G-Tech
    4
Everything posted by G-Tech
  1. That has got to be the best balance of Form and Function of a Datsun that i have EVER Seen!! Absolutely amazing!!
  2. Well Happy Birthday to Hybrid Z !There is still plenty of time to keep playing! What a great forum it has been. Thank you for those who help keep it going! I'm close to the 20th century (2004) since i started on my Z. Still going strong
  3. If he doesn't get back to you, i might be interested
  4. Not many take on this challenge, good for you! It is for sure a challenge. If you have rack and pinion steering, you have the worst. There is manual which is not bad and i dont exactly remember the name of the other style. Its like reciprocating, or something like that. Bottom line is, i found that a "block Hugger" style fits well on Pass side. It's the driver side that i had the most issue with. 1st thing is to pin the steering shaft (I drilled and tapped through it for a screw) so you can cut-off the clamping ear. Then get rid of the Rubber Rag joint on the steering shaft. Techno toy tuning makes a solid piece to put in place. I don't know anything about the size of it though. I made mine and made it smaller diameter for clearance. I have modified a couple different sets of headers. I 1st had a Hooker High Flow Manifold that i still had to cut a window in it and have a plate welded in from the back side. Then i didn't like that i had 2 different style headers so i bought BillyBoat headers for a C5 vette. Still had to cut a tube off and re-route a new one to avoid the steering shaft. Then i was worried thet 1-5/8" primaries were not big enough and i had someone make me a set of long tube 1-3/4" headers and found that it was not worth it. I went from 375whp to 387hp (very disappointing results for the $) Take a look at all the pics. There is a pic for everything i just explained. Worse case you can run manifolds upside down and they will point fwd. If you are turboing, this will work well. If not, you have to run the exhaust fwd and down around the front, which i'm not a fan of.
  5. Well my stock speedo only went to 85mph and i know it was revving a lil high at that point for long distance driving. But hey, if you have 75mph posted signs and your car don't mind 85-90, then u have a good car! I can't imagine an original 84 Maxima wants to do that speed anymore than my zx did when it was stock. Sorry i cant be of any help other than replying to your post, to keep it fresh
  6. If i still had cruise on mine, i'd be happy to find out for you. But i don't have it no more. Props to you for thinking you need a cruise control unit that goes higher than 75. Good luck. Hope someone can help.
  7. I fought with this for a couple years on my 280zx. I replaced fuel injectors, put a header on (pain in the ass). I wanted to make something out of that 6cyl...Did this and that with very little improvement. Don't think your really going to get more than 15hp more. Your just going to have to V8 swap it!!
  8. Glad i didn't start a whole thing here. FWIW i also agree that a Grill delete is an excessive thing to overlook or not mention. Like i said, it's a valid point to bring to peoples attention. Happy Building in the future!
  9. Sucks to hear you had such an issue. I have had problems similar with other companies also. It's super frustrating. I know i have purchased a handful of things from Apex Engineered. Some were fine but the rear subframe for a s130 chassis i got from them certainly had some modifying to be done. I have learned very rarely is something "Bolt-on". Even when they say it is. My Brakes from Arizona Zcar had to be modified, my Custom stub axles from whitehead performance interfered with the shock mounts and i had issues with the rear coilovers from T3. I guess my 2 cents is every company tries putting out parts that aren't 100% I would say be careful buying those hood hinges til you talk to them and see that the problem has been fixed. All these companies are small and trying to do more then they can handle. Hence mayb why their customer service sucks. It's tough out there and i hate to see post like this. There are certainly worse companies that don't deserve to be in business but i just don't feel this is one of them. I'm thankful for this company making what they do. FWIW, I have absolutely no ties to any company. I'm just an enthusiast Good luck with your build. Not trying to stir shit up (even though i feel i just did)
  10. My input on this is avoid steel wheels (pretty obvious opinion) My main reason for chiming in is to suggest that you avoiding wheels that you need to use adapters. My 1st set of rims were for a front wheel drive car and i had adapters. One day i took a wheel off and i noticed a stud had broken off and i had no idea because my rim was covering it. How dangerous to have a v8 car with 3 studs holding a wheel on. I went to Boze Wheels and they made me a custom set. Not cheap but there isn't many options unless you want the standard Rota wheels
  11. Hey, whats happnin slownrusty! Been awhile. Always liked seeing images of your car. I'm on 20yrs this year. Been in my family since new
  12. The Differential will swap but you have to look at the flange that the driveshaft bolts up too. If yours is round, you will have to swap that over(FYI, it doesnt just pull off, you need some sort of puller. Even just a 3 jaw puller from harbor freight). The 300zx half shafts and stub axles i do not believe swap over. If you want something stronger than universal joint half shafts you need to source 280zxt companion flanges and CV-joints. I have custom made stub axles that allow me to run 300zxt cv joints. The company that made mine are out of business. Z car depot might make something. If you do the 280zxt cv joints, they will work in any R-200 (longnose) Diff. And you will only need the 280zxt inner stub axle (called companion flange). Your stock outer stub axle is the same as a 280zxt. Which if you are running alot of HP (400+) and a stick shift. The outer stub axle is your week point. If your under 300hp you will be fine.
