42
Everything posted by 74_5.0L_Z
You could try making your own cross-member like I did. The other thing that you can do is move the whole cross-member forward so that the engine drops in behind. This will also add caster and require custom T/C rods. crossmember.pdf
280z 1975 Steerin Rack Rebuild Question
74_5.0L_Z replied to BMAC's topic in S30 Series - 240z, 260z, 280z
https://www.classiczcars.com/forums/topic/48621-steering-rack-disassembly-and-refurb/?&page=4#comments- 1 reply
- 1
Drivetrain offset from centerline?
74_5.0L_Z replied to fusion's topic in S30 Series - 240z, 260z, 280z
It is offset toward the passenger side (I think the offset is about 3/4"). Duplicate that as much as possible to minimize driveshaft angle as seen from above. -
My posts in the thread above show the fitment.
The dimensions for the bar above were for an S30. The original installation was in a 1974 260Z.
Dual Ball Joint Strut Modification
74_5.0L_Z replied to JMortensen's topic in Brakes, Wheels, Suspension and Chassis
I think you would be better off creating an SLA front suspension rather than the double ball joint set-up. Alternatively, have you considered putting narrower front wheels / tire on the car and using longer lower control arms to push them out to the width of your fenders. You would of course have to relocate the top of the strut outboard by a distance similar to the added length of the lower control arms. The factory LCA is ~11.3 long center to center. You currently have 15x14 wheels with essentially a 4" backspace. I would go to a 15 x 11 with a 5.5 inch backspace and make some LCAs about 16 inches center to center. Which ever avenue you pursue, I am watching eagerly and would be willing to provide any help I am able.- 38 replies
- dual ball joint
- scrub radius
- (and 7 more)
I used the gorilla lugs for several years (black 7075 aluminum) and had no problem. I used P/N 44037B because I have replaced all of my wheel studs with M12 x 1.5 ARP. If you have stock wheel studs then you need M12 x 1.25 threads. However, when I started doing track days I bought a good set of steel lugs.
More Caster With Power Steering?
74_5.0L_Z replied to socorob's topic in Brakes, Wheels, Suspension and Chassis
Unfortunately, it is really hard to get more than about 5 degrees on an S30 without major modifications. I'm at about 6.5 degrees and I have moved my cross-member forward and the top of the struts backward. Yes you do get benefit from the effort. Just know that there is a lot involved in getting it right. This is what 6.5 degrees looks like in side view. -
For a street driven car, I would say dial in as much caster as possible without having clearance or binding problems. Unfortunately, adding caster is difficult to do correctly. If you add caster by lengthening the T/C rod then you have to have spherical bearings at the LCA to cross-member connection to avoid binding. You have to push the lower ball joint forward 1.25 " to get 6.4 degrees of caster. Because the LCA attachment to the cross-member is fixed, the LCA becomes angled forward pretty significantly as seen from above (See attached image). I used to set the car up with the control arms angled forward, but that causes other issues. The angled LCA causes loss of static camber. With camber plates you can compensate, but that is a band-aid. Another issue to deal with when you angle the arm forward is clearance between the tire and frame and tire and forward section of fender. Again, things that can be dealt with but have to be considered. In my current set-up, I moved the top of the strut back 3/4", lengthened the T/C rod to move the lower ball joint forward ~.5 inches, and made a cross-member that relocates the LCA attach point forward so that the LCA is perpendicular to the chassis center line at my desired caster. -
I think there are a lot of variables. The factory ALWAYS designs cars to understeer at the limit. That means that they always want the front suspension to reach its traction limit before the rear. Many newer sports cars have an SLA front suspension and a strut rear suspension, or they have struts at all four corners with tons of front caster. The SLA will almost always have more camber gain than a strut set-up, so the designers may be adding rear camber so that the rear will be optimized relative to the front at the lateral limit. Likewise, the newer front strut designs utilize a ton of caster compared to older designs. The added caster adds camber gain to the front wheels as steering angle is applied. So again, the rear needs added camber to match the front when both ends are near their limit of traction. The S30 is different than the newer designs (at least in stock form). The rear struts have more camber gain than the front (the fronts have about .5 degrees per inch of travel, and the rear have about 0.75 degrees per in of travel). You can see this on a lowered Z with stock suspension: The rear gains a lot of negative camber, but the front gains very little. Also, the stock front caster is really low compared to newer designs (<3 degrees), so there is no camber gain as the wheel is turned. If you add significant caster to the front of an S30 (>6 degrees), then you get the benefits of camber gain as the wheel is turned. You can then run less static camber, and you can run almost equal camber front and rear. I run 6.5 degrees caster and -1.8 degrees camber up front. I run -1.5 degrees camber in the rear. -
22mm front sway bar
74_5.0L_Z replied to 74_5.0L_Z's topic in Brakes, Wheels, Suspension and Chassis
Thanks for the info. If I could time warp back to 1982, I could go buy one. It would be nice to find one someone has laying around. -
I am looking for a 22 mm front sway bar. The bar can be originally intended for the S30 or from something else as long as it is compatible. I may have to modify it regardless.
Does anyone know of a readily available 22mm sway bar that fits the S30? I already have 18 mm, 20 mm, and 25.4 mm sway bars. I currently have the 20 mm bar installed and would like to add a little more front roll stiffness without adding additional spring rate. I know from previous use the 25.4 mm bar is too stiff for my needs.
Stance coilover kit, front woes :(
74_5.0L_Z replied to sileightygx's topic in Brakes, Wheels, Suspension and Chassis
Is the drivetrain (engine/transmission) installed? It will ride high if there is no weight in the front. -
Here is a good link that covers the gear ratios and rated torque capacity of the mustang T5. http://www.allfordmustangs.com/Detailed/349.shtml You will notice that all the T5s for the 3.8 V6 were rated at 265 lb-ft of torque while the V8 World Class T5s were rated at 300 to 330 lb-ft. If you go with the GForce or Astro Performance gears and shafts then you can get 500+ lb-ft of torque capacity. Also the V6 T5s have the crappy 3.35 to 1 1st gear.
