Pop N Wood
5
Hah! I was writting such a list just yesterday. John's cars is at http://www.brokenkitty.com/. Start reading there on what is required. Your second stop is Jaguars that Run, http://www.jagsthatrun.com/. Buy the swap manual from them. Not LS1 specific, but you will save a public "SEARCH SEARCH SEARCH" flaming if you ask questions you could have answered with the manual. Lots of invaluable info in that book. The brake line question is covered in there. Radiator you can get from JTR, or you can recore the stock radiator to a 3 or 4 row core and use that. Get the drive shaft from the donor car, and consider getting the Camaro fans too. You will need to figure out what you want to do with engine accesories (PS, AC) and how to delete what you don't want. Anyone know how to rig up just an alternator? Some of the other big ticket items will be the instrumentation (need to do something about the speedo and maybe tach). And you are also going to want a service manual for the engine, plus the $500 for tuning software if you plan any do it yourself. One last thing. The stock LS1-2 heads flow really well. Car mags build 500+ HP dyno engines with little more than a cam and valve spring upgrade. Don't know that new heads are such a "must have" upgrade.
Read that this morning. Pretty cool story. Got to hand it to those cops for sticking with it.
flyin miata chassis X brace...
Pop N Wood replied to olie05's topic in Brakes, Wheels, Suspension and Chassis
Nice pic of the torque arm on that Miata. May be overkill, but the thing looks to have some advantages. Looks to have built in subframe connectors, a protected channel for the fuel lines, and works as a driveshaft loop. Not sure how easy it is to get out of the way for maintenance (the fuel lines go under the thing) or what it would do to the ground clearance. -
Challenging the calibration on the radar happens ALL the time and usually doesn't work. But you still have an argument claiming reasonable doubt. A coworker just went through this with his wife. They admitted, like you did, that she was speeding, but claimed the 90+ MPH the cop was claiming was no where near the speed she was traveling. They were on a crowded freeway, the cop tagged them (on radar) when he was coming from the opposite direction. It took him 15 minutes to catch her. The judge eventually dismissed the charge on reasonable doubt when she convinced him there was probably 100 different things that could have caused the cop or the machine to make an error. Everybody was polite about it, so I think that helped. See if there are any doubts you can bring up. If nothing else just tell the judge what you said above and ask to have the ticket reduced. 90 MPH is going to be a pretty stiff fine so it is worth a shot. BTW, borrow a hand held GPS to check your speedo calibration. Speedo shops are expensive. If it is off, tell the judge as a result of this ticket you checked and fixed your speedo. Might make him think this was an anomaly and he might go easy on you.
Size difference between the BBC & SBC
Pop N Wood replied to a topic in Gen I & II Chevy V8 Tech Board
From what I have read hear, most BBC in a Z have hood clearance issues. Do a search. There have been some pretty good discussions on BBC in a Z from guys who have done it. -
I remember SPIIRIT. He deleted his member ship at a time when a bunch of guys were getting snotty about wasted bandwidth. I always wondered if that difficult period in HybridZ history didn't have something to do with his leaving.
LS1 guys - ?? about coolant line under TB
Pop N Wood replied to VinhZXT's topic in Gen III & IV Chevy V8Z Tech Board
So if I am following this thread correctly, you still need to have the coolant line in place, it just doesn't have to go through the TB? So VinhZXT will still need to find a place to T the line into? -
I just found the lamest thread on the net
Pop N Wood replied to TheNeedForZ's topic in Non Tech Board
What would every happen to people like that if they found out no one cares enough about them or what they do to bother spying on them? Guess that is the point where they start blowing things up just to get someone to hide from. Man, what a wasted life. Guess you can't be a failure if you never try. BTW, what the hell are you doing on a site like that in the first place? -
Get rid of the clown car sized 23" wheels, make the roof line proportional to the body height, don't emulate the dodge 300 series brick shaped body with square corners and keep the overall weight down around 2800#. Basically put the pig on Midol to get rid of that "bloated" feeling. For me, make it look like a Porshe Cayman S Saw one of those the other day and man, what a gorgeous car.
The good thing is I believe they all use the same bore. So maybe you don't need the whole engine, just the shorter stroke crank and rotating assembly.
