RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. I just picked up two of these, 15x7 4 lug. Wonder what brand they are??
  2. I think what your refering to is the double slip joints on the pair of 3 pipe collectors >> http://www.burnsstainless.com/MergeCollectors/TurboCollectors/turbocollectors.html joel
  3. Found this on GT-R register site; 11010/11000-05U*0 - R32 (80 in early cars, 00 in later cars), R33, R34 standard block 11000-24U00 - R33, R34 N1 Block 11000-RRR45 - New Nismo Block "I suppose the rumor that the R32's are tougher may relate to the early 80 blocks. The other thing is that the metal gets stronger as there is less stress, de-stressing is done by time and/or temperature cycling, and R32 block is older and likley to have been through more temperature cycling. The N1 block has thicker walls on the cylinders and smaller oil channels to the head, like the tomei items. The Nismo Block is designed for 2.8l conversions it has even thicker walls, thicker top section to the head and maybe revised water channels."
  4. HeHe... thats as funny as the vid. Priceless
  5. Where is the real info? Don't see no GT-R info...
  6. I hope its not a bad thing as I'm coming up on two years. I think as long as its not left out in the eliments, with no spark plugs in it etc., it should be ok... (I hope)
  7. Here ya go....... http://forums.hybridz.org/showthread.php?t=111128
  8. heres what is aplicable to the rb20/25/26 unless noted. head studs: rb20/25 202-4301 rb26 202-4207 rod bolts: z32 dohc vg30 bolts were reported to work on the rb25/26 but will not work on the rb20 (rod bolts are too long for rod, verify length of rb25/26 botls) pn for z32 rod bolts 202-6004 use sr20 bolts, may need slight trimming 202-6005 x2 (2 sets req'd if using kit) or alternatively order (rod bolts and nuts respectively) 12x ar3.67-1 12x n502 rb20 rod bolts ONLY : 202-6003 (l24 late,l26,l28 rod bolts) main studs: this is from my measurements of my stock bolts and my block rb20/25/26 except rb30, again verify lengths and sizes. 3x am4.600-1lb 11x am4.125-1lb 14x 200-8519 14x 300-8344 CREDIT carl (RaceBread.Com)
  9. After building a stroker turbo Z motor, and comparing it to my non stroked Z motor, I'd rather of built me a RB30dett than my RB26dett. Its just once I started learning about the RB30 bottom end, I already had spent the money on Carrilo rods and JE pistons for my RB26 motor, or I would have built myself a RB30dett just because of the usable torque down low... I like power down low vrs top end high rev power. I may not even like my motor once its up and running, just because of the low torque.
  10. Brian, do you know yet if the RB30 uses the same system for numbering bearings like the other RB's do, ie; numbers on crank, rods, block and oil pan flange?
  11. You'll never get a responce to your questions if you don't provide more info on what your talking about.... What does it go on? What brand? ETC.
  12. The reason for removing them is to have access to the oil galleys for cleaning purposes... I have used two part epoxy, and I've used JB weld. I just shaved the plug down enough to where once screwed in, it left a slight indent to use for filling in with the epox or whatever you end up using. I didn't put it on the threads, just filled in the outer exposed indent. Hope this makes sense...
  13. Sorry for the delay.... I got them from the wheel seller here local. I really don't know where they got them from. They are two piece, 1 3/4" thick. Using them with a +40mm wheel, they fit perfect...
  14. I've also done it with success...
  15. I think the add pretty much says they will... " They fit 70-85 Z & ZX, with 4 lug configuration only. " I had a set of 17x7's on my Z for the last 5 yrs w/o any problems.
  16. Looks good. Will the exhaust pipe clear it ok?
  17. Ah pooie..... " Thank you for your order. Unfortunately, the street flares you ordered are no longer available. We do still offer the ZG flares if you are interested in those. We haven't charged your card for anything yet so let me know if you'd like to substitute these."
  18. Oil Filter By-pass Adapter for RB26 -- Earl's 1178ERL - 3/4-16... Earls has ones with thermostats built in
  19. You forgot to mention sizes.... $40 sent for 2 large shirts.
  20. Yea, I bought a set of the MSA CF ZG flares that promply were sent back to them... funky they were. I like your grill. It looks better than the one Nissan sold like that.
