sweetleaf
Everything posted by sweetleaf
  1. I say use seafoam. Yeah , ATF is an old trick but can/will eat and swell some seals. Was mostly dumped down carbs, back in the day. Or just use K1 Kerosene.
  2. As mentioned above, your speedo will be slightly off but you can use those tires without a problem.
  3. Thank you very much for the reply. My total bracket thickness looks to be about 3/4" . The 2 caliper bolt pads are 1/2" . The thicker flange area (3 bolts to hub) is 1/2" and the caliper side is 1/4 " thick. So I'm guessing these are for the 240SX brakes ???
  4. Anybody that runs either of these adapters. All I need is a couple of specs. Please?
  5. Please, anybody that has either setup. Measure the bracket/bolt spacing.
  6. Could be lots of things. Put a FP gauge on it.
  7. Anybody? . I know there is a ton of people with the rear disk conversion. All I need is the dimensions. Please ( :
  8. It won't be plug n play but you just need all the sensors, power, and ground connected correctly. You will also need an EFI pump and regulator.
  9. Could you measure the caliper bolt spacing? I would really appreciate it. I'm pretty sure that they're different.
  10. bump, I'll have pictures up in a little. But, They look similar so I think the caliper bolt spacing is what will tell, witch ones they are.