You need the V8 version period. At a minimum, you should get the T5Z transmission. You can buy them new or get a good one from Astro Performance. For the Z car, gear ratio selection is paramount to making a fun driving car. When I first built my car(circa 2001), I used a stock T5 from a Mustang police car and it had the following gear ratios: 1st: 3.35 to 1 2nd: 1.99 to 1 3rd: 1.33 to 1 4th: 1 to 1 5th: 0.67 to 1 It held up decently behind a stock 5.0L, but I hated 1st gear. At the time I had a 3.54 rear gear and ran 24.7 tall tires, but 1st was uselessly short. In street driving, I just generally started off in second gear. Later when I upgraded to a 331 stroker making 400 hp / 400 tq at the wheels, the stock T5 died a very quick death (during an autocross I sheared all of the teeth off second gear coming off a corner). When I pulled the transmission I discovered that I had also twisted the input shaft and output shaft as well as the stock slip yoke. So, I upgraded to Gforce gears and shafts. At the time I was only autocrossing, so I opted for the stock fifth gear. The new gear ratios were as follows: 1st: 2.94 to 1 2nd: 1.94 to 1 3rd: 1.33 to 1 4th: 1 to 1 5th: 0.59 to 1 I really liked the new 1st gear, especially with the new 3.36 rear end that I installed at about the same time. Unfortunately, when I started doing track days instead of autocross, I really hated 5th gear. The 4 to 5 shift dropped the rpms way too much and totally killed acceleration. So I pulled the transmission and installed the S80 fifth gear set from Modern Driveline (0.80 to 1). I now really love fifth gear. It pulls like a freight train all the way to redline in fifth now, but it might not be a good choice for a street car. My recommendation is this: If you plan to build any significant power then pony up for an Astro Performance A5 with the following gear ratios: 1st: 2.94 to 1 2nd: 1.94 to 1 3rd: 1.33 to 1 4th: 1 to 1 5th: 0.80 to 1 Be aware that the GForce and AstroPerformance T5s use a 26 spline input shaft and will require a different clutch disk. The stock input shaft is a 10 spline.
300 ZX Turbo CV shaft disassembly and reassembly
74_5.0L_Z replied to JMortensen's topic in Drivetrain
Can you post a video showing exactly what you are trying to explain? -
Are saying it doesn't plunge in and out like the outer? If so, then that is alright because that is the way it is supposed to be. If you are saying that it doesn't articulate freely in angular motion, then there is something wrong. The outer joints are the only ones that allow the in / out motion to accommodate length change of the axle. -
Bringing this one back from the dead because someone asked a question regard installation of the T5. This is my current set-up: Tilton 75-875U master cylinder (.875 diameter) Tilton 60-6104 Hydraulic Throw-out Bearing Tilton 61-612 Adapter King Cobra Clutch (5.0L Ford) Centerforce Dual Friction disc Fidanza Aluminum Flywheel Steeda Tri-Ax Shifter I have also upgraded my T5. I have the G-Force gears and main shaft with the following gear ratios: 1st 2.94 2nd 1.94 3rd 1.33 4th 1.0 5th 0.80 If I were to do it again, I would just contact Astro Performance and get there A5 with the 0.80 fifth gear. I have the engine and transmission out of the car right now for a rebuild of the engine. I plan to upgrade the pressure plate to the Centerforce LMC aluminum unit.
I just split the inner passenger side boot on my car as well. I have a very similar setup (Z31 CLSD R200 with CV axles). My inner passenger boot split at Daytona while I was doing about 155 mph, so I had grease everywhere. Luckily I inspect the car in between sessions and found it before the CV joint burned up. On mine, there is no evidence of the CV boot contacting the LCA even though I have about the same clearances that you do (my LCA are painted and clean so I would be able to see rub marks if there was contact). I attribute my boot splitting due to age and the centrifugal forces caused by going 155+ mph for an extended time. So, because I attribute the major cause of failure to be age related I decided to replace all four boots and clean and re-grease the CV joints. I ended up using the EMPI boots (P/N 86-1170-D for the outer boot and P/N 86-2127-D for the inner). They fit well and seem to be well made. I did reuse the factory retaining rings where possible, and used Redline CV-2 grease instead of the EMPI grease that comes with the boot kits. I haven't run them at speed yet. I'll test them this coming weekend on the Sebring long course where there are two straights where I will see about 150 mph.
Thanks. I had been perusing their web-site yesterday. I think the size I need for the Round Wire External Retaining ring that keeps the inner CV from pulling through the cage is CRS-30. I have requested a few samples. I haven't been able to find an exact replacement for the Flat Constant Section External retaining rings that are on the other boot side of both CV joints. I don't need those right now, but it would be nice to have a few spares laying around. So, I will follow Jon's advice and hit the local Nissan dealer to see if they can still get them. -
Looking for New Steering Rack Feedback
74_5.0L_Z replied to Samurai7one's topic in S30 Series - 240z, 260z, 280z
The stock rack that I pulled out of my early 260Z was the slow (1.59 inches per turn). I have measured three 71-73 240Z racks, and they were all the faster (1.81 inches per turn). I cannot swear that all 240Z racks are of the fast variety, but that appears to be the case. The stock 240Z rack has the aluminum pinion housing. Some 240Z cars that I have seen have had their racks replaced with newer units that came from a 260Z or 280Z. So, verify that the rack you buy is 240Z original equipment.