  13. The only thing i can really answer for you is the Diff question. That Diff will be plenty strong but you will be doing 1 wheel burnouts until you put some sort of LSD in it. I run Quaife LSD and love it. There are other makes out there that people like too. Good luck with the swap!!
  14. I don't know much about that swap but i have put a LS in my 280zx. At the end of the swap you will have the chassis electrical (interior/exterior lighting and any accessories you choose to keep or add), and you will have the engine and drivetrain electrical (engine, trans ). I have the stock computer still for chassis stuff and i have a 1999 Camaro computer that controls the engine and tranny. What i think you need to focus on is first getting the computer out of the G35 and either stripping the wire harness and sorting out the engine and trans portion of it or if you can, sourcing an aftermarket standalone wire harness just for your motor and trans. Basically, you want the motor to still think it's in the G35.
  15. I used them along time ago. They worked great. Fitment was real well. I have them hanging on a wall still because i had a couple welds crack and leak. I wouldn't let that make you not order them though. There isn't many options out there. They can get re-welded. I have rack and pinion steering for what is worth
  16. Dude!!! My inspiration!!!! Welcome back. your car is what convinced me to go v8 like 15yrs ago. Started with SBC 300hp. 4 motors later im at a 416 LS3. Your car is looking good! You still running a LT1? I was super impressed with what you did with that motor
  17. Looks great, really clean looking body! Eibach makes 1in lowering springs. That is what i started with. The pic is with 1in springs. Probably all he needs. If he wants to go any lower, he will need Techno toy tuning coilovers. That is what i have now. The front can only go down at most 2in before it needs the shortened struts that Techno toy makes.
  18. i think you are spot on for a sure thing fit. I have 17x7 front and 17x8 rear 225/45 up front and 235/45 rear. the only thing i did different then what you are talking about is i have 0 offset. but +4 is less than 3/16 of an inch so i dont think that will hurt you any. The front you have to make sure the tire doesn't hit the strut (i think you will be fine). The rear i had a problem with mine when the car squats, it would actually hit the front of the wheel well lip. That is from V8 torque. if it is still 6cyl you will be fine. Mine is lowered 2-3in
  19. Just to put my 2 cents in about stock aftermarket cv-axles. I bought the same trakmotive axles from Rockauto. They worked fine in my 280zx (different car i know). The main thing i noticed was the main shaft is a noticeably smaller diameter than stock. They worked fine other than that. I swapped them out after finding used OEM cv's. Ill keep them for backup but i was a lil concerned about strength for high HP
  20. Have you tried zcarsource or zcardepot? there used to be a company called black dragon and that is where i got my rack 10yrs ago. One of those companies bought all of black dragon's stock when they went outta business. Let me know what you find. I may be in need of another one myself
  21. Buyer beware with show cars in Ontario. DO NOT give him any money till something is completed. I dont feel like going into my huge mess i got into with him. I will say it was like 10years ago so maybe things got better but i would most certainly NOT give him money unless he has something done and ready to ship. You run into issues when a business you have problems with is technically in a different country. I ended up sending a shipping company to his door 1yr later just to take whatever part of a hood of mine he had. I sold it for $50, that's how bad it was. If he has something in stock and sends you pictures of it then you may have no choice but to get it. I know how hard it is to get things for s130's.
  22. Do a lil research to determine whether you have an r180 or r200 diff now. There is info based on what options your car has that will help u figure out which diff urs came with. or look up pictures of the 2 different ones and look at urs. The r200 will be fine as is for atleast 300hp and an automatic trans. A stick shift puts more abuse obviously. You will only do 1 wheel burnouts. There are options for a limited slip center section that u can have installed, all are pretty good. You might want to have cv-joint half shafts that came in the turbo models. U mostlikly have universal joint halfshafts ( again, do a lil research to determine). If you switch to cv-joints, you will need companion flanges for them to bolt to. i have an extra set i would sell for like $150. The companion flange is the other half of the stub axle. The stub axle is the main weak point but again, depends on the HP and auto vs stick shift. I have a 1983 280zx with 400whp LS, Stick shift that i drag race and beat on constantly. it still has the r200 with Quaife Limited slip, W/ 300zxt CV-joints and custom heat treated stubaxles.
  23. Those are for 280z not the ZX. Unfortunately i dont have any better advice. i made my own patch panels and got fenders from a company that doesnt exist anymore. Zcarsource might have fenders if it comes to that.
