Everything posted by wongboh
Crazy plan: A Tesla and chevy Volt powered EV hotrod S30
wongboh replied to jokeitch's topic in S30 Series - 240z, 260z, 280z
Any progress on this? Thinking of doing the same project for a future build -
Ford Super 8.8 irs swap thread. Rear brakes too
wongboh replied to Invincibleextremes's topic in Drivetrain
Any updates?- 282 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Subscribed. I was tossing around the idea of building a jig to shorten the super 8.8 assembly and mount in my Z but this seems like a much easier option and will let me get my Z back on the road sooner. Thanks for tackling this project on and bringing an affordable option to market. I would be interested in the tack-welded kit.- 282 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Thanks for picking up where Will left off. I'm subscribed and definitely interested in the mount. I was planning on heading to the junk yard to pick up an explorer 8.8 diff and wanted to know how to easily identify the diff. Information on the diff is posted on the sticker on the door pillar (http://www.explorerforum.com/ntrprize/Axle.htm) under the "Axle" category. Explorer 43 Open 3200 3.08 41 Open 3200 3.27 42 Open 4.10 46 Open 3.73 45 Open 3200 3.55 D4 Limited Slip 3200 3.73 D2 Limited Slip 4.10 L73 Limited Slip 3.73 Here's an example of a D4 unit with the 3.73 Limited Slip: I hope this is helpful. Shawn
TrackZpeeds CXRacing LS1 T56 240z
wongboh replied to trackzpeed's topic in Gen III & IV Chevy V8Z Tech Board
This thread has been inspirational to me. Best of luck on getting everything sorted out with your insurance. Hopefully they can work something out to get this car fixed. -
Thank you for documenting your progress Trackzpeed! You've don't a lot a really great work--its truly inspirational. I will be transplanting in LS1/T56 from a 98' Z28 into my 240z. After going through your posts, I plan to use the CX racing mounts/Headers/Ypipe just like your install. Cheers! Shawn -
Just finished going through this whole post. Awesome job wickie! I know its been a year... any updates?
240z Build - LQ4 bottom - L99 (LS3) Heads - T56
wongboh replied to wongboh's topic in Gen III & IV Chevy V8Z Tech Board
Thanks for the info! 392 isn't far off from 400--that's reassuring. -
After getting my car stolen 4 years ago I'm finally getting back into the swing of things. I just purchased a 1972 240z with a SBC 350 / TH400 from an IROCz. It's a great motor and will serve me well while I piece together my new motor. In the meanwhile it had an oil leak so I decided to change the gaskets and paint the existing engine/firewall to clean things up a bit. I was originally going to buy an LS1/T56 but decided to go with an LQ4 so I could install a nice set of rectangular port LS3 heads. I decided to go with the LQ4 because I wanted to keep costs down. The car has good bones and no frame damage. I know the exterior needs work, but that can all be fixed via parts cars on Craigslist. I'm still doing my research and planning it out, but I've listed some photos/parts list of what I have so far. I've been a member of this forum for 9 years and finally have a 240 to work on. I'm excited to share my progress--hopefully this post will be helpful to someone in the future who wishes to do something similar. HLS30: That's the previous owner in the second photo smoking a cigarette Existing Engine: 350 SBC (Casting 14010207) Weiland Intake Manifold Edelbrock 4 Barrel Carburator Before & After Paint: I painted the firewall and engine with duplicolor high temp paint. When I install the new motor, I plan to have everything sandblasted and repainted. Future Engine: LQ4 Shortblock Purchased from Craigslist for $300 local (from 2003 2500HD, mileage unknown) Planning to have this honed, hot tanked, and re-assembled Will do an .030 overbore, pistons, and balance the rotating assembly if the shop recommends Oil Pan - TBD L99 Heads (Casting: 823 with 11,000 miles) Purchased from Ebay for $715 shipped My understanding is this is equivalent to LS3 heads but with VVT (Fitted to automatic Camero SS's) Rocker Arms - TBD Note: The 8 Intake rocker arms need to be offsett i.e. from a rectangular port head: LS3,L99,L76,L77,L92) while the exhaust rocker arms do not need to be offset and are interchangable with (LSx...etc) LS1 valve covers purchased from eBay for $75 shipped LS7 Cam: I chose this cam after reading these articles: (5.3L LM7 & 6.0L LQ4) Purchased from eBay for $105 shipped I wanted to increase lift as much as possible while keeping the stock valve-train Lift: 0.558/0.558 with 1.7 rockers (LS7 Cam) Duration: 211/230 (LS7 Cam) LSA: 121 degrees (LS7 Cam) The LM7 article lists the specs on a stock LM7 w/ beehive valvetrain upgrade: Crank HP: 422 at 6,300 rpm Crude estimate on my setup: 