New alternator mounting bracket for LT1
Pop N Wood replied to nazar's topic in Gen I & II Chevy V8 Tech Board
What timing. Check out zcarnut's response in post # 11 http://forums.hybridz.org/showthread.php?p=601398#post601398 So since you already flipped the alternator front to back, the reverse rotation should make the existing impeller blow in proper direction? -
Yes, that is exactly what he did, and even why he did it. Something about going around a circle track in one direction and wanting the engine torque pushing (I think) the inner wheel back down. I had a farmer friend claim he once reverse charged a battery on his tractor. So when he started it the diesel ran backwards. I don't know if it is possible to reverse charge a battery, but I do know a diesel is just as happy to run backwards as forwards.
I have an idea. Put spacers under the three bolts holding the bracket to the engine and mount the alternator facing backwards. That way the alternator will be in front of the belt. May have to flip that adjusting arm upside down and backwards also. Only problem I can see is the alternator will spin backwards. I think the electrical part will be OK, but not sure what will happen to the cooling flow with that impeller going backwards. -
Need some help on a NHRA Rollcage design
Pop N Wood replied to cyrus's topic in Brakes, Wheels, Suspension and Chassis
Man, no kidding. A stinkin bloated charger with a faux 2002 Camaro scoop. And GM is hurting not because of their performance car offerings, but because they can't compete with the Camary's, Civics and Minivans. I know it has been opinionated to death and that GM's quality is good nowadays, but it takes a long time to live down the rep they earned (right or wrong) in the 70's and 80's.
ohhh the temptation for a TT sbc
Pop N Wood replied to Psykovertible's topic in Gen I & II Chevy V8 Tech Board
Whew! those and another $15K and you will be half way there. -
1971 240z - Should i get it? (pics)
Pop N Wood replied to 240zV8's topic in Gen I & II Chevy V8 Tech Board
That T top looks like serious trouble to me. But if the dash is uncracked it is worth the $900 all by itself. Bring a screw driver and a magnet, poke all the floor boards, battery area and metal in front of and behind both wheels. Use the magnet to check for bondo in the areas in front of and behind the wheels. Open the hatch and check for rust on the rear deck. If all those things check out, then it is easily worth 3 to 4 times what you plan to offer. Still, I wonder what it would take to put the roof back together. -
I have lived all over the USA. The only place I have seen anything close to that (although not that bad) is my adoptive state of Maryland. I call it the Maryland merge. I watch the Maryland people closely. They come to a complete stop before they even attempt to check their mirrors or look over their sholder. What really drives me crazy is when they do it where the merge ramps opens up into a new, protected lane. I lived in California for years and only once did I see some one stop at the end of an on ramp. Myself and half a dozen other cars went on the sholder to go around the moron. I wonder if that dildo is still sitting in that same spot afraid to move, horrified by all the crazy CA drivers passing him by.
sub frame connectors....i searched
Pop N Wood replied to ZT-R's topic in Brakes, Wheels, Suspension and Chassis
Yes, they do have weld in kits. http://www.baddogparts.com/ Do a search. People have posted a pic of these installed and they look pretty good. -
The 240Z project car comes home tomorrow!
Pop N Wood replied to desert dog's topic in Gen I & II Chevy V8 Tech Board
That car is too nice to put on a rotisserie. That type of thing is usually done when replacing rusted floor panels. -
Harbor Freight may not have high quality dollies, but what they do have a wide selection of low cost casters http://order.harborfreight.com/EasyAsk/harborfreight/results.jsp I don't have any experience with car dollies, but I have made enough movable work benches and tool dollies to know wheel diameter is what makes all the difference in how easy somthing is to roll over a dirty shop floor. Get the 5", 330# swivel casters from HF for $5 each, weld together a rectangle of used 2" pipe from a salvage yard and you will have a custom fit set of 4 dollies for less than $100. Should handle 1200# each. Get a little more creative and you can make a bolt on attachment that connects to the lug nuts and allows the car to be moved without tires. Or better yet, I found some old shopping carts dumped in the woods. Would be easy to use those casters to make it a $20 project.
Hybrid Z :: While I'm at it....
That was one hell of a game. I still can't believe Texas won. I don't know if it was just the type of defense Texas chose to run, but USC has one hell of an offensive line. They were opening huge holes all night. Not many punts in that game.
Check out Phantom's posts. He is using the Z28 fans for exactly the reason you said. Plus he says the fans fit the stock radiators well.
