the price of admission is higher in the “expensive†areas, but your housing investment will fare better over the years. So, the opportunity cost is actually lower! For a person who already makes reasonably good money, home ownership in the low-cost areas of the rural Midwest, the South, the Plains and the interior West will result in higher overall out-of-pocket costs than living along the urban coasts. I’ve been developing an inferiority complex over my house. Every time I visit my D.C.-area HybridZ buddies, I cringe in jealousy at how their houses keep rising in price, while mine stagnates or even falls. But it’s the basic law of supply and demand. People talk about escaping from the urban “rat race†and moving to the boonies, but mostly what happens in real life is the other way around. Unfortunately some of us can’t just uproot and move. One definite tragedy with the decline of American manufacturing is that white-collar jobs in the great urban centers have become almost entirely paper-pushing. With the exception of biotech and computers, engineers and scientists would be hard-pressed to find professional employment other than “science administration†in the D.C.-NYC-Boston corridor. Consider what’s happening in the Department of Defense, for example. Sure, D.C. is full of DoD administrative jobs. But the weapons labs have been downsizing and dispersing for 15 years. If you want to do research – goodbye Arlington, hello Dayton! The airplanes, the tanks, the satellites – they are designed, tested and built deep in the rural heartland, even though the programs are administered from inside the D.C. beltway. For another example, look at what happened to the aerospace industry in the L.A basin. Once nationally dominant, what little that’s survived has fled into the inland deserts. Goodbye Burbank, hello Palmdale. But hey, if you really want land, move to Southwestern Ohio. A 2,000 ft^2 house on 5+ acres, with a 4-car garage, will cost about $200K on the “good†side of Dayton, less than a half hour away from downtown. And you’re about an hour away from Colombus or Cincinnati. Go on, move out here, guys – help rebalance supply and demand! Do it, and help raise the value of my house!!!
  9. Yes, indeed, Thanksgiving.... Yesterday afternoon my wife was involved in a car accident; car spun out on a highway interchange ramp, in a light drizzle. Rear wheels locked up (strange for a FWD car), and the car essentially oversteered into a Jersey barrier. Arina’s more or less OK, with minor sprains and bruises. But emotionally she’s still in shock. I suppose that in any circumstance one can find the perspective to be thankful. Minor injuries could have been severe. Severe injuries could have been mortal. What we should really be thankful for, is luck. It’s mostly luck that got us where we are, and it’s luck that keeps us safe. Hard work, talent, skill – they are merely the tools by which one can take advantage of luck. But take away the latter, and all our efforts are useless.
  10. Is this the correct item? http://buy1.snapon.com/catalog/pro_det.asp?P65=yes&qt=1&test=Die%2C+Rethreader%2C+Metric%2C+M20+x+1.50%3B%247.55%3BRD7-5%3B9754&qty=1&Item_id=9754&PartNo=RD7-5&Price=%247.55&ListPrice=%247.55&FORMNAME=3&Desc=Die%2C+Rethreader%2C+Metric%2C+M20+x+1.50&SUB_Cat_ID=&SUB_Cat_NAME=&Cat_ID=&Cat_NAME=&group_id=2425&group_NAME=Master+Spindle+Rethreading+Set (Stock number RD7-5, Die, Rethreader, Metric, M20 x 1.50, $7.55)
  11. I recently went through this procedure on my 280Z. The attempt to bend back the crimped flats of the companion flange retaining nuts (inboard side of the stub axle) proven to be hopeless. On the driver's side, I loosened the nut with lots of force and a long breaker bar; ended up eating the threads. On the passenger's side, I ground off the crimped flats completely, with a 4" grinder. The threads survived more or less intact. I removed the stub axles by placing a block of wood on the inboard end (where the companion flange used to be), then whaling away with a sledge hammer. The stub axle flange was not visible damaged, despite the rather vigorous blows. Does Snap-on (or anyone else, for that matter) sell a rethreading tool or rethreading die in the correct pitch and diameter, by itself? I don't want to buy a complete set! Also, who sells the companion flange retaining nuts? The generic parts stores in my area (Pep Boys, Autozone, Advance, Napa) do not. And finally, what's a decent price for the rear (inner and outer) bearings? Local prices are $30-$40 per bearing. That's around $140 for a set of four!!!
