32
Everything posted by Zetsaz
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
He went ABS on this and the distributor cap to be on the safe side. They'll never come close but at least there'll never be a concern about warping over time -
He's printing out of ABS. He was actually having some issues at first, warping, not sticking to bed... but apparently a firmware update on his printer solved the problems. PETG isn't as rigid but is more chemically stable (if I remember that right...), so I might use it for some of my fuel line mounts/isolators. My fuel lines are basically just zip tied together right now other than a few key spots where they're on insulated clamps. As nice as it would be to have an off the shelf part or just fab up some brackets, I might take some measurements tomorrow and actually try to design the defrost vents. If they're a total dud, it's a lesson learned and I'm only out a couple dollars in materials to my cousin. Also spent some time last night replacing the bulbs in the gauges with LEDs. Those green filters are a real pain to remove on the tach and speedo.Almost wished I'd just dumped the money at speedhut gauges already, but you know... budgets. -
Cousin sent me a video earlier... https://imgur.com/99RAg17 A friend in Boise who does some 3D modeling regularly took my measurements and made some small adjustments to my center vent design that my cousin just finished printing. Still has roughly the same angle as the piece I was making, but is a slightly cleaner design overall. Distributor cap coming up next along with some other small things! Will be also be printing me a basic bracket I designed to set my MS3x in the stock location. That being said... if it doesn't work I'm just going to fold some scrap metal and drill some holes in it for the ECU bracket haha. -
I think where I've positioned it I'll get about the best flow possible if the vent printing is successful. Cousin had to restart it. One side started warping (weirdly enough, the supports worked well, it wasn't the angled section collapsing) I'm amazed anyone gets it has high as they do. for room, I avoided pushing it any farther forward than the two bolt holes that supported the original heater core, as you can see from the front bracket. But at that location, I can't go higher up. I was barely able to squeeze out the inch drop I need for the drain hose, and even then, it's ever so slightly kinked going down the hole I made in the trans tunnel. I think the ducting will be fine, especially if I opt to use some of the stuff on the link you suggested @jpndave. As far as defrost ducts, I'm debating between these two right now.Top don't seem to have any sort of brackets. I think if I used the bottom ones with the closed side towards the cowl and just modified the brackets slightly I'd get them to line up right where the original holes are in the finish panel. -
Fortunately that's someone else's installation from ages ago that's still on the xenonzcar site for reference. they did a lot of things kind of poorly that I would never do the same way, but it gives you an idea of why I want to change to use their small included ones that don't drop down so low, or purchase some that already have a 90 deg bend in them to reduce the length of hose and bends in it. That being said, the stock stystem also uses corrugated hose and (at least on mine) the flow was okay despite a weaker and less efficient fan. If you have suggestions for a specfic type of smoother hose/tubing I'd love to hear it, but other than fixing the defrost routing issue issue, I don't really see the need to change from the stock style right now. -
That's not too bad! I'll probably make some forward mounting brackets that at least line it up with the stock openings. -
I'm working pretty slow right now, but I'd be happy to verify once things are put together and wired up! I'm slightly more concerned about the defrost right now. Stock vents are usable, but require some... interesting bends. I believe this installation is with the compac and not the mini, but mine is similar. I may end up mocking up some basic brackets for the small defrost vents they included, but I'm also bothered by the possibility of the way it looks from the top with out those vents fully covering the openings on the finish panel. Edit: by the way, Ross. I think those fittings you sent will actually work perfectly. Especially the 90s. I know they're typically supposed to go with the threaded end in towards the cabin, but I think I'm going to use them the opposite direction and they'll actually work great to plug into some of the stock AC hoses I had into the engine bay. -
Well, the school's only printer actually in the building apparently has some heating issues on large projects. BUT I made a thing... my cousin is printing it now. we'll see how it turns out. This is a new center exit vent. Figured while I'm having fun making an ecu bracket, having a new dizzy cap and TPS bracket printed, I might as well try my hand at some basic parts and see how they turn out. The defrost vents are too complicated, and honestly I could just make small brackets to mount the smaller vintage air pieces that were included instead of complicating things just to get a 90 degree bend that looks original to avoid putting a loop in one place on the ducting. -
Oh man... if my infiniti was sold I would probably be interested. Good luck! I've heard great things about Datsun Spirit's work.
