Domzs
    5
Everything posted by Domzs
  1. I see what you are saying , but installation is what matters . Thanks for clearing that up .
  2. As far as the shafts go , look for bad u-joints . Bad trans can cause vib. and noise . Just visually inspect your suspension . Make sure nothing is loose or bents . Good luck .
  3. My 78 Z came like this . Don't rec. swapping them .
  4. As for your turn signal and hazard lights , check the hazard switch first . If bad , try to clean contacts before replacing . Depends on what type of vibration you are talking about , it could be a lot things like tires , driveshaft , halfshafts , loose components .
  5. Thanks for the break down .
  6. So you have spark and fuel pump operation . Need to make sure you have fuel press. . To check for injector pulse you'll need a noid light or a homemade test light ( low amp. bulb ) . Plug into the injector connector to see if you get any pulse . But first , i would spray some carb spray or starter fluid to see if it runs ( this will eliminate the ignition system ) .
  7. I have been following your project for awhile . Great job ! Debating on which way to go with my 280ZXT , like yours or 8.8 live axle . If you don't mind me asking , how much have you put in it so far ?
  8. Need to check to see what's missing , fuel or spark , when it happens . Sounds like something got hot then shut down . How did it shut off , ran bad then stopped or like key turned off ? Need better description .
  9. Just take the car to your local shop and have them do a front end shake down ( check the rear while they're at it ) . Shouldn't cost any , we don't charge our customer for that .
  10. Don't see how full length can work with an auto . I'm runninng JTR in mine , they seem to be pretty good .
  11. Thanks . I'm glad they are 70cc , perfect for turbo . How's your project coming ?
  12. Take a fuel sample to see and the Z fuel tank has a drain plug ( if you to drain it ) .
  13. LOL . Won't do you any good without 4" bore block , Matt .
  14. Trying to find some spec on this casting , not much help on LS1Tech . Think this is a large chamber casting ( truck L92 ) .
  15. Check with your FSM . Think they are brown ( 40 amp. ) . I replaced my with MAXI fuses . Down load FSM and do some reading .
  16. Just picked a set of LS3 heads and intake for $550 . All have 0 miles , but the heads do have some scratches and dings . Good price ? Does anyone know anything about 823 casting ? All i need now is a rebuildable 6.0 iron block to start my turbo build .
  17. Fusible links . But those are just wires . Should have two boxes look like these .
  18. Sorry , forgot the size . I'll check tomorrow when i get back to the shop , if i remember which box . LOL . They fit tight , i used some WD40 to get them in . Not going to come off without any help .