  12. Another alternative.... Conservative: If you can teach yourself to fish, good. If you have fishermen working for you, even better. If none of the above, go f*** yourself. Liberal: If you’re willing to learn to fish, come and we’ll teach you for free. If you’re unwilling to learn, that’s your problem. Sometimes we forget that “liberal†didn’t always mean “tax and spendâ€.
  13. To attempt to answer Socket_Toomee’s question, about whether Americans feel abused by Bush’s lying…. My impression is that as an aggregate, Americans do not feel abused. Most Americans probably feel that even if the occupation is going badly, and the “mission accomplished†speech was premature, and the war itself was started too casually, and the Bush administration dismissed world opinion too peremptorily, that nevertheless the invasion of Iraq WAS justified at least in principle. That is, even among critics of the war, the majority would say that some sort of war with Iraq, at one point or another, would have been inevitable. Well, the corollary to that thought is that the lack evidence for WMD’s or of direct connection between Iraq and al Qaeda are essentially technicalities. So, if Bush fibbed the technicalities, so what, in the long run it’s excusable. My own personal opinion is quite different, but the final conclusion is actually the same. I do in fact believe that Bush and/or his advisors lied to the world and to the American people. Or, to be more precise, either they were breathtakingly ignorant and complacent, or they lied; take your pick. However, I fully expect politicians to lie, to lie grossly and egregiously, to lie ruthlessly and cynically. So, in that regard, I do not feel abused. It’s just more of the same. In George Orwell’s book, “Animal Farmâ€, I identify 110% with the character Benjamin.
  14. Personally I’m worse off than I was four years ago. My stock investments plummeted, and my house has declined in value over the years. Do I blame Bush? No. Do I credit Clinton for the 1990’s economic boom? No. As others have already pointed out, the impact that politicians have on the economy is severely overstated. However, I give Clinton credit for doing one thing very, very well: he sat back and allowed the country to run on autopilot. Instead of offering “new dealsâ€, or “great societiesâ€, or “contracts with Americaâ€, he just screwed his intern and smoked cigars. Which, in my view, makes him an excellent chief executive. What disappoints me most about Bush is his lack of conservatism in some regards, and his social-conservative zeal in others. The medicare prescription drug “benefitâ€, the increased farm subsidies, the social engineering programs such as “promotion of marriage†– these are fiscally irresponsible measures that benefit neither the investor class nor the middle class, nor in most cases the poor. Bush has used taxation and government subsidies neither to advance the greater good nor to help the needy, but to redistribute wealth in accordance with his social agenda and his political strategy. It is neither conservative nor compassionate. But most of all I blame Bush for refusing to admit making mistakes. Even staunch supporters of the Iraq war would agree that the occupation was mismanaged, the manpower was inadequate and the basic philosophy of dealing with the “Arab street†was flawed. Simply admitting that mistakes were made, even in the glancing sense of Reagan after the Iran-Contra scandal of the 1980’s, would go a great distance toward blunting criticism and building consensus. Instead, Bush regards himself as infallible and his decisions as immutable. Everything that he did was right, everything that his advisors recommended was correct, and any dissent or argument is flawed, if not outright seditious. BTW, after I broke my leg this past August, and the county ambulance came to fetch me, I indeed received a bill. My health insurance paid part (but not all) of it. But the curious thing is that the health insurance company negotiated with the emergency room, greatly lowering my eventual bill. I pity the fellow without health insurance, who got shafted paying the “retail†bill. See, we ALREADY have socialized medicine in this country! It’s just that the socialization is done very deviously.
  15. Returning to the original theme of this thread…. … I disagree. I think that there SHOULD be room for non-automotive discussions on this site, be it about politics, religion, dating, whatever. Why? Because we’re a community. We’re more than just a discussion group on modified Z’s. Why? Because finding technical information on V8 swaps was only part of the reason that this forum was started in the first place. The other part was in reaction to the bashing and denigration on the more “traditional†Z forums, directed towards persons interested in engine swaps. Reaction to such discrimination produced a collection of concerns – philosophical concerns – far beyond merely technical issues. True, it’s critical that our discussions maintain a level of deference and politeness; and emotional, ranting posts that disregard such criteria will lead to trouble. But by and large, most folks have observed the “rules†when posting about even the most sensitive political and cultural topics. So, I would opine that so long as the tone and language of the posts adheres to the overarching Hybridz guidelines, any subject is fare game. Even the most controversial. Otherwise, we’re just another automotive discussion group!
