Hit a few set backs today but got a bit finished.
STRUT INSTALL
Began with both the front and rear bare shock tubes/hubs.
The struts (blue tube) slides into the shock tubes and with the provided gland nuts is held into position. The gland nuts sit at the top of the shock tube over the strut shaft.... before putting on the nut your required to add light weight oil into the tube until it is about 1.5-2 inches away from the top. Wasnt able to torque them down since I recieved only 3 correct nuts, the last ones will be here tomorrow.
REAR SUSPENSION MOCK UP- PARTIALLY ASSEMBLED
This is what it looks like mocked up. Mustache bar at the bottom, rear control arm pivot mount and both control arms. Bushings to be pressed in have been and are ready to go. On the outsides you have the shock assemblies in a exploded view. Front sway bar is not pictured but runs from middle of one control arm forward and then to the other sides and down to the control arm.
MORE BEING REPLACED
Rear Halfshaft U-Joints- $100- Fixes any vibration and shutters from worn out U joints. Replaces one of the oil fill holes that was accidently broken off. (napa)
PLANS FOR TOMORROW
Actually start assembling front suspension.
Torque down gland nuts
Possibly finish assembling shock assembly
Remove diff cover and drain fluid/replace, paint cover red
