Ben280
    26
Everything posted by Ben280
  1. Now you're talkin'! New motor arrived home today. L33, but not the L33 you might be thinking! The truck oil pan and intake are HUGE, we will be replacing those, along with most of the other stuff. Nice to have a solid, running/driving baseline. The yard I got it from supplied hot compression numbers, (165psi) so the bottom end should be solid enough for now. I'll pop most of these accessories off, take a look at the heads, and probably send them out to be cleaned up. Still need to order the bellhousing kit, I'm getting a bit hung up on the reverse mount starter and getting enough trans tunnel clearance.
  2. Haha! I'm all for a discussion about important race related matters such as oil pressure. I might be unhappy to be the catalyst for such discussions, but not disappointed to host them in my build thread. I've started working on the wiring harness. I have a friend who builds some really spectacular stuff for prototype cars, and offered to help me get a new engine and chassis harness sorted out for this car. We are trying to do it right, and he's managed to score some pretty serious hardware for me. We are using a Motec PDM32 which is all autosport connectors. One thing has lead to another, and he might be going a bit wild on the construction with the twisting and sheathing. This is all going to look hilarious next to my Megasquirt ECU (rebranded as a Notec from here on out!)
  3. Latest and greatest update. Moving on from the Koni/GC combo finally. I worked with Jonathan at Shaftworks to build some custom dimensioned struts for the car. The fronts have S13 mounting dimensions (which I built my front uprights to accept) and the rear are 2002-2005 WRX. I'll probably have to put some serious work into the rear T3 knuckles to accept that fit, but we'll see.
  4. The Z (with higher RPM) would just hit 130 on the front straight. The video I posted is WOT until the 2 cone marker, and just hitting that marker. With more power and less gear, I'd probably be pinging rev limiter until the brakezone. Most modern high performance cars cars are getting 140-150. The 800hp Viper that holds the production record there tagged 171 on the front straight, and camero ZL1-1LE's will get to about 150. No interest in Pacific, but the COTNW in Bremerton looks really interesting! I like the idea of running dual sensors @tube80z, you'll hear a lot of radio chatter about failing out sensors. It's also just good practice to get good sensors, and keep tabs on em! Intermittent electrical issues are the worst! With the swap, I'm going to be re-wiring the front half of the car. Prior to my motor exploding, I'd gotten my hands on a Motec C125 dash and a PDM30. Need some other accessories, but this seems like a real good time to get them installed!
  5. I have a long nose 3.90 in the car, and a 1:1 4th in the Jerico. That pegs top speed at 126 with an assumed 6500rpm rev limiter. I might start hunting for a 3.54 short nose diff, since that would bring my top speed up 13mph, and I could likely widen up my ratios. First gear is pretty tall on account of the L having a narrow powerband, and trying to keep the drop small from 3rd to 4th. @clarkspeedInteresting idea. Maybe it develops internal weakness that come out at high RPMs? I tried to be pretty nice about getting the car hot before hitting the track, but maybe I missed the mark a few times. Tough to say, and it wasn't something that I thought to keep an eye on. When I had the motor apart last year, I didn't notice anything weird about that area.
  6. Hey! That bodes well for the resale value of my Hoke trigger kit then! There's a fair bit of play in mine. I wasn't doing anything fancy with the shaft placement, apart from using the later KA truck oil pump for a bit more oiling. As far as I've been able to tell, they are essentially the same casting, just different springs. It would be interesting to know, although I think I've since binned the pump. Worm drive, sprocket and camshaft are going on the altar to the Gods of Speed in the new shop.
  7. Particularly good shot of the car climbing the hill into T11 at the Ridge at GTA '22
  8. I don't really know what caused the oil pump gear to fail here. I was using the correct crank snout gear, or so I thought, but clearly that still failed. My one thought is that because I'm using a Hoke crank trigger kit, that somehow the shaft was able to shift laterally on the snout gear? There is a bit of movement there, but I assume the distributor would hold it more or less in place. Clearly with a distributor, once this drive gear failed, the motor would shut off on account of erratic spark. With the crank trigger kit, it was all too happy to keep running. Shame on me for not wiring the pressure switch into the ECU with a safety strategy. @tube80z, Didn't really look into the v6 stuff. My goal was to keep it straightforward and easy, so the LS family ticks that box for sure. The L33 is all aluminum, so it should serve to keep the weight down a bit. Drop in ready for a lot of my existing parts, or easy to get parts as well. Now to decide what to do with all my L series parts. Sit on 'em or sell?
  9. @clarkspeedAsk and you shall receive! I'm still not very good at taking photos as I go. Dirty hands and not wanting to touch the phone I suppose. We're going back to June 2021 here. Pic of the car after it chucked a rocker at ORP. Where'd the rocker go? Not that much carnage all things considered. Just a little peck on the cheek Back together, placed 3rd in Unlimited at GTA at the Ridge. (1:52.8) 2022 season prep starts with needing to get engine temps under control. Howe racing radiator and Setrab oil cooler should do something cool. Apex Engineered sent me a strut bar to chop up, since theirs didn't work with camber plates. New radiator means I can get rid of the inner fender wells and lean the radiator down at a pretty good angle. Helps with airflow, and eventually I'll duct it out the hood. Starting to plan for mounting a fairly massive splitter on the front of the car Big rear wing to match. Zebulon MSC design 14" chord. Splitter mounted, need to duct air into the radiator somehow. After watching a few cars burn down at events in early '22, I decided to invest in a suppression system This is a 2.25kg Novec system. GTA 2022 went well until it didn't. Coasted in on a cooldown lap after seeing a goose egg for oil PSI. Got home and parts were still hot after sitting for 6 hours... That Cam looks pretty dry. I think that piece should still be attached! The culprit!