  16. In this and previous threads on roll cages, the main reasons cited for installing a cage have been, in no particular order: 1. safety (real or perceived) on the street (principal interest seems to be side impact protection) 2. safety on the track (here the principal interest tends to be rollover protection) 3. just passing tech inspection in order to be allowed to race on the track 4. stiffening the chassis to reduce body flex in turns, thus improving handling 5. stiffening the chassis to reliably accept high horsepower/torque 6. “while I’m at it†chassis improvement when making extensive rust repairs 7. appearance/fashion/self-esteem Well, the perspective of most of the experienced roll cage builders on this site is rooted in #2 and #4. And just to reiterate the obvious, success in objective #2 does not necessarily imply success in #1, nor does a cage built to conform to objective #3 necessarily perform well in any of the others. Meanwhile, many (if not most) off the shelf kit-type roll cages fall in #7. Fine. But I would say that it’s perfectly OK to build a cage for objective #5 (often comes along with #6), and not in the least meeting objectives #1, #2 or #3. Provided that you’re aware of the risks and you (or the cage builder) know what you’re doing. With that in mind, I think there’s plenty of wisdom in a “cage†which dispenses with the roll bar, but includes X-bars in the doors, a dash bar, connections between the rocker panels and the rear struts, and between the rear struts and the sheet metal supporting the rear hatch hinges. Ain’t no way would this “cage†meet objective #3 in any venue where a roll cage is required. But sometimes that’s not the point. The design can fail in many of the above objectives, without necessarily being relegated to category #7.
  17. America is a socially conservative country. It would take a considerable disaster for the more socially conservative candidate to lose, especially if that candidate is the incumbent. So, I agree that the race isn’t as close as most media outlets have been reporting it to be. Bush will win handily. My own reasons for opposing Bush include the following: * Bush has inexorably been shifting more power to the executive branch, at the expense of the other two branches of government. It’s a trend that began with Roosevelt, continued with Nixon, and accelerated with Bush. Ultimately this destabilizes our form of government. * Even more so than Reagan, Bush has allowed himself to be swayed (some would say manipulated) by a select cadre of appointees and staffers, who have become an unelected de facto government. * While claiming (if only by implication) to be a fiscal conservative, Bush has actually expanded the welfare state. Examples include expansion of Medicare, handouts to farmers, and funding of social initiatives such as “promoting marriageâ€. Again, comparing with Reagan: Reagan’s deficit spending mostly went into defense, which ultimately meant more jobs and more corporate investment, at least in the short term. Bush’s deficit spending is going primarily into entitlements. * Bush seeks to pollute the Constitution with amendments to please his socially-conservative core constituency: banning flag burning and banning gay marriage, for example. This is offensive not only to social liberals and moderates, but also to constitutional conservatives. * Bush’s “faith-based initiatives†erode the separation between church and state. As for the Iraq war – well, Congress gave Bush the go-ahead, so it would be difficult to argue that the war is unconstitutional (for an example of unconstitutional war, consider Reagan’s covert assistance to the Nicaraguan contras in the mid 1980’s). That still leaves the question of whether the war was a good idea; that is, whether it’s justifiable, rather than merely “legalâ€. I think that among most of those Americans who still support the war, there is a perception that somehow Iraq was connected to 9/11 and Al Qaida. If there were strong evidence for such a connection, then the war WOULD be justifiable, regardless of the presence of WMD – as a prophylactic measure, as a security measure, and as just plain good old revenge – even if, as has turned out to be the case, the resulting occupation would be bloody, frustrating and divisive. But I would opine that no such connection exists.
