33
Everything posted by Zetsaz
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
I mean... if I wanted EASY I could always just get Z Car Garage axles that bolt in, but that's a $1500 endeavor and would cover most of the rest of what I'm looking at doing haha -
Haven't done checks while prying, but I already have a rebuilt CLSD, with an RT style diff mount and double checked all mounting points and nuts/bolts were tightened. Noise is also happening if let off throttle at low speeds and go back and forth between coasting/loading the engine downhill. Can hear a bit of thunking every time I let off the gas or hit it again at lower speeds. Doesn't happen at cruise or if I only shift at higher RPMs. I had assumed that had to do with all the load already going one direction on the joints and them not having much slack on them to move back and forth at that point. -
Appreciate the input! The big question with the U joints is, do I just replace them with more heavy duty new U joints, or spend the big $$$ on CV axles? I'm not running much power, but I care more about a smooth and reliable ride. EDIT: For the price of good CV axles that don't require modding or other mixing and matching, I can probably get new U joints, the interior vintage air stuff, and control arms which is making me rethink some things. -
Looking for some feedback on what to prioritize next. Have a handful of "big ticket" items that need to be done before power is ever a concern. I can probably do 2-3 of these at once with the money I have set aside, but can't do all of them for another few months due to limited budget and my job's extra stipend money not usually coming in until November. These are listed in no particular order -Cabin side Vintage Air parts: This would allow me to finish up everything on the dash side and not pull things anymore, as well as get a bit of heating for the nicer days I might drive in the winter (nearly no snow in the PNW, so I'm not worried about salt and corrosion on days it doesn't rain) -Bumpers and rear speaker bracket: Would allow me to properly put together the interior plastic panels for the last time and the exterior would be complete (small paint bubbling issue that will be repaired for me if it's deeper than clear coat aside). Technically this is more to tidy things up making the car look "finished" and less for anything functional I need. -Rear (and maybe front) control arms: highest priority here is correcting the toe-in at the rear wheels to prevent wear. Both front and rear have slightly more camber than I want, but it's pretty close and less of a concern than the toe. -Front and rear strut bars: I've read from multiple people (with way more experience building stuff than I do, and more racing experience) that the front is especially helpful and can improve front traction dramatically. -CV axles (or just U joint replacement): Rear U Joints are making a lot of noise on shifts right now and on bumps. Cruising is smooth. Not sure if I want to just replace them, or go straight to CV axles. -
Got on a one track mind and forgot to get more pics of the dynamat. I'll get some later on. Between that and the resonator, the car is so much more enjoyable to drive. Only downside is now I can't tell if it's slower because of a slightly more restricted exhaust, or if it's a placebo effect and only felt faster due to noise before haha. Only the rear corner where the original antenna used to be has some bubbling right now. I'm hoping it goes away, but fortunately most everywhere else that I thought was bubbling only looks like a tiny, needle point sized, "dent" in the clear and I should be able to buff things nicely. Hopefully, at worst, the bubbling I'm still seeing in the rear corner is something I can wet sand and fix with touchup, but at least now I know it's just a small area that might need to be blended in and I fortunately won't need to respray the whole exterior. Any other areas that may potentially be concern I'm honestly just going to let go. By the time it becomes even slightly noticeable I'll probably be wanting to color match some carbon panels or something else. Currently dealing with a short on my right turn signal. The wire on the switch has corroded near the original soldering. Ordering new soldering stuff now to hopefully repair it for good. It's amazing how many small things keep coming up now that I'm driving it regularly. I'm almost grateful for current circumstances allowing me to work on it more and really get things to the point where it could be usable as a daily. -
Interest in Chassis Strengthening Kits
Zetsaz replied to sabiauto's topic in Brakes, Wheels, Suspension and Chassis
Depending on where they're placed I might be interested in some select pieces. My car already has sound deadening and some other things, so I'm pretty limited in how much more I can do for chassis reinforcement if it involves welding under areas that have material applied, -
