26
Everything posted by Ben280
Sounds about perfect for what I'm after. The DTC's are ok, but wear like junk and are about as abrasive as 60 grit sandpaper. I've got Wilwood calipers front and rear, so a fairly common pad shape. Might look to upgrade as I start adding aero since I'm using rather small calipers. Only reason to upgrade there would be a thicker rotor, but I'm using a 12x.81" rotor up front. Rears are rather thin and after their visit to the track turned mostly blue haha!
I figure if I can get the car to feel really nice for 2-3 hot laps in a row, that's about all I need for a time trial type event. There's a fine line for me between going fast and burning the car down during a 20 minute session. I've tried Hawk Blacks, and they were pretty good, but I like the bite and modularity of the DTC-30s more. I might try the DTC-60's but I've also heard that Hawk has been left in the dust technology wise by other companies at this point, and the torque their pad compounds can put out just are nowhere near what other tech can do. Need to research this more, but I've heard enough to be interested. I'll note too that the Hawk Black brake dust is about the most corrosive thing I've ever seen. Don't even think about getting it wet or it will permanently bond and etch into aluminum.
Just cooked the pads and got some serious heat into the system. No brake cooling to speak of, which with wheels this small and wide is a real problem. The pedal felt alright, but the brake feel just didn't instill the confidence I wanted. I need to do some research and probably some testing to find something that I like. Water and Oil temps were a bigger problem, I could get about 3 hot laps before temps were too high.
Getting back to racing, and had a couple of events already. First up was SCCA Time Trials National Tour at The Ridge Motorsports Park up in Shelton Washington. First time at that track, and first time on track in about 6 years, so I wasn't about to light the world on fire, but I managed to go sub 2 minutes, which was the goal for the weekend. I did swap out my lightweight autox front hub arrangement (T3 aluminum hubs, custom hats and scalloped rotors) in favor of a full vented rotor and OEM steel hubs. Figured additional thermal mass would be good, and I was right. Still need to work on brake cooling, and cooling in general for future events. My auto-x gearing meant that I was on the limiter in 4th for a good chunk on the front straight. When I go back, I'll likely swap out some of the trans gears to try and optimize those ratios. Anyway, video here: This past weekend was back to Auto-x, so I swapped out the front hubs, swapped back the brake compounds, replaced a corded front tire, and went racin! I was using the usual Hawk DTC-30 on the track, but have been messing around with the Hawk HP+ pads for auto-x, hoping for a bit less need for warm-up. Well the HP+ suck, and I'm throwing them in the garbage tomorrow! Just really numb, bad release, and no real initial bite. It was also fairly cold, and my tires were having issues getting up to temp, I've been really thinking about switching up a couple things in the car after August, so wheels and tires might make the list. Anyway, best time from Sunday, when we finally got the tire to be over ambient temp! Reasonable time, but should have been 3 seconds or so faster on this course. Always more work to do!
New Techno Toy Tuning Micro Rear Brake kit
Ben280 replied to Miles's topic in Brakes, Wheels, Suspension and Chassis
I feel like these wild mish-mash collections of parts are from people looking to convenience over a proper engineered solution. Brakes need to be viewed as a cohesive F-R system, I'm surprised that more companies haven't taken the example from Z car garage (and really everyone else) and offers a full brake system. It's not witchcraft, unless you're trying to use maxima rear brackets and stuff you can find at pick n pull Lots of talk here lately about a need for documentation. Is this a new concern? I feel like nobody has offered it really in the past 10 years, so what's spurring this now? -
Makes sense now, I was trying to imagine how this would work with the factory rear uprights! Watch your roll center as 260DET said, you can easily get into trouble and the car will behave terribly. Since you're already welding in camber plates, good enough time to add some reinforcement up there, although I think if you try and get too vertical, you'll start hitting your springs on the inside of the shock towers.
Thanks for posting! Cool to see some of the principles of intake tuning in action, namely, longer runners pushing the powerband lower at the expense of total HP, the 205mm had the earliest power spike with a lower overall number! Good stuff to keep in mind when looking at intakes for triple carbs and ITB's!
Progress on my insane VQ35HR 240Z project
Ben280 replied to markrolston@mac.com's topic in Nissan V6 Forum
Just when I thought this build couldn't get any cooler, you throw Motec and a dang HGT box at it!? -
Cool! For some reason I thought you got a 550. Should make it easy for troubleshooting!
@DuffyMahoneyHow are your injectors wired into the ECU? If i'm not mistaken there are only 4 injector drivers on the haltech board. Are you running 2 batches of 3 injectors? I seem to remember from a few pages back you got a CAS dizzy piece so you'd have a cam signal heading to the ECU for a more sequential system.
Haltech's are a bit different than the MS3 I use, but the injector timing sounds to be fairly out of joint from Duffy's video. If the crank sensor is bad, inconsistent or just something the computer can't figure out, the MS would either not start, or show errors in the Sync gauge. I doubt the Haltech would try an muddle through a bad cranking trigger. I the trigger and home wires are also shielded bundles in the Haltech wiring harness, so unless Duffy isn't using those, noise shouldn't be an issue either. Injectors are behaving badly at a minimum, I'm interested to hear what the report on them is!
