lol, five layers of paint, didnt cut out the stock 1/4 panels when they put the subtle z rear flares on, riveted and glued the flares on, the covered it in bondo, molded a spoiler into the rear with rivetes and bondo, while leaving bare metal underneath for it to rust through, filled the rear vents with fiberglass resin and cheap lead, tried to use JB weld to fix a brake booster, tried to use house hold insulation to insulate the wires from heat, had the distributor 3 teeth off, hacked the wiring harness up all the way around, wired the stock tach to the motor, but didnt calibrate it, speedo wasnt hooked up, cut up a good 73 console to install some crappy auto shifter, put bolts where the grease fittings where on all the ujoints, destroyed the stock front valance by trying to mold in some yellow fog lights with all thread and fiberglass, used to short of a weatherstripping on the windshield which created a 1/2 gap at the bottom, had cheapo carpeting and insulation glued to the floor, exhaust was half ass'd and hacked up, too big of a carb, was using a point distributor and balast, wired in a Taurus fan to only be on high whenever the ignition switch is on, covered the surge tank and all those lines in a tar like substance.