Looks like my last response didn't post from my phone... I think I used either 1 gallon of each or 2 gallons of each. Can't remember which bucket I bought, but I remember when I was first applying it and talked to you about dry weight I concluded the lizard skin wasn't more than about 20 lbs in total. Having compared both now, Lizard skin was much easier to apply and probably took less time (not counting dry/cure time). If you're done the math then that actually sounds about right. I bought the "mega pak" which has about 96 square feet and it won't fully cover the interior, though it does get MOST of it which is more than you need for adequate deadening. If I were to do things again, I'd probably just use adequate coverage of the ceramic coat for full coverage against heat everwhere, then use Dynamat in all the large flat panels and tucked in key areas for the sound deadening. more coverage depending on how concerned you are about sound/weight ratio. Paint update for everyone else: mentioned to Dave yesterday that I noticed some tiny bubbling in the paint. Painter called me back a few hours after I sent him the same pic I sent you. He said it's too hard to tell how deep the source is from just the pics, so he'd have to see in person to properly advise, but admitted that ultimately the prep and spray was his responsibility and we'd see what can be done. I've inspected more of the car and a lot of the spots that looked like they were bubbling (so tiny I they don't even show up in pictures), were probably just off gassing solvents in the clear coat. I wiped down some of the areas and they actually left tiny streaks, but I could get the dots to go away even with just tiny wipes over them with my bare finger. That rear corner by the original antenna location is the only spot that has noticeable bubbling that's potentially deeper. I'm going to wash and wipe down the car later today to get a better idea of where it's happening. In the meantime, I was already scheduled at an exhaust shop down the hill from me, and a resonator (glasspack) is being installed in the center of the car right now which will make cruising even more comfortable. -
I'm sure it's about as difficult to remove as the original deading tar (?) based stuff that came with it stock. My car is very much a street/cruiser car. As much as I've cut weight in heavy dated tech in some areas like the emissions and original heater core/fan, I'm not concerned about every last pound. I bought the "mega pak" to be able to do everything. Shipping weight was about 30 lbs so I'm assuming between this and the dry weight of the Lizard Skin I used, I'm not adding more than about 45-50 lbs of sound deadening/heat control. That is MORE than offset by losing the 280z bumpers and bumper shocks, vintage air will be lighter than just the original fan, original tar sound deadening is all gone, emissions stuff is all gone, hvac vacuum control stuff and solenoids are gone, original engine harness is way heavier thanks to the AFM and some other bits... it's a lot. I'm expecting about 150-200 lbs net loss in weight or more from stock. Will never get down to early 240z weight, but I'm okay with that in the sturdier 280 chassis with stronger parts than the 240z came with. -
So close... So tired... Will post up some pictures when I'm mostly done and the seats are ready to go back in. Doors are already so much better, but hopefully it also helps with the large flat areas that Lizard Skin didn't quite do enough for -
Bottom line is, everyone will always complain about something. I think for the most part it's a solid car, and the mostly understated styling will prevent it from looking dated too soon. -Twin turbo -RWD -6 spd manual All the sorts of things most people claim they want, bu most of those complaining couldn't afford it anyway.
Exciting things will be happening soon... But probably not until this weekend. I was tempted to leave the box closed and just caption this post "WHAT'S IN THE BOOOOX???" but the effect isn't there if people haven't seen Se7en with Brad Pitt haha -
This is honestly tragic. I was considering them mostly for the front and rear control arms. I don't want to burn through tires waiting to correct rear toe in particular. Their control arm designs, especially for the rear are preferable to me over the T3 offerings. May just hold off and see if they figure things out, someone else fills the void, or T3 comes out with an offering closer to the Apex rear arms.
Agreed on both points. Lots of people commenting that it has a square opening just like the s30, but the S30 had the bumper to break things up. What's funny is the grill even has two distinct looking areas top and bottom, almost like the 240z grill that didn't cover below the bumper. Saw a very minor edit with a body colored line between the two sections of the grill and it actually cleaned things up a lot and broke up the giant mouth look on the front. Not a perfect solution, but hopefully they break things up a bit. I know on the early cars, bumperless is very popular right now, but I always thought it looked incomplete, and the same is true for the new one.