  18. Here’s my long-lost reply to Tannji’s post, from somewhere in the middle of this series; I suppose that much of this has been rendered obsolete by a half dozen pages of posts, but anyway, here goes… I would claim that the relationship between those in power, and those over whom that power is exercised, is necessarily adversarial. Sure, the situation is more benign when those who are in power are responsible, “compassionate†and driven by some sense of interest in the public good. But these are only idealizations! The only true limitation on those in power is friction with other concentrations of power. I suppose that in high school civics class, this is referred to as “checks and balancesâ€. If the three branches of government are fighting it out amongst themselves, they’ll be too preoccupied to bully the public. The Patriot Act, and recent political currents in general, is part of a shift in power towards the executive branch, at the expense of the legislature and the judiciary. We can not reasonably expect the executive branch to “be accountable and to make amends†unless it’s forced to do so. The PA weakens that forcing. And the more power vested in one branch of government, the greater the overall influence of government in our lives. I agree that magic abolition of government would only result in a power vacuum that would give rise to yet another, and probably worse iteration of government. It’s contrary to human nature to be able to organize into a group without vesting power in a central leadership. Yet, we should remember that setting limitations on that leadership is our number one priority. Most of us would agree that the abridgements of liberties to which Americans have been subjected in recent times are not extreme. It’s easy to point to much more onerous restrictions of liberty in prior cycles of national security threat and consequent government reaction. But we should assess the present situation, moderate as it may be, in terms of which direction it leads, if taken to a hypothetical extreme. Clearly, shutting down the FBI, summarily opening our borders, abolishing government power to wiretap in any circumstance whatsoever, and removing all security from our airports will lead to a situation where the risk of terrorist violence will be far greater. OTOH, implanting a radio ID tag in the neck of every American, installing closed-circuit television in every bedroom, and routing all e-mail through a government-monitored server would reduce the odds of a the terrorist attack, not to mention also reducing crime in general. I ask this: which of these two hypothetical extremes is the greater evil? My belief is that the latter is the greater evil. Why? Because life by its very nature is rife with risk, uncertainty and misfortune. It’s true that the cornerstone purpose of government is to facilitate a system where people can live together in some modicum of cooperation, and that this requires that the individual surrender some portion of self-determination in order to allow this cooperation. But risk reduction through government intervention rapidly degenerates into folly. I’d rather take the risk, recognizing the very real possibility of harm – than to accept the remedies to eradicate that risk! Terrorism is a risk. It may or may not happen. That shady character sitting next to you in a crowded flight – he may or may not be wishing to harm you, he may or may not be about to attempt to harm you, he may or may not be able to actually cause you harm – these are all possibilities, and unpleasant possibilities indeed. But government power is altogether a different animal. It is not limited by lack of ability, or lack of means, or inauspicious circumstance. Suffer government to grab enough power, and it WILL harm you. It’s not a question of risk; it is a certainty. Tannji wrote: “You have a choice. Let a terrorist violate your rights, or let the government.†Exactly! And here is my choice: I’ll let the terrorist violate my rights. Why? Because if he tries, he may or may not succeed. But the government is guaranteed to succeed. Consider that a common thread amongst most terrorists who hate America is hatred of pluralism; in particular, hatred of the idea that there should be limits on the extent to which society can oversee an individual’s actions. These “fundamentalists†advocate a paternalistic, intrusive state where the individual does strictly what is “taught†by the leaders – by the central organ of power – which conveniently places itself beyond the pale of questioning. The premise is that “good people†who have nothing to hide, have nothing to fear from such state intrusions; it is only the miscreants who need fear the state’s wrath. Sound familiar? So what do we do about the threat of growing government power, especially executive power? Do we take to the streets, signing songs and carrying banners? Do we support radical candidates for public office? Do we stock up on ammo and canned food, and head for mountain hideaways? Well, these are all options, I suppose. But I think that it is precisely by bitching and moaning that we do the most PRACTICAL good! Why? Because by raising awareness, if necessary by erring on the side of radicalism, we can cajole the great majority of moderates to be more weary of potential government abuses. A couple of salient quotes, somewhat paraphrased: “If you agree to surrender some of your liberties as a sacrifice necessary to obtain more security, the result will be a loss of BOTH liberty AND securityâ€. (Ben Franklin) “If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy.†(James Madison)
  19. So far this discussion of Democrat vs. Republican has been dominated by economics; raising or lowering taxes, abolishing or increasing entitlements. And this makes sense, if one subscribes to the idea that most people vote according to what’s best for their own wallet. But in this election, especially, my choice is confounded by the social issues. As a stockholder and relatively “affluent†person, at least according to the tax codes, my preference would have been Republican. But it seems to me that if you’re not an evangelical Christian, there’s no room for you in the modern Republican party. I support abortion, physician-assisted suicide and gay marriage. I oppose the display of the 10 commandments in public places, oppose amendments banning flag burning, and oppose “faith-based†initiatives. Socially, that pretty much makes me a lefty, right? But, I support gun rights, oppose affirmative action, and support the death penalty. Which makes it difficult to be a Democrat, either. But one has to choose; and for me, the rejection of adherence to a “moral blueprint†makes it impossible to vote Republican. Then there are the issues of foreign intervention. I thought that it was the Democrats who traditionally want to use American taxpayer money and risk American soldiers’ lives to “make the world safe for democracyâ€. And as I recall, it was W., back in the 2000 election cycle, who derided the concept of “nation buildingâ€. But how does that jive with the reality of the past 4 years? Following Cyrus’s original statement, I’d like to pose the following question: Why is it that in modern times we’re seeing such a close alliance of pro-business, free-market interests – with socially conservative interests? This year, I’m voting Libertarian.
