42
Everything posted by 74_5.0L_Z
240z dies when choke is fully open
74_5.0L_Z replied to 5 Star Rising's topic in S30 Series - 240z, 260z, 280z
What oil are you using in the dampers on the carbs? Did you verify that the floats are set correctly? Float level is critical for these carbs. You do have the springs installed that hold the piston in the down position right? The clicking sound you describe sounds like uncontrolled movement of the piston inside the SU carburetor. This would occur if the springs were missing. Also, the oil inside the SU acts to damper the movement of the piston. At idle, the butterfly is nearly closed and airflow through the carburetor is low. Thus the pressure differential across the piston is low. This allows the mass of the piston and the force of the spring to keep the piston low. When the piston is low the needle restricts fuel flow to control the air fuel mixture. When you open the throttle, the air flow through the carb increases and the pressure at the venturi decreases as the velocity increases. This pressure decrease causes the piston try and rise. The piston will rise until the force provided by the spring and the mass of the piston is in balance with the force on the piston cause by the pressure differential. The piston should rise and fall smoothly as the throttle is opened and closed. If the spring is missing, then the piston will slam upward and downward making your clicking sound. If the oil is missing, then the piston will move too quickly when the throttle position changes. -
Medal detector find, car part? tractor? What is it!
74_5.0L_Z replied to ~KnuckleDuster~'s topic in Non Tech Board
http://www.hubbellpowersystems.com/pole-line/deadend/guy-hook/ -
My guess is that it is from the power company. Perhaps California Electric or California Edison. It appears to be a tensioning cleat or something like that. Or as you proposed, it could be a climbing foot peg. -
Any metallurgists on here? Input about breakage
74_5.0L_Z replied to BluDestiny's topic in Miscellaneous Tech
If you look at the one on the opposite side of the car, I'll bet it is bent and may already be cracked and ready to fail. Total crap design. -
Brakes dragging after 30 minutes of driving
74_5.0L_Z replied to ditto64's topic in S30 Series - 240z, 260z, 280z
Did you overfill the master cylinder fluid reservoir? In preparing my car to run at Sebring the first time, I replaced the brake fluid with Motul 600 and added cooling ducts to the front brakes. Unfortunately, during the brake bleeding I overfilled the rear reservoir. About 15 minutes into the first session, the rear brakes overheated and I was not even driving the car all that hard. Inspecting the car in the paddock after the session, I discovered the overfilled rear reservoir was pressurized. As the brake fluid heated, it tried to expand but because the reservoir was full it had no room to grow. The expansion caused the rear brakes to drag slightly and continuously. Eventually, the rear brakes overheated. -
LS/T56/240z Project Mentor Wanted
74_5.0L_Z replied to RebekahsZ's topic in S30 Series - 240z, 260z, 280z
Thanks. Every composite part that I have played with needs work to fit right. I'm used to it and accept it. -
My car has the shifter very close to the stock location, but that required moving the engine back almost against the firewall. The back of the driver's side cylinder head is 3/4" from the firewall. To put the engine in this position required deleting the factor hood latch, and fabricating my own mounts. I believe the Laine Family installation has the engine in a position similar to mine and that they managed to keep the hood latch.
Which big spoiler are you using? I am wanting to add a rear spoiler to my car to help with high speed stability and to get a little more confidence in high speed turns (Turn 1, Turn 17, and Bishop at Sebring). I am hitting speeds of 140 - 150 mph headed toward 17 at Sebring. My car NEVER pushes and feels very balanced. I like driving a neutral car at autocross speeds, but would like an aero induced shift toward understeer at higher speeds. -
Techno Toy Tuning Tie Rod
74_5.0L_Z replied to Keepn it OG's topic in Brakes, Wheels, Suspension and Chassis
Mike, Where did you find the M14 x 1.5 tube ends? I looked for those a while back without much success. I was planning to go the same route that you did with the Moog ES323 tie rod ends. -
Fuel starvation after heavy cornering on track
74_5.0L_Z replied to turbogrill's topic in S130 Series - 280ZX
I swear by the ATL Black Box fuel sump. It is a gated plastic box that sits inside your fuel cell. The fuel pump is inside the box and is plumbed out through the top of the cell. Gates allow fuel into the box from three sides. I also plumb my fuel return into the top of the box. The system is so effective that l have completed a track session without any starvation issues and then have the car run out of fuel loading it onto the trailer. Good to the last drop. -
What do you want to do with the car? Are you auto-crossing, drag racing, or just driving? How are the roads where this car will be driven? Is the car structurally sound or is it really rusty? Does it have a cage or any structural reinforcement? Are you planning to run camber plates or use the stock isolators? My car has a lot of structural reinforcement. I autocross and road race. My front springs are 500 lb/in and are 8 inches tall free length. My rear springs are 400 lb/in and again 8 inch free length. You have to consider rate and free length when selecting springs and while you are placing the coil-over sleeve on the strut.
