Derek
    53
Everything posted by Derek
  1. Ok I got the heater in today and it looks pretty cool. It's about 7" tall and about 3" in diameter. It fits very well directly behind the alternator. The inlet is in the bottom and the outlet is in the top. I decided to pull cold water from the drain plug on the radiator and feed it back into the 3/4" nipple coming off of the water inlet on the block. I filled the radiator back up with water and plugged the unit in. It started getting hot right away. I let it run for about 10 min and started checking for heat. The lower radiator hose was getting warm but the rest of the motor was still cool. It was apparent that it was taking the path of least resistance and reentering the radiator through the lower hose. I didn't have time to do any re-plumbing so I just let it cook. After about 45 min the radiator water was a piping hot 160 degrees! I was quite impressed. I think whats happening is the thermostat is keeping the hot water from circulating. My plan is to drill a small hole in the thermostat. I'm thinking along the lines of 1/8" or 3/16". When I get it all figured out I'll post some pictures. Derek
  2. Happy birthday Big-Phil. I know what you mean about people believing you as I also was born on April fools day. Wow two hybrid members born on April 1. How about that. Derek
  3. Well I just turned 49 today and my main ride is a F250 4wd Diesel. I'll certainly take this info seriously!!! I really didn't want the car apart for too long in the shop so I was trying to get a handle on what I have. I'm going to drive it like it is for a few weeks so I can get a little road time in. 10 or 12 years out of my Z is just too long. I'm looking for all kinds of errands to run. Thanks Derek
  4. If only I could remember!! I think they were Bosch but i'm not sure. I'm not even sure if Bosch made shocks for the Z. I got them from one of my customers who had a Z car specialty shop in Fort Lauderdale. I was going to go with KYBs but he talked me out of them. At this point I think I'm going to have to tear it apart and see what I have. I have access to a press and a 400 lb digital scale so I can measure the rates. At that point I'll figure what I'm going to do. Thanks Derek
  5. The first two shots are "lost foam casting". In the head picture you can see the different EPS foam pieces assembled. The picture of the block has already been dipped in slurry and ready to be backed up with dry sand. I do a fair amount of lost foam casting. It's really a very cool technique. Derek
  6. Yes I'm hoping I don't need to run it all night. It says it has a thermostat for over heat protection. the company that makes this also make standard block heaters for just about everything imaginable. They offer a 35MM heater but it's only 400 watts. If this actually works I'll buy a couple of the core plug style and loose the tank. The tank was the quickest way to find out if it's worth the bother. I'm running a 192 degree thermostat now but I don't think that makes it heat up that much faster derek
  7. Alright. Here's what I plan to do. I ordered this heater from JC Whitney ZX540691A http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=ZX540691A&searchbtn.x=0&searchbtn.y=0 It's a tank type 1000 watt heater with 5/8'" nipples. According to the Zerostart literature it will cost 6 cents an hour to run. I can afford this. I'll post some test data as soon as I get the heater installed. An early Z with carbs is not going to work well with a remote start system. For me this is the best solution. At least for now that is. Derek
  8. I really think too much sometimes. But it's fun Derek
  9. Or perhaps Great idea avenue. Here's what I want. I want to have my car at operating temp when I get in it. I don't happen to think this is a bad idea. Here's what I know. When the temp is around 30f and I don't plug in my truck the temp gauge never moves by the time I get to the shop and you can forget about heat. When I plug the truck in over night The truck starts better and the heat is noticeable. The temp gauge doesn't make it up to operating temp but does move pretty far. Ok here's what I've found out so far from a single source on the web. This means I'm right and your wrong. (do iI really need a smiley face here?) this is from a forum on dodge trucks http://www.dieseltruckresource.com/dev/showthread.php?t=193010 They were experiencing engine temps of 130 to 140 or so on tucks that most certainly have more mass than my Z. Tomorrow I'm going to plug in my truck and measure the amp draw and do a cost calculation.I'll also measure the temperature rise. Then we'll see who's laughing then!!! Derek
  10. Yes but multiples might make the difference. Derek
  11. Yes but the car runs much better at 190 than it does at 80. So my theory is if I can maintain the coolant as close to operating temp as possible, every time I jump in the car for a short trip it would be warmed up. I live in theoryville In the winters even though it rarely gets below freezing I use the block heater in my Diesel for the same reason. Derek
  12. So Here's the deal. I live 5 minutes from my shop. It's 5 minutes to the hardware store. 5 minutes to everywhere I seem to go. The car only reaches operating temp by the time I finish my trip. Here's my thought. I'll install a block heater or two and leave the car plugged in when I'm not driving it. At least it should be better than it being stone cold. Any thoughts or suggestions on this? Thanks Derek
  13. Ok Here's the story. I purchased a set of front and rear coil springs out the Nissan competition catalog in probably 1990 or so. I put them on the car and drove it for a short amount of time then the car was parked since then. I just got the car back on the street and I'm not happy at all with the harshness of the ride. It handles like a dream but I'm making this my daily driver so I need something a little more forgiving. Does anyone have any direct experience with these springs and can maybe help me establish a benchmark as to how stiff they really are. I want to buy a new set of springs but I don't want to end up with the same ride as I have now. Thanks Derek
