I am trying to set up IPSEC vpn with GVC to connect to the NSA 3500 firewall. I am having several issues. Here's what I am trying to do: in my scenario, I have a 3500 firewall, and all 6 interfaces are used for various subnets. I want to use IPSEC vpn client for remote users to connect to the sonicwall. They should be able to VPN in, get an IP leased from a DHCP server for a virtual lan, and policies on the firewall should allow users on the vlan to get access to other subnets.
let's say this is my current assignment for interfaces:
X0- 192.168.100.1/24
X1- WAN
X2- 192.168.150.1/24
X2:VLAN - 10.1.1.1/24
X3- 192.168.160.1/24
X4- 192.168.170.1/24
X5- 192.168.180.1/24
A zone is configured for each. X2:V10 zone is set up with X2 as parent.
I have a DHCP server running on X0-, 192.168.100.50. It services DHCP for all non-WAN interfaces, and IP Helper is set up on SonicWall to route DHCP requests from each zone
I want the group VPN to assign X2:V10 subnet via DHCP to the users that login via VPN. when a user VPNs in, they should get 10.1.1.50-99 IP address..
On with the current problems
1. I am not able to successfully allow it to connect and do split tunnel traffic when VPN client establishes a connection. Under VPN->Settings->WAN groupVPN I have disabled 'set default route as gateway' option, and gateway is set to 0.0.0.0. The problem arises when GVC assigns 2 default routes, and traffic cannot pass correctly. If I manually remove one of the default routes on the client machine, split tunnels work just fine. But I cannot expect users do this this themselves. I would like to ideally be able to have users use split tunnel, rather than route all traffic through the firewall.
2. I was able to successfully route all traffic through 'secure tunnel' VPN option. Not the best, but it works for now. However, I would like to have the sonicwall correctly assign 10.1.1.0/24 address range to the VPN clients. What do I need to do to properly set up VPN on a separate non-physical interfaces, and allow it to properly communicate with other interfaces?