422HP * 6.0L/5.3L = 478 Crank HP Crank TQ: 395 at 5,000 rpm Crude estimate on my setup: 395TQ * 6.0L/5.3L = 447 Crank TQ Note: An LQ4 equipped with L92 heads will flow much more air than an LM7 The LQ4 article lists the specs on an LQ4 with L92 heads fitted with a 4-barrel carb and GMPP GM Performance Parts - Hot Cam: part# 12480033 LIft: 0.525 compared to the LS7's 0.558 Duration: 219/228 compared to the LS7's 211/230 Crank HP: 471HP @ 6,600 rpm Crude estimate on my setup: 471HP * (211/219)*(230/228)*(.558/.525) = 487 crank HP Crank TQ: 417TQ @ 5,000 rpm Crude estimate on my setup: 417TQ * (211/219)*(230/228)*(.558/.525) = 431 crank TQ My understanding is that a 58 tooth gear will be needed as well as the front cover/timing sensor Cam Gear, cover, and timing sensor - TBD L77 Intake Manifold, Fuel Rail, Injectors Purchased from ebay for $305 shipped from Austrailia Coil Packs - TBD Throttle Body - TBD Intake - TBD Exhaust: I plan to use the existing system: 2.5" Dual Magnaflow (no crossover) Standalone Harness I haven't done much research hear but I'm hoping to learn how to modify an existing Ly6 or L92 harness I listed an LY6 or L92 above because my gut tells me these will be inexpensive compared to LS3 harnesses but again, I haven't done much research here yet. Existing Drivetrain: Differential: The previous owner installed an R200 with turboZX axles. I'm planning to install billet stub axles I will need to research if the existing R200 will need to be upgraded I'm planning on having anywhere between 400-500 ft-lb of torque Existing Transmission TH400 with a B&M shifter (came with care from CL) Future Transmission T-56 - (I'm currently looking around for deals) Suspension: I plan to keep the existing setup Tokiko Shocks and springs (came with car) 15" Panasports (came with car) Brakes: I plan to upgrade the brakes before I install the new motor setup Toyota Brake upgrade: TBD Body: I plan to sandblast the whole body and replace the rusted panels in the future. Running Total of Expenses $4,200 Car $300 LQ4 Short Block $75 LS1 Valve Covers $715 L99 Heads $305 L76 Intake Manifold, Rails, Injectors $5,595 Total Please let me know if any of my information above is incorrect. I anticipate this will be a 2-3 year project. My goal is 400hp/ft-lbs @ wheels using mostly stock parts so I can maintain the vehicle using GM's recommended service intervals. I'd like to have the flexibility to take the car on road trips and weekend road course events. Here's a photo of me on the day I bought the car (notice the smile from ear to ear). That's my friend in the back in my Mercedes which I will be selling to pay for this project. Wish me luck!
Thanks Phantom!
I've been reading on these forms for 9 years and finally have the funds to start the project that I've always wanted, an all aluminum (LS-type) Chevy V8 with a t-56 tranny paired with an early datsun-Z body. I remember the first time that I saw this combo and instantly wanted one of my own. My budget for the body is $4000 so please, let me know if you'll be able to help me out. I'm located in Southern California but am willing to drive out to neighboring States for the right vehicle. I plan to post my build and finally give back to the HybridZ community. Thanks for taking the time to read this!
Q45 CV's for 80 bucks? is that for each one or for all 4?
Do all q45 come with R200 VLSD's or are some of them open differentials?
wongboh replied to wongboh's topic in Drivetrain
How much should a Q45 differential and half shafts go for? I found one at my local junk yard. What about a 240sx with a finned cover? -
Sounds interesting... have you done this? Originally I was planning on buying the two sets of q45 cv's at the junk yard. -
Thanks... I think I'll jump on that q45 differential i saw at the junk yard -
Do all q45 come with R200 VLSD's or are some of them open differentials? Also.. are all NA Z32 Differential R200v's?? Is it common to change the Stub Shaft to accept Q45 or Z32TT CV's on these diffs? Do you use an adapter or are the stub shafts inter-changable? Lastly.... Is it possible to use Z31 TT shafts on an R200v(It seems that all R200v's have stub shafts with 5 holes.... correct me if I'm wrong please)? Is there an adapter out there that will allow this? I am planning on swapping to either an 230V or an R200V. I would like to use the R200V because it is much lighter than the R230V and is adequate for my HP/TQ Application. The problem is that... it seems that the R200V's have the stub shafts with 5 holes. I'm not sure how to do a CV conversion on these diffs because the only CV's to use are the Z32 TT's or the Q45's. Please correct me if I'm wrong... and thanks in advance for any help I can get.
Thanks a lot
Does anyone have pictures of the front OE differential mount installed?