  14. Yes I'm just an old "normally aspirated' kind of guy! Well I was going to call you today and get the lowdown on what my options are. I have an extra drive shaft and 4 speed transmission so I could have all of the machine work prepped beforehand. I can fit the drive shaft in the big lathe but I'll probably sub it out to a local shop. I really just want to drive it a little bit before I go swapping out a tranny. Derek
  15. Thanks for the words of encouragement but that cylindrical shape in the foreground turned out to be a needle bearing. It was also a quart and a half low on gear lube. I threw in some new gear lube and I'll drive it for a while like it is. I don't plan on rebuilding it so I'm not worried about doing any damage to the tranny. Now I have to figure out what direction to go for a transmission replacement. Derek
  16. I'm changing the lube in my manual trans and this is what I found Is my transmission angry? This can't be normal can it? It's got a noisy bearing so I think I see an upgrade in my future. Any thoughts Derek
  17. I too hate participating in dreams but I'm trying to get my post count up so I'll just jump in.! The head idea is in my opinion a much better idea. I would think that casting more of a blank as far as the combustion chamber is concerned and plan on having it machined on a 5 axis CNC mill would be a better way to go. Trying to get people to agree on a standard size and design might be problematic. I also agree that basing it on existing manifold designs would make things easier as well. If it had the stock port spacing but was a cross flow design then theoretically after market headers and intakes would bolt up to the head. Now the problem is the tilt of the engine reduces the room you have for intake system on the passengers side of the car. On the drivers side you have 15" from the head to the shock tower. on the passengers side you only have 10". For a NA motor this may be tight. This kind of stuff costs big money and for what you would have to plunk down to make this work you could install a RB motor and still have some left over. Just my opinion! Derek
  18. Keep us posted on that if you can. I have the same idea but I'm probably a few months away from doing it. thanks derek
  19. Just to give you guy's an idea of costs I would charge at least 15,000 for a set of patterns of this complexity. I get $1000.00 for a fairly simple double sided pattern that fits in a 13" x 18" box so if you do a little math the price could get astronomical for such a limited run. I just looked at the site again and saw that he had 1500 hours in the patterns and I'm not surprised. Making a pattern that looks like a block on the outside is relatively simple. Making one that actually works is a whole nuther ball game. I'm not trying to throw a bucket of cold water here but just trying to give you guy's something to think about. Look at how long it's taken me to get my manifold to the point of a single raw casting. Derek
  20. Has anyone tried the halogen 1156 replacement bulbs as a backup light? Thanks Derek
  21. Lot's of progress on the car but nothing on the manifold. Plus I just got slammed with a bunch of pattern work. I'm so close to getting my car back on the road after a 12 year or so hiatus that I'm going to be sticking on that. As soon as I get the car drivable I'm sure I'll be itching to get rid of the SU's so things will progress rather quickly from there. Thanks for the interest Derek
  22. Found this on culture garage. http://tanetane92.web.infoseek.co.jp/gallery.html Very cool stuff Derek
  23. I used SEM 39853 Texture paint on my dash and plan on using it on my console mods. Derek
  24. I went this route http://www.classiczcars.com/forums/showthread.php?t=23919 I followed Bruces instructions to the "T" and couldn't believe how nice it came out. I did my repair with the dash still in the car but with the windshield out. Not the best but it was workable. Here's a couple things I found during my repair. I drilled tiny holes at the ends of the cracks to check the crack from spreading. Make sure you remove enough of the black dash material next to the crack. Mine was warped upward. I didn't cut it far enough back and when I started to feather out the filler I broke through immediately. Make sure you have a thick enough layer of bumper repair over the crack. I sanded it too thin and when I pulled the car out in the sun it cracked again. I would try and leave at least 1/32" thickness over the crack and feather it out 2" or more on either side. I'm still amazed at how good the dash looks and how easy it was to do. I keep looking at the dash and just can't believe how good it looks. Derek
  25. I did my repair as per this post http://www.classiczcars.com/forums/showthread.php?t=23919 It went exactly as advertised but I made a couple of mistakes. Make sure you remove enough of the black dash material next to the crack. Mine was warped upward. I didn't cut it far enough back and when I started to feather out the filler I broke through immediately. Make sure you have a thick enough layer of bumper repair over the crack. I sanded it too thin and when I pulled the car out in the sun it cracked again. I would try and leave at least 1/32" thickness over the crack and feather it out 2" or more on either side. The SEM texture spray and trim black paint paint work great. One of my cracks came back and it's because i sanded too much of the bumper repair off. AGAIN!!! The other crack that I did with a thicker coat is holding up great. I live in Florida so come August I'll have a better idea of longevity. Derek
