Pop N Wood
5
The one problem I would have with a 5.3 is none of them came with a manual transmission from the factory. Of course you could back fit everything to swap from an auto to manual, but seems like costs start to really mount when you do something like that. There is something to be said for getting everything you want in one package from the get go.
There should still be a return line from the surge tank to the big tank, so there should be fuel being circulated between the surge and main tank from the low pressure pump. If the HP return goes to the main tank, then the low pressure pump will have to have even more capacity to ensure the surge tank is alway kept full. Aren't you guys with turbos concerned about a lean condition causing something to detonate and melt?
Somewhat bummed at 450RWHP, 500+rw torque
Pop N Wood replied to silicone boy's topic in Gen I & II Chevy V8 Tech Board
Don't know that I will argue with what has been said, but I do know WWII aircraft used variable speed superchargers to compensate for altitude. At higher altitudes you can spin the blowers faster to maintain boost pressure without the risk of detonation. Certain models were actually tuned to work best at different altitude bands, and tended to be dogs when operated at the wrong altitude-. So I guess I take exception to some of the statements made above. Take a forced induction engine designed to work at sea level, bring it to altitude and change the blower/turbo configuration and you might get back to your sea level power. Perhaps a more accurate way to state it is a forced induction engine can be retuned to maintain power with altitude whereas a N/A engine has limited ability to compensate for changes due to altitude. -
What strut inserts come with the AZC assemblies? That will have a lot to do with what spring rates you run. Give Dave a call at AZC. I am sure he can recommend the appropriate struts and spring rates for what you want to do. For the amount of money you will be sending his way, I am sure he will be glad to talk to you. BTW, forget using a line lock as a parking brake. They simply do not work in that capacity. You will really only need one if you plan to drag race.
There is such a thing a volumetric efficiency. If you drastically alter your intake flow velocities at cruise, then it most certainly can and will affect your cruise economy. Think of replacing a dual plane manifold with a high rise single plane. You (might) get more power potential at high RPM due to the better flow capacity, but this can often come at the cost of low RPM performance. I personally have no experience with that type of engine and have even less idea what changing the MAF will do to the low RPM flow. But the idea that the engine is pulling the same load and turning the same RPM, therefore it must be flowing the same CFM of air is not a correct assumption. And if your EFI is working correctly, the gas is proportional to the air flow, so the answer lies in what happens to the air flow.
Looks like something Wile E Coyote would drive. Can't imagine getting a safety inspection for that thing.
Supose another option would be to drive sanely until your record clears up. But don't suppose that will happen. You guys have an insane amount of faith in what lawyers can do. Most yellow page lawyers will be glad to take your fees then file the same paper work, and get the same fine, you could do yourself. I have seen it happen.
Getting rid of the rubber steering coupler was one of the best mods I did to my car. Vibration is really not an issue. Did it 18 years ago and no cracks or steering failures to date. Nissan used waaayyyy too much rubber in the front end. I have seen on this site many ways to get rid of the coupler. Probably the best was just bolting (or welding) the two halves directly to each other with nothing inbetween. One Canadian member actually drilled out a hockey puck and used that.
Gorgeous. What size wheels and tires are those?
I got in a fight tonight over FI vrs Carb.....
Pop N Wood replied to 240ZR's topic in Non Tech Board
Here is a good thread referencing an article where they dynoed a FI LS engine, then swapped in a carb and dynoed it again. http://forums.hybridz.org/showthread.php?t=106275&highlight=500 Like the guys said above, in the controlled environment of a dyno room you can dial in a carb to do pretty well. Throw it into the real world with bad gas, humid days, high altitude and the carbs needs to be manually retuned. Saw a thing on Monster trucks the other day and they said FI is what made the trucks real. All that bouncing around and free flight would make the carbs go bonkers whereas FI keeps the engine reving. Want a sense of history on this? Read some aviation books debating the differences in the fuel injected DB-109 and the carbed Spitfires used in the battle of Britian. -
I have those for my stock ride height 240. Unfortunately no pics right now. But without lowering they don't do a very good job of filling the wheel wells. Unfortunately no pics are readily available so hope someone comes in with some. BTW, people are saying tires in that size are getting increasingly more difficult to find. What brand of tire do you plan to run? My current tires have been sitting unused for 15 years so I need some new rubber.
Check with your local crack head. People huff that crap all the time. Home Depot carries in gallon tins.
oh no... i think i might get banned for saying this..
Pop N Wood replied to a topic in Non Tech Board
If that yellow scion didn't get you banned I can't see how a Honda will. -
Unfortunately someone beat you to that idea http://www.toyota.com/prius/index.html?s_van=GM_TN_PRIUS_INDEX
HEADS UP On CHEAP CAR TRAILER In Atlanta GA!
Pop N Wood replied to Mikelly's topic in Non Tech Board
Not sure what this means. I guess nuns never go down so don't try haggling on price? -
Not to disrespect anyone, but I would gladly pay a few grand more for a V8Z than an inline turbo one. In fact, I would be afraid to buy a used turbo car from some motor head. Much more complicated and many more things (expensive things) that could be wrong. Plus IMO V8Z's are more unigue than a turbo Z. They kind of bridge both worlds of old school hot rods and small imports. But that is just my opinion.
For $900 leave the magnet at home and buy that sucker. Now. Stop thinking and do it. That thing has straight bumpers and you can't see the steering wheel from underneath the car. Good find. I have a 12/70 240 and I have the exact same bit of broken bondo on the rear valence. Some drunk kid on motorcyle slid underneath my Z and exposed the damage with his helmet. Probably got bumped from the rear at some time in the past. The ding on your car is right under the bumper mount and you can see the slight crease in the bumper. The rear valence is not structural, so don't worry about "the frame". And yes, that frame rail, such as it is, is perfectly straight. Mine looks like the ocean on a windy day from my misguided attempts to use them to jack up the car. They straighten as easily as they bend. Your only worry is rust, which that car doesn't seem to have.
I think it has more to do with the application then anything to do with physics. If you are building a tow vehicle, you want low end torque. That means long intake runners, no overlap cams, long stroke, etc. And often times those type of cars, which aren't worried about engine height and length, get an inline 6. If you build a performance car, you want more cylinders lower to the ground and more high end HP.
Do you know that for a fact? Every car loan I have ever had there is no penalty for paying the loan off early. You need to call them and ask them if there is a penalty for ealy payment. Should be a one word answer. And if all you want is a shorter term, then you shouldn't need to refinance to do that. Just pay on the loan as though it is a 4 or 5 year loan and you will pay off the car in 4 or 5 years. Simple as that.
Help: Need John's Cars motor mount photos
Pop N Wood replied to 231Z's topic in Gen III & IV Chevy V8Z Tech Board
That kind of sucks. Isn't his trans mount like the JTR type and just a bar that bolts to the sheet metal floor pans? I was hoping to fab some stock looking mounts. But I guess i wan't planning on using his driveshaft anyway, so not sure what else he would have that i would need. -
Somebody be Kind Since I am Trying To Avoid The Obvious
Pop N Wood replied to a topic in Gen I & II Chevy V8 Tech Board
Damn. Take the effluent from that gasoline cocktail, put it in a drum in the back of a Ryder truck and park it out in front of a federal building somewhere! -
500 ft-lbs of rear wheel torque with a N/A 350? I cry BS. Show us some build specs and a dyno chart. Is it just me, or does having that much more torque than HP tell anyone else what potential there is in that motor?