If you lower the S30 and do not significantly increase the spring rate then you will most likely experience bottoming of the suspension over bumps. On a lowered Z, the benefits of coil-overs come mostly from the availability of different lengths and rates of springs, and from the additional clearance between the strut and wheel. Read the sticky regarding sectioning struts. To properly lower a Z car the struts must be sectioned, you must install shorter inserts, and you must have decent bump stops.
Arizona Z Car brakes are awesome
74_5.0L_Z replied to crapforum's topic in Brakes, Wheels, Suspension and Chassis
You cannot use the full potential of bigger front brakes until you have also added appropriately sized rear brakes. A balanced set-up is key to maximum braking performance. Right now, with the upgraded front and stock rear, the front brakes will lock easily and the rear are doing not much of anything. I found myself in the same predicament years ago when I upgraded the front brakes before the rear. The brakes felt better than stock but were severely limited by the stock rears. I finally decided that upgrading the rears to match the front was mandatory after trying to stop on a wet slippery bridge. The front locked super easy and the rear did nothing. I nearly hit the car in front of me before getting stopped. An unbalanced brake set-up is dangerous to drive in wet conditions. If you have four 1.75 " pistons (per caliper) in the front, then you will need four 1.375 pistons (per caliper) in the rear and a proportioning valve in the rear brake circuit to get good brake balance. -
Sway bar for my Laurel C31
74_5.0L_Z replied to JelmerPatrol's topic in Brakes, Wheels, Suspension and Chassis
The center to center distance for the mounting bushings on the S30 is 700 mm, so the S30 sway bars are likely too narrow for your application. I would look into a sway bar for an older Mustang. I used to play with the older Mustangs (69-70). They had a similar shape and were wider than the S30 sway bars. -
Roll bar question ...
74_5.0L_Z replied to VitaminZ's topic in Brakes, Wheels, Suspension and Chassis
I think that piece of metal might be sufficiently strong for hanging up your laundry after it comes out of the washing machine. Other than that, I see no useful purpose. -
I have run three track days now with the MSA flush mount mirrors. They don't move and the visibility is great.
Brake trouble shooting with pressure gauge
74_5.0L_Z replied to RebekahsZ's topic in Brakes, Wheels, Suspension and Chassis
Here is a little light reading regarding caster, its measurement, and its effects. http://www.disco3.co.uk/gallery/albums/userpics/24543/steering-geometry-and-caster-measurement%5B1%5D.pdf -
Caster does have a jacking effect, but only when the steering wheel is turned. When corner balancing the car, you REALLY need to make sure the wheels are pointing straight ahead. If you have 6+ degrees of caster, then turning the wheel will significantly affect the scale readings. If you turn left, the left front wheel and right rear wheel will gain load and the right front and left rear will lose load. On a related note, caster (or more specifically caster trail) produces a torque about the steering axis. If both wheels have equal caster, then when you are driving straight the caster induced torques at the front wheels will be equal but opposite therefore cancelling each other out. If one of the front wheels has significantly more caster than the other, then the car will pull toward the side that has less caster. -
I'm guessing that your caster is not equal left to right. -
New project-reducing bumpsteer
Do you have stock control arms? How much caster? Bump steer spacers? Camber plates? The stock camber curve at stock ride height starts off toeing out with bump and then at extreme bump start to toe in. When you lower the car with everything else stock, you operate closer to the hump where the curve transitions from toe out to to in on bump. The bump steer spacers help get a lowered car back in the safe toe out on bump region of the curve. From the pictures, you have lowered the front substantially. Bump steer spacers will help but probably not enough. Raising the LCA pickup helps the camber curve on a lowered Z, but also moves you more toward the toe in region of the curve. Your options are as follows: 1. Raise the car so that you are operating in the toe out region in bump. 2. Raise the steering rack relative to the LCA pickup points. 3. Lower the outer tie rod ends to get back in the toe out range. In all of the above, you are just moving around on the same curve. To change the curve, you need to use a different length rack. I wish you were close enough for me to come help you out. Good luck. -
If you are good at math, try "A Multi-body Systems Approach to Vehicle Dynamics "https://books.google.com/books?id=FlBgF8w9CegC&source=gbs_similarbooks
ST front sway bar clearance question
74_5.0L_Z replied to madkaw's topic in Brakes, Wheels, Suspension and Chassis
Let's see a picture of the end links. The simple cure is to replace the six with a V8. Problem solved. Actually, I had a similar issue wth an ST sway bar years ago when I still had the L6. For me, the cure was longer end links. -
Delete the rear sway bar.
shops that do turnkey ls 240z swap?
74_5.0L_Z replied to alphalonewolfxiong's topic in Gen III & IV Chevy V8Z Tech Board
I think Hoke Performance does this. He's in Asheville NC.
