MONZTER
    31
Everything posted by MONZTER
  1. Yes Wiggins clamps. You will never see hump hoses used on the upper echelon of motorsports. (Not that my car is that, I just want to pretend) The Wiggins clamps offer 3 degrees of float per end and the bore inside remains smooth and free of any turbulence causing "humps" in the plumbing. They also are 1 hand quick release, no tools needed. They are so good, except the color purple, but it is a Mil Spec specification for this type of fitting, just like the red and blue on AN fittings. Tony, FWIW I fully appreciate your insight and ability to apply your real world experiences to so many different areas. Really nothing much from an engineering standpoint is new anymore, much of it is simply reapplying ideas and techniques from one industry to another. This can be as obvious such as military to automotive, but it takes a real creative person to see the brilliance in the simplest most unappreciated things we take for granted. Jeff
  2. Hi Guys, Thanks again for the input. I can see your point that is probably such a small difference it probably won’t make a difference. The truth is, I am just a freak about this sort of stuff. I am really trying to look at every part of the system, and push it for a "textbook" approach. Bottom line is I like the challenge of figuring it all out. Here are some pics of my build. You can see how I am looking at everything from headers being equal length, to minimizing bends in the plumbing to simply how the air flows in and out of the intercooler. The horn in the question above will be built into a carbon plenum for my ITB set up. Sounds like I will stay with the round inlets.
  3. I run the Victoracer 265-45-16 on 16x8 Panaracer wheels under stock fenders with rolled lips. The Victoracers are kinda old school with their sizing, narrow and a little tall. A 265 Hoosier is waaay wider than the Victoracer.
  4. Thanks Guys, Trust me Tony, Barrels mm,mm good, looked into it, but I have to finish this thing up one of these years, oh ya, and not spend all of my kids college money..
  5. Yes, Very simply put this is what I am trying to do. I have seen intakes with Square and Oval shapes on the big end but can’t determine if it is for packaging or for improved flow. I will try to find the pictures. I believe one was on a Corvette LeMans Engine. Another picture I saw was on some V-12 exotic.
  6. Hey, I am working on my plenum for my turbo individual throttle body set up. Do any of you have opinions which shape would be more effective? The first one is round 88mm big end, 90mm long, 46 at the body. The second one id 88mm square big end, 90mm long, 46 at the body. Both are tangent on the big end and flat to the floor (not protruding into the plenum) Thanks for the input. Jeff
  7. Hi Tim, My specs were for the original question, main cap studs. Jeff
  8. The instruction sheet said 60ft/lbs only with ARP moly lube. There was no other spec for oil. Jeff