Small progress this weekend despite all the smoke. Fitted the single piece outter seal. Some small things I missed arrived from home and I put the seal on the filler neck as well. Can't seem to get the upper edge of either of the hatch seals to seat properly. Soooo frustrating, but it's closer than before. My turn signals are intermittent right now. Might be the flasher or my hazard switch is being finicky. Going to take apart all of it and maybe talk to... Dave Williams? Who does the rebuilds and headlight relay upgrades. Lives about a half hour from where I am. Lastly, I bought the sound deadening I need. Last big purchase for right now will probably be the bumpers. Need to check on backorders. -
I'm only worried about it looking like it "belongs" in that it's well positioned and doesn't look like the hole's been hacked out. It's under the carpet, so oem appearance isn't much of a concern. I'd need to make a lip if I went with the OEM tool doors. I do have some extras on the parts car in Utah still and they'd work great, but it'd be raised up if I didn't make some kind of lowered lip on the edges for the door to sit on just like the original tool doors have. I think an 8"x8" door from tanks inc. might work well, but I've only spent about 2 minutes on a google search looking at anything premade. -
Yeah I'm almost tempted to find a premade door for like $20-$30 with the magnetic push latches to keep everything really flush under the carpet. We'll see what I can find. In the meantime I've ordered a cover plate for the spare tire well, and a single piece outer hatch seal. I was disappointed that some water leaked in last time I went through a touchless car wash. Also lucked out on some of the correct seatbelts on ebay for the year that mount on the pillars instead of the strut towers. -
WTB: Modern Motorsport brace for R200 finned cover (or equivalen)
Zetsaz replied to 24OZ's topic in Parts Wanted
If you notice the bottom left of your picture, the original brace goes across almost at the very bottom of the drop mounts. The T3 has it set much higher, basically right against the mustache bar, with slightly better clearance if you also get their bar. My bar is skimming the brace, which I'm not sure is ideal, but it hasn't been an issue in 2k miles of driving. No shaved fins. The cover is completely original. -
The pickup/pump mount has adjustable height, it's about at the floor of the tank. I just mean that even though the assembly is low profile it's still slightly taller than the original pads that were on the fuel tank by about 1/4". O Ring plate would make it more like 1/2" because I didn't cut and reweld to make the top of the pump assembly sit flush with the original top of the tank. However... Right now that means every time I try to set the pump in, if it's not perfectly aligned (and I mean perfectly) the friction from the bolt threads pushes down on the ring inside the tank that it clamps to. With the optional O ring plate you already have two rings sandwiching the tank's metal and there's no issue wiggling the pump into place or even tapping it. See the pics for what I'm referring to. Second pic doesn't have the inner ring installed since it was just for test fit, but picture the mounting bolts attaching to the black plate inside instead of the red O ring plate. Foam seal isn't enough to hold the inner ring in place with any more than a few pounds of pressure pushing down on it if the threads catch the pump even slightly off center -
So... as much as I prefer the retrofitted in tank pump assembly for longevity down the road, this thing is a huge PITA to service without some sort of access door in the car. Mostly since I'm not using the O ring adapter to mount it, but I need the clearance since I didn't make a cutout in the tank to lower the pump assembly. It took 3 hours but I fixed my pressure loss issue. The hose provided with the kit I used was poor quality and ruptured. I replaced it along with the clamps with one from NAPA of the same inner diameter that felt MUCH stiffer and was noticeable thicker. Hopefully I don't have to drop the fuel tank again any time soon. Currently I'm rethinking what my priorities are next. The evenings are already getting cooler here and I rarely have any reason to drive in the hottest part of the day. The lizard skin is good enough to not roast inside the car unless I'm not moving for a long stretch. I might be prioritizing getting some rear control arms first so I don't have to buy tires too soon from excessive toe in wearing them down. In the meantime, enjoy some pictures of my post-repair cruise through Chuckanut drive. I'll have to get some better pics near the water sometime. -
I messaged him almost two years ago when putting my suspension together and getting the new diff with finned cover mounted. Doesn't make them anymore (might be again, but wasn't at the time). I went with the T3 kit and I'm happy with it. The mustache bar Nelsonian posted isn't necessary on a 280z, but the clearance is really close without it and I might swap to it down the road anyway if I don't go a completely different direction with suspension . This is all I used: https://technotoytuning.com/nissan/280z/drop-mounts-and-dogbone-combo-240z-260z-and-280z -
Ran into my first big hiccup. Car won't start. No fuel pressure. No leaks anywhere. Fuel pump priming. After reconsidering how clean the tank is and the new hoses and the effort I made to get any dust out of the vapor tank, I think it's just a clamp on the hose in the in-tank pump that came loose or the hose burst. Dropping the tank tomorrow. Will be a good opportunity to do a manual calibration on my fuel gauge as well. Also washed my Infiniti after neglecting it for the last maybe 4 months and it's really left me wanting a quieter cabin and more speed. So comfortable and quick and reliable, but to really make any big purchases on the Datsun now I'd have to sell it. Guess I'll spend the next year thinking about it and maybe making a decision haha. -
Drive back to Washington went without a hitch... mostly. I had a somewhat unfortunate run in with a whole lot of tumbleweed near Twin Falls, and extreme winds on top of 80mph speed limits blew off my driver side windshield wiper. Fortunately no damage to the fresh paint aside from some a few very tiny nicks in the air dam that I'll get some touch up paint on asap. First purchases soon will be protective coating for the front and the vintage air unit. Would love to be able to keep the windows up at higher speeds to avoid the excessive wind noise on longer drives. -
Used to have one but on the old efi, junky seals, and rotting body it made no difference. Right now I don't even have the MSA tip on, but I'll be putting it on when I get to Washington as well as adding a resonator. City driving is annoying due to the cabin drone. Lizard skin can only do so much All new hoses on it now. Old ones definitely get super hard. Was pretty hard to even get them to come off. I don't think the tank is particularly heavy in mine. At least not heavy enough to justify dealing with vapor and tank pressure issues.