  20. Don’t sell! Set the whole project aside for awhile; maybe a couple of months. Then return to it, once your nerves are rested. If you sell everything, under a burden of disgust and frustration, you’ll only come to regret the sale, since you’re guaranteed to lose money on the sale, AND will find yourself without a sports car to tinker with. Seller’s remorse can be worse than buyer’s remorse.
  21. Tannji (and others) – The price of being safe – that is, of having one’s safety maintained by an organization wielding authority – is obedience to that authority. This is the crux of the debate on this thread. There are some who resent the latter, but still desire the former. Others point out the inconsistency, and state that they’d gladly accept the authority if that’s the price of protecting life and limb. But I say: dispense with the authority, accepting loss of protection. It’s not the case that I would not be afraid of fanatics with AK-47’s. But rather, that I recognize that the price of dismantling the paternalism of authority is exposure to the dangers from which that paternalism is purported to protect. Hey, I don’t want to get blown up in a hijacked airliner either. But I’d actually rather have that happen to me, than to a heart-to-heart basement chat. My belief is that much as 9/11 was a horror and a tragedy, the steps that would have been necessary for completely foolproof proof protection from such an event would have been too onerous an assault on our liberties. This is the logic behind statement #3 in my prior post. Now, to answer Mike’s question – “what could I actually DO about the government, to make it better?†Well, for us government employees, there’s an insidious little law called the Hatch Act, which largely bans political (partisan) activity. I suppose I could donate to the Libertarian party, but that’s about it.
  22. Pete, I didn’t want to identify folks by name, but yes, in my previous post I was thinking of you and others of my friends in the D.C. area. You make a critically important point, which has much to do with the psychology of the differences in our positions. You actually feel safer surrounded by a barbed wire fence and armed guards. Whereas I feel threatened! The barbed wire makes me think of Dachau. In your perspective, evidently, the guards are there to protect you, too. Protecting the “secrets†going on at the military base, and protecting the men and women who work on them, are intimately related. As a law-abiding citizen just doing his job, protecting the secrets means protecting you, too – hence, the guards are on your side. Whereas in my view, the interests of the government and of the individual are invariably at odds. The government which is “best†is that government that’s mired in confrontation with other concentrations of power, such a corporations, unions, PACs, churches, whatever. Then, the individual can “relax†while the various organs of power battle it out. Those teens in uniform toting M16s are there to protect the interests of the government. I do NOT see those interests as my interests. But I swallow my pride and stomach the situation, because I’d rather work in my relatively cushy job than pump gas or dig ditches, even if it means being surrounded by barbed wire. There indeed crumbles the courage of my convictions. The conservative newspaper columnist George Will put it quite deftly, when he wrote that a quintessential feature of government is that it has a monopoly on the legitimate exercise of violence. I agree. But that is precisely what scares me. No terrorist, no matter how brutal, how cunning or how amoral, can exercise violence with “legitimacyâ€. And in that sense, terrorists can be fought. But government is special. Government can exercise violence legitimately – that is its prerogative. One can not hope to confront the government with violence, and entertain the hope – even in the abstract – of winning. If I may put forth some rather curt and perhaps inflammatory statements: 1. I personally feel far more threatened by soldiers with M16s than by turban-clad lunatics with Ak-47s. 2. Most emphatically, I do not believe that the U.S. should be at war, or that the “war on terrorism†is a war at all. War, by definition, is between nation-states; between governments. 3. And, to be entirely forthright, I would rather risk being blown up by terrorists than being interrogated in a basement cell of some federal building. I don’t say this in some benighted effort to appear heroic, in the “give me liberty or give me death†sense. But I’ve heard enough from first-hand sources about what it means to be “protected†by one’s government.