  10. I figure with the dogbox, a button clutch should make for an excellent experience. I do need to upgrade my winch with this plan, but I think the performance might be worth it. Looking at the quartermaster 7.5" for now, but also considering a 10" for more "drivability".
  11. My buddy who runs Aerowolf made a pretty sick youtube video as well of the mods I made to the car over winter. I'll try and do a photo dump shortly, but this is a pretty overview of what happened, along with a medium speed lap at PIR to close out.
  12. Here's a video of the car from the session before the oil pump gave up. I would have really liked to take the car sub 50 before more power, but alas, not to be. Aiming for .45's with more power and better (fresh) tires.
  13. Man, I'm bad at updating this thread. Maybe since I hate facebook and instagram is losing its charm, I'll start posting here more. Long story short, we went road racing, and my Rebello is no more. Oil pump gear failure roasted the camshaft. While I think the L series is an excellent motor, and I've enjoyed the past 6 years with it in the car, the need for more power and not an unlimited budget/timeline to get this thing back up and running means we are going V8 in the full spirit of HybridZ. An Apex Engineered LS subframe and a junkyard L33 are on the way. I've got a few things to get for connecting the trans to the motor, but luckily, having a Jerico makes this much easier! To button clutch, or not, that is the question. Also investigating headers. Ohm says the CX Racing long tubes work nicely, I haven't been able to find any photos of how they sit. The car isn't as low as it once was, but I don't like when headers are the lowest part of the car.
  14. It's important when ducting the radiator like this to make sure you blank off the sides as well, such that the only place for air to go when it gets to the front of the car is through the radiator.
  15. ZCG's numbers show it's certainly no slouch, although I wonder if with some compression and ethanol this would support 400whp+.....
  16. I'm right at the crossroads of what do I do with my L series for time attack/road race use. Swapping for a V8 has appeal, but I just saw the post on Z car garage, and, well. Time to investigate! This is really an incredible project Derek.
  17. 15x7, depending on the offset will be the limiting factor for things like the bumpsteer spacer (too thick and the tie rod will hit the wheel barrel). A quick steer knuckle can help here, since it brings the tie-rod closer to the car centerline, but for a EP/ITS car, I'm not 100% convinced you need fast knuckles. Auto-x, yes, track car, not sure. That bushing looks like a way to adjust the trackwidth/roll center without going to heims, as limited by class rules. Tube arms and heims are tube arms and heims. Go with the ones that tickle your fancy and go from there. I think the Apex rear tube arms have some distinct advantages over the T3 rear tube arms, but unless you can change the inboard mount, that's gonna be your weak point IMO. Keep one eye on the rule book here, you don't want to go spending money that boots you out of the class you want to be in.
  18. Quite the fleet! We've got a 1987 BMW 325e (AKA Garbage heap), my 1997 12v Ram 2500, a 20' enclosed and my wife's tesla out front. So a similar hodgepodge of junk. The Z lives in a 1946 2 car garage, so a root cellar with a wine nook haha. I'll be sure to post up when I make it down to the Willow area, see if some of you Cali folks want to come make a day of it!
  19. Are you North or South? If North.... Well, you got room for a truck and trailer? Hehe. I know a bunch of the endurance racing guys go down there in march for the season kick off event, and most of the time don't have issues. NIMBY's are clearly the worst, and I think the track has had it's own management issues over the years. Certainly something to look into tho, would be a lot of fun to do a few California trips!
  20. Big Willow/Streets of Willow would be a blast, but 15+ hours towing. Laguna has a lot of cool points, but yes, the sound restrictions do seem goofy. Probably better to do it now before this motor gets swapped out for something louder! Maybe late this year I'll make the trip to Willow, there were a couple friends who made that trip already this year. It would be interesting to see how it stacks up against the late great John Coffey.
  21. Would love to get down to Thunderhill! Didn't realize Sonoma was relatively close, any others worth visiting in the Bay area?
  22. Turn2 Lapping day at the Ridge Motorsport Park up in Shelton Washington. Practice day for the Global Time Attack event happening in late July, where I'll be losing in the Unlimited category haha! I'd like to get into the 1:50 flat territory, and maybe with some bravery and more aggressive shifting I can make it happen. Aero cars can go sub 1:50, but I need more power to get that quick. One day I'll remember to invert the Y axis on my datalogger, but for now, you'll just have to enjoy the backwards version! Thanks Jon!! Getting more confident.
  23. Another weekend, another day at the track!
  24. Marugen Shokai http://home.att.ne.jp/sky/FairladyZ/ Can also get them from RHDJapan: https://www.rhdjapan.com/marugen-shoukai-works-over-fenders-standard-type-s30-s31.html Designed for a front G nose car, so lots of modifications needed to make em fit a standard car with or without an airdam.
