Pop N Wood
5
wanting ideas on new project
Pop N Wood replied to sleepyzzz's topic in Gen I & II Chevy V8 Tech Board
That engine might suprise you. Mine had been sitting for the last 6 years. I did use fuel stablizer and started the thing one or twice a year during the storage. But after 6 years of sitting it started right up and drove. Drain and clean the fuel tank, clean out the carbs, change the oil, change the antifreeze and flush the cooling system, pull the plugs and squirt a little Marvel Mystery oil in there. Then turn it over a few times by hand then see if it runs. Take it slow at first because the brakes have undoubtedly glazed over. A 74 I believe had the crappy flat top SU carbs. If I were you I would consider picking up a complete, used inline 6 from somebody doing a V8 swap. I will bet you can get a complete, running engine for less than $500. If not at least swap out the smog carbs for some earlier SU's. BTW, I am always amazed at how well Z cars run and how reliable they are. But your car is over 30 years old. There will be intermittent problems that spring up. Make sure the wife has a cell phone, AAA card and stays out of bad neighborhoods at night. -
I would rebuild the carb first then see if you still have a problem. A car that old, especially if it has been sitting, probably needs rebuilding anyway. What year is the car? If it is a mid 70's, then you have a smog carb. Probably worth while to just scrap the old carb and pick up a new edlebrock with manifold. Might be dollars ahead in the long run.
I've choosen the engine I'd like :)
Pop N Wood replied to Lvcien's topic in Gen I & II Chevy V8 Tech Board
Getting a 95 and up will get you an improved optispark distributor. Those suckers are expensive to fix. If given a choice, get the 95 or later. There is one on ebay, complete with tranny, for $1300. http://stores.ebay.com/Fparts_LT1and-LT4-Engines_W0QQcolZ2QQdirZQ2d1QQftidZ2QQtZkm it is out of a Camaro so it will have aluminum heads with 275 HP. The Caprice motors are iron heads with less HP. -
I have refinanced cars and my credit score is 797. Can't hurt it too much. And I think bastaard525 is looking for a shorter term loan, not longer. There should be no penalty for paying on a long term loan like it was a short one. The advantage of doing it that way is you have the flexibility of dropping down to the minimum payment should you have a rough month. If there is really no penalty for paying extra, then don't refinance unless you can get a better interest rate. Call around and shop for deals. The place we refinanced with said they were going to assume the loan for no cost with the same payoff period we already had. The interset rate was so much better it dropped our payment by something like $50 a month. An absolute no-brainer.
Help us decide! Mazda3, Sentra SE-R, Civic Si, for my wife!
Pop N Wood replied to a topic in Non Tech Board
Drop the SI and just get a 4 door Civic. The SI's cost a good bit more, don't have 4 doors, get 10 less mpg and even with all that in stock form aren't exactly performers anyway. I'll bet you will get a better deal on a standard Civic than the SI. You wife will be much more happy with that car. -
What year is your Z? If you have a 72, then stock it didn't have front speakers anyway.
Kind of an amazing statement. 30 years ago "Made in Japan" was a euphemism for cheap, low quality junk. I suppose in 30 more years we will all be clamoring for the Chinee spec merchandise and not that cheap, Pakistani crap.
Oh, man. You would look stupid doing that without an airdam.
are brake dust shields required?
Pop N Wood replied to J__'s topic in Brakes, Wheels, Suspension and Chassis
???? If a brake line gets severed, then what is a dust shield going to do you keep you from losing hydraulic pressure to both front brakes? How is either front brake going to work? I would think the issue would be road debris damaging the rotor or mud/liquid causing it to become slippery. -
I should start on his program. I think I would have a much more impressive "before" picture.
four piston front brake question
Pop N Wood replied to dune333racing's topic in Brakes, Wheels, Suspension and Chassis
I just did the 4x4 upgrade this weekend. Like Trevor says, the spacers are needed between the hub and the rotor hat to align the rotors inside the S12W calipers. Alex's pic shows them pretty clearly. The stock steel wheels did rub slightly on the innermost cooling fin of the 4x4 caliber. I imagine a thin (may 1/4 inch) spacer between the wheel and the hub would fix that. But 60 seconds with a die grinder on the innermost caliper fin yielded adequate clearance. Nice, meaty looking brake set but heavy as all get out. -
Wish I could take credit for that comment, but on about link #20 of the above it was posted by someone else.
8:1 CR begs for forced induction...
So what was home schooling like?
What does "pre ban" have to do with anything anymore? All that chit expired.
"A couple of years ago" might have been during the time of the DC sniper. In that case your probably were not he only one who got rousted. I *think*, from watching cops on TV, that they are allowed to search for weapons if they have reason to suspect weapons or to guarentee their own personal safety. A report of an armed man is most likely considered probable cause. And a hand gun will fit in a purse.
Top speed on an Apache is 178 mph. Top speed of a radio call is 671 million miles per hour. Muzzle velocity of a 9 mm round is 784 mph, depending upon the load. You do realize running from the cops is a felony. Lose your right to vote or own a gun forever.
You might have accidentially connected two lines that shouldn't be connected. Or you could have a short somewhere (anywhere) in one of the lines. Had the same problem on my truck when a trailer light harness went bad. If your lucky you will check your new wiring against the schematics and find your mistake. If you are unlucky, you will chase through all the wiring in a 30 year old wirig loom to try and find the chaffed wire. Good luck.
NO! NO! Not the little red button!
I have no idea what those things could be doing. Best to wait for Hot Rod or Car Craft to get ahold of them.
Damn John, good link. Wish I would have had that when I lived in CA. Although I didn't see anything in there about a "locked box". Hard to drive to the gun range in a Z with a range bag and not have both the ammo and gun within immediate reach. But I did learn you can carry a loaded pistol in your car if you live in the car. Or are camping. Or if you are a zookeeper. Not to get political, but is actually quite easy to get a concealed weapons permit in LA. All you need to do is be a movie star and meet the Culver City chief of police at a party. Every now and then the LA times publishes the concealed weapons list and it was 90% Hollywood types. Joey Bishop can carry a gun, but someone running a check cashing buisness in south central can't.
Huge difference between California and Florida. I am interested to hear the answer myself. The biggest problem I have with gun laws is most times even the cops don't know what is right. Believe me, I have asked and different cops give different answers. I know in some states, even with a concealed weapons permit, you would have been in violation since the gun wasn't on your person. Also you don't ever have to agree to let a cop search your car. If he asks and you agree, then you have just given him permission and thereby waived whatever rights you might have had. If they have probable cause (for whatever reason), then they are going to search it anyway. But you don't have to give permission. Have to wonder why cops ask questions like that. Couldn't have been for his safety since he already had you sitting there while he ran the plates. You can always claim amnesia.
I thought MikeJTR said in one post that a T56 cross member can be made out of a flat piece of stock since the T56 mount comes down about an inch farther than the T5 setup. It was in a post where some guy mounted his JTR supplied cross member upside down to get it to work.
1971 240Z Front strut assembly S.O.S.
Pop N Wood replied to BWRex's topic in Brakes, Wheels, Suspension and Chassis
John C sells complete, sectioned strut assemblies on his web site. Very pricey though because he has done a lot of work to them. -
Anyone know if the JCI LS headers are different from the JTR ones? JCI is $20 less, but JTR offers ceramic coat (for $125 more)
