daddydonuts
Everything posted by daddydonuts
  1. I pushed the piston all the way in and it does not even come close to the clutch fork, and when I bleed it, the piston comes all the way out...makes me think my clutch fork is bent or I have the wrong type of slave. 73 240Z 4 speed
  2. What causes the slave to come all the way out of the bore when I push in my clutch pedal? System is bled, pedal is adjusted within tolerance according to the FSM. I bought a NAPA brand slave and have maybe 20 miles on it.
  3. I'm using a MSA comp gasket with a ton of RTV, no leaks yet, but I haven't driven it hard yet.
  4. Yes, it was more to ship it to me than the cost of the gasket. The fel pro looks just as good for a third of the cost. I guess I will just RTV a cork one...they seem to stay together when compressed
  5. Well I just removed my front cover to replace the timing chain and of course my gasket ripped during removal, I put RTV on it and no leaks so far except the rear corner that was already leaking
  6. What has everyone had the better luck with on a L28 oil pan gasket? I've had no luck with the cork and MSA one's.
  7. Anyone have a fuel supply line for SU's? I dont care for the stock ones. Thanks
  8. I bought the eBay seat covers for mine with the Z logo and white embroidered stitching and they are very good quality. I have not installed them yet so I can't say anything on how they fit.
  9. They are solid...but I do need to remove it to prevent any rust...thanks for the advice
  10. It's still the original color from the factory. I am going to remove the insulation then treat it.
  11. If it doesn't hurt to leave the insulation on the floor pans and paint over it, I am going that route. I just don't want to create a place for rust to live under that insulation.
  12. I live in GA, lots of humidity.
  13. That I could do. Would it be wise to either leave the insulation in place and paint over it? Or just remove it?
  14. Looks great. I used the eBay white face set with the blue lights and it made mine look pretty sick.
  15. I have mint floor boards in my 73, but I am having the bright idea to use POR-15 to better protect them prior to installing new carpet. How or what is the easiest way to remove the insulation, that I am guessing, was installed from the factory?
  16. Started getting everything out of the way to install the turbo motor.
  17. I have an 83 manual Turbo ECU. Will an automatic ECU work with a manual setup? 82-82 ECU should be the same, just not sure of the auto or manual trans.
  18. My hometown, I bet one of my old Z's could be rusting away there. http://tricities.craigslist.org/pts/4128911253.html
  19. If you got one Jamal hook him up. I got one here somewhere. Dave
