Everything posted by brokebolt
I would guess from my summation of your description, that maybe you indeed did have a copy of on original Cannon casting. We (friends getting together, not business) used to do stuff like this for one-off parts, never for resale. If you didn't match the mold up correctly when you mated the two halves of the mold together, then yes it would misalign the top and bottom half of the manifold like you stated... that was all sand cast stuff not modern technics like today. Normally, however, you scrub any indication of the original manufacture (like a logo or the letters C-A-N-N-O-N across the number one, or number four runner) to prevent copy write infringement and liability on your part. I heard a rumor that the TWM was a copy of the SK Racing manifold, it does look similar to me...
Can I make a set of Triple 40mm Dellortos from 2 sets of twins
brokebolