This cam suggestion is for a 383 sbc,w/ dart sportsmanII angle plug heads, 202/165 and 200cc runners.10.5:1 compression Kieth Black hyper pistons,and 5.7 rods.
I`m using an Edelbrock Victor jr intake with a 750dp holly carb
Headers will be long tubes with 1 3/4" primaries, 3 1/2" collectors, and 3" dual pipes.
I`m using a 200R4 trans with stall converter, Have 3:55 gears and 24.5" tall tires.
The recommendation was also based on a 2700lb car.
TM-HR HYDRAULIC ROLLER SERIES  .700" roller diameter
The TM-HR Hydraulic Roller Series profiles are designed to be compatible with today's sophisticated engine applications. There are a variety of hydraulic roller lifter profiles to choose from, depending on one's specific application and desired performance.
                  adv@      [Duration lobe lift point]     lobe   [lift w/ rocker ratio]
            Grind #   .006"    .050"  .100"   .200"   .300"   LIFT       1.5   1.6
       int/TM286HR   286       234    202     145       74 .   340"    .510" .544"
     exh/TM290HR   290       238    205     148       76    .340"    .510" .544"
This is a dual pattern cam, supposed to produce good power from 2200 to 6500rpm with a relatively flat torque curve.
I didn`t get any hp/tq #`s from them, and would really appreciate it if someone here who is knowledgable with desk top dyno could run this and see what it should do.
Here`s a link to the grind#`s if you have trouble deciphering my chicken scratches http://www.reedcams.com/Cat/hyd_roller_profiles.htm#Anchor-H-R-47383