Wilwood proportioning Valve
Ben280 replied to grannyknot's topic in Brakes, Wheels, Suspension and Chassis
It sounds to me like Madkaw has a prop valve installed in the rear circuit, and has it dialed all the way down. You can only "bias" a dual master cylinder system, otherwise you are proportioning the amount of force to the rear. This would be mostly in line with what OP had to do. Would be helpful to know the model Wilwoods you are using, as saying you are running Wilwoods all around is just like saying "I run calipers all around". If you know the MC size and the size of your pistons in the caliper, you can do some pretty simple math to tell you where you should be, and how much prop valve you need to throw at it. -
That sounds to me like a few injectors are just going fully open above 1300rpm. I'll be interested to hear what the injector lab place says about them. Were you logging data on the ECU? Should be reasonably easy to see if you had trigger errors or a bad sensor. Good thing to check, but I don't think it's the root cause of your issue here. Another thing would be to try installing a dummy injector and see if you can run through the test modes on the ECU to confirm the ECU is at least sending a good command.
The erratic crank angle signal that would make the injectors that out of whack would result in a no-start condition on an ECU like the Haltech. My money is on the windings in the injectors. ECU might be the issue, but the voltage requirements of a low impedance injector should be within what is possible from the Haltech. Also, just to address some of the statements earlier, the Low/High resistance is a bit of a misnomer. The low impedance injectors, also called "Peak Hold" have a much higher opening voltage, and keep the injector at a base voltage while running. They'll send the injector a 2-4v signal, then sit at 1-2v. High Impedance injectors, also called "Saturated" are a simple on-off signal, at 0.5-1v. Hence how a "High" injector can be overpowered and burnt out by a "Low" signal.
If you want to go racing, go Koni 8610/8611 inserts or MCS. You wallet will be a little sadder in the short term, but you'll be getting a quality product. I've used AZC, they are nothing to write home about, and I saw a HUGE improvement moving to the Koni inserts. Likely the same basic product as the BC, Megan, Tein, Feal etc. A full Koni setup should be a similar price to the AZC stuff.
Interested on how you plan to do this.
Makes sense with how Edan recommended the the caliper situation. Good data for people with the stock brake setups. -
Nice work!! That ratio works out nicely with the piston sizing you have. That's some valuable data you've collected as well about the prop valve, thanks for posting that here. -
Oh nice! Those will be helpful to tune in the bias. I've seen some gauges that go in between the pads and measure clamp force at the caliper, but haven't used one before. Good luck!! -
Depending on what is left in the factory system for the rear circuit, it might be alright. Drum rears use a lot less pressure than calipers, which might be why the rears seem to be oversized. Worth looking into more before cutting in the prop valve. I don't THINK Edan would flat out lie to you, but he might have made some assumptions about what you have going on. Also, it would be worth verifying based on the Wilwood boxes/part numbers your piston size, as the numbers listed on the Silvermine site don't correlate with the numbers on the Wilwood site. But parts change and I'm relying on photos that might be out of date! -
Sorry, I know you didn't come here asking about your brake ratios, but the links you posted got me curious. I went through a similar sizing adventure, although I am able to use different sized master cylinders to solve my bias issues. -
Ahh ok. You've got WAY too much rear brake. The front pistons are a bit of a mis-matched for the size of the rear pistons, fronts are small, rears are large, relatively speaking. Since the MC equally powers both brake circuits, the clamping force at the rear is higher due to the increased piston area. If you have any of the factory stuff in the brake circuits, this will alter your results. Right now, based off Wilwood's numbers for the Superlite front (4x 1.12" pistons) and the Dynapro rear (4x 1.38" pistons) you have a 60% rear bias. Ideally that would be flipped. If you max out that prop valve and cut the rear pressure in half, you'll end up with a 56% front bias. Couple links included below for further reading on the exciting world of brake pressure math! https://www.tceperformanceproducts.com/bias-calculator/ https://www.joesracing.com/master-cylinder-math/ -
I can tell you off the bat that you're going to need some serious help to get the rears to come in line, and even with a dual master setup, you might always have a rear bias with this setup. What master cylinder(s) are you using? On edit: You've linked two rear kits. What front kit did you get? -
Hmmm interesting. From racing Z's for a number of years now, I think the idea that the mustache bar + diff mount will transmit a dramatic amount of lateral load under cornering is overblown. I'm sure there is some, and some FEA could probably tell us to a certain degree of certainty, but I'm also sure that there is a huge amount of flex in the rear of these cars from the factory. Once you start tossing V8's and big tires at these cars, all bets are off. I take a lot of reference from how the cars that these parts come out of are used. The S550 Mustang for example from the factory has bushings inset into the front of the diff, and the rear rides in another set of bushings. There are a number of kits for people who track the cars to solid mount the diff (aluminum bushings for the front and rear). A local autox friend of mine has this upgrade in his 2017 Mustang and is making about 850hp. No cracked diffs yet! Good points tho!! This is one of the more radical mods for the rear of the Z car, I'm excited to discuss and see if the community can improve it for V2!
So far the one event we've been able to run was a blast! Need to get used to it. Clutchless shifting is weird, but much faster. I'll have to see if I can find some RPM traces to illustrate. A bit advantage of this box was I get to select ratios. At the moment, it's geared for higher speeds, so a bit of a long first/second. Makes it tough in the little lot we were in, could have probably screamed around in just first gear. More strength, ability to swap gear ratios pretty easily, easy to R&R, and a teensy bit lighter. It is still in a H pattern (Jerico WC-4 if you want to go look at their website), but we aren't allowed to run sequentials is this class anyway. The springs for the 2-3 shift are crazy strong, I don't think there's much advantage to sequential at least for the upshifts here.