Hmmmm.. What are you making there Omar...? Mocked up the plate with scrap metal I had laying around. Figured I could at least see if I liked the location if visibility would be good where they were recessed just like the original controls. I thought I was sooooo clever using the screw holes in the panel as potential snap plates until I realized they have "ramps" towards the front of the plate and I can't actually snap them in... I have a 3D print file ready to go, courtesy of @seattlejester and I'm just going to epoxy or plastic weld it to the panel. Also realized today that my place of work has 3D printers... Checking if I'm allowed to use them first thing in the morning haha. -
Center exit on the 280z is one big rectangle hole. Normally it would be what splits the air out to the side vents as well, but the vintage air has 3 independent exists instead. Center exit needs the side pieces cut and blocked off, and the entrance blocked with something that has an appropriate hole in the center. I'll load pics when I'm not on my phone -
Thank you! I'm really hoping I can get to the wiring portion of things tomorrow, but there's still so much left the more I look at it. Still need to modify the center exit. I'm almost tempted to finally buy a 3D printer and design some things. If I could redesign the stock defrost pieces and the center vent the install would be much cleaner -
Well... That was entirely too much time spent making 3 very basic brackets. Thought at first they'd just be templates to get the right fit, but considering they'll be totally out of sight and I'm not making nicer attachment points on the firewall like all the bracket madness the guys at project Binky get up to... I'm going to call this good. -
Ordered more things with some light black friday sales. -Odd ball parts I needed from Zcardepot, including the missing passenger side tail light rubber that was unavailable this summer. -Skillard window rubber wipe kit -Headliner and roof/pillar trim kit from MSA, as well as a fender cover for when I'm working on the car. Bumpers have apparenty been stuck at port, still waiting on Datsun Garage to ship. Will be checking in with them this week. Debating how much I really need CVs right now with Futofab having 20% (15?) off, vs front control arms that I need to finish correcting the caster. -
Is he still in business?? I've heard so many horror stories about poor communication and many months of lead time. Sadly only other carbon dash options right now are Carbon Signal in the UAE. Tough pill to swallow
Oooooohh, where'd you get the dash? Looks great. Love the engine start button placement and overall look.
AHH! Sorry, mixed up the N47 and P79 in my head. Thank you for the correction.
The N47 head (if I remember correctly) has a good combustion chamber like the P90, but the liners can be risky for a turbo. That being said, some people have made their head flow WORSE by removing them and not doing things properly. As far as pistons go, flat tops are actually great with a P90 if you have a standalone ECU. Nissan ran VERY conservative boost and compression with the now primitive efi. You can make more power on a stock block just by improving the efi. If you don't have a P90, stay with dished pistons, as flat tops will get you into NA compression territory for these motors, and the worse combustion chamber design of the earlier heads will severely limit you if you're really intending to boost. All that being said, Big Phil (turbo280z on youtube) ran an N47 head for a long time in his turbo L28 with good results until he switched to an RB30 build.
Interior Innovations Diamond leather interior feedback?
Zetsaz replied to ScramblerX's topic in Interior
A guy close to me said that's what he used and the only concern he mentioned was the fitment wasn't quite right but the quality overall is quite good. -
Window Bumper Rubber Location?
Zetsaz replied to Witchboard's topic in S30 Series - 240z, 260z, 280z
Ahhhh gotcha! At this point I've replaced pretty much every single warn out rubber/oddball part in my car, and almost literally everything has been taken apart at some point or inspected, so if you have any questions, about weird items feel free to ask me! Some odd stuff specific to only a couple years I'm less familiar with, but body/mechanical/interior specific stuff I'm fairly familiar with original parts at this point. -
Z car depot is generally quite good at pointing out differences between the years and whether or not the part is needed for your car. Hang onto them in case someone else has done the same. I have a friend with a late 280 who might be able to check -
Do you have your door panels off? It's on the interior on the "floor" of the door. It's a rubber bump stop on the inside for when it's completely rolled down. -
Weather is getting colder by the day and I think I've just had the last few moderate days of driving for a while. Time to start fixing small things (as in... My hands won't fit in these small spaces!) Pulled the dash tonight to start working on the vintage air... It's even less room to work with despite being the gen 2 mini. I'm debating weather or not to move the ECU over to the passenger side while I have everything out and it's easier to access, but for now the focus is on the Vintage Air and some patches of Dynamat on the most resonant spots of the firewall. New bumpers are also ordered! Odds and ends I need are finding some firewall AC bulkheads I like that'll fit the AC hoses I have, and figuring out how I'll get the hoses inside routed -
You should consider your use for the car as well. 9k rpm sounds ludicrus on an L series, but if you're in a mostly street car you'll rarely get opportunities to get even close to that unless you're on freeway on ramps. My L28 is a pretty much stock block but with improved accessories and MS3x with sequential fuel and spark. It drives great even though the acceleration isn't like modern cars, but I rarely get chances to go past even 5.5k where the power starts to fall off in the stock motor.
Alignment done today. Left side was WAY out but somehow I got the right rear dead on. Found out one of my local datsun friends did the alignments at a Les Schwab nearby and got it done through him. He took the time to pull the spindle pin for the rear of each control arm to ensure we got the toe as close as possible. Camber all got suprisingly close too! All of it ranges from about ~ -1.3 in the front to ~ -1.5-1.8 in the rear. My current ride height is perfect and doesn't need excessive negative camber for good clearance, but it seems like the rear right tire has been rubbing slightly on the lip on the way out of hte carport, so I'll probably do a mild roll on the back for better clearance.