  23. Several members on this board, including yours truly, are or were civil servants or government contractors, and in that capacity voluntarily submitted to intrusions into our privacy and abridgement of personal liberties in order to perform the jobs that we voluntarily undertook. Sure, it stands to reason that if you’re going to hold a clearance, you dutifully fill out your SF86 every 5 or 10 years. And if your office handles such and such information, that every envelope that hits your mailbox at work gets opened before it ever reaches you. But we need to remember that the rest of America isn’t run by the DoD. At least, not yet. It’s silly to expect that the average citizen should surrender his rights with as much alacrity as do civil servants. I work in a place surrounded by barbed wire and guards with M16s. Does that bother me? Yes, to considerable extent it does. But ultimately, that’s the life that I chose. I deal with it. But WHY should we expect that all Americans should have to just deal with it? It’s one thing to “have nothing to hideâ€, and therefore to cheerfully accept surveillance because the sensitivity of one’s occupation requires it. But the argument breaks down when we attempt to extend it to the general public. In the outside world, it is strictly upon suspicion of wrongdoing that surveillance is ever justifiable.
  24. I think that even though one might be innocent of the criminal activity that some surveillance/search & seizure law is intended to thwart, one’s dignity as an individual is nevertheless diminished whenever police powers are enhanced. Here is a simple example: Red-light cameras might ticket only those drivers who run red lights, and arguably make the streets safer, while raising revenue for the city (which might otherwise had to have come from taxes). And if you don’t run red lights, you won’t get ticketed, so the cameras should not bother law-abiding citizens, right? Wrong. You are under surveillance, guilty or innocent. I would argue that this is an example of government intrusion; it assaults our dignity and affronts our rights. The issue is NOT whether law enforcement officials are irresponsible, corrupt, or flippant with their powers. Or even, whether some unfortunate mistakes might cause innocent people to be inconvenienced. The issue is the abstract principle: does the government possess such-and-such powers, or does it not? How do we, as a society, balance the need to be safe – whether from criminals within our midst, or foreign enemies – with the need to be free from paternalistic intervention by our government? I would argue (with some oversimplification) that all politicians, all persons in power, would seek to augment their power. Party affiliation, social class, economic background – it doesn’t matter. To use a national tragedy as an excuse to curtail individual liberties and to enhance government power, is the dream of any administration. The Bush administration was just lucky. A tragedy happened on their watch. A horrified, cowed public would gladly accept restrictive laws, if those laws were sold as being “necessary†to “protect†the public. Whenever America has been at war, or even undeclared perception of war, civil liberties have been curbed. It's been that way since the 18th century (Alien and Sedition acts), and the 20th century is rife with such examples. True, in many cases the excesses of government power have been temporary, when a backlash comes to sweep them away. Which indeed suggests, as Mikelly says, that the Patriot Act will be temporary too. But the mere fact that it’s temporary does not prove that it is presently useful, justifiable or sensible.
  25. If money were truly no object, then the amount of customization would be so large that the choice of baseline car would be almost irrelevant. That said, starting with a Z, I would consider designing front and rear suspensions (probably unequal A-arm) from scratch. For the engine, I’d build an all-aftermarket big block Chevy – aluminum block (Rodeck or Merlin, for example), 4.5†bore and 4.0†stroke (comes out to about 510 cubic inches) – and go twin-turbo. I’d use one of the new aftermarket 6-speed gearboxes, and an aftermarket version of the Ford 9†rear (for example, Mark Williams) in a custom center section suitable for independent rear suspension. The engine would mount far enough back that the driveshaft would be maybe 8†long. The I’d build a chromoly tube frame to connect the various parts together. Composite (perhaps carbon fiber) panels would bolt to the tube frame to form the body. The outer mold lines (that is, the body shape) would go through several iterations of wind tunnel testing, aiming towards minimum drag and suitable downforce. Finally, I’d rivet the original VIN plate to the door jamb, and call the car a “Zâ€. My guess is that the engine alone might be pushing $70K, by the time the turbo plumbing, the oil system (dry sump, of course!) and the electronics were sorted out. The frame, welded professionally, would probably be another $50K, not including the custom design work and the stress analysis. If all the design, testing, fabrication and assembly work is done by professionals charging retail prices and labor rates commensurate with their expertise, I’d expect this car to be pushing $1M.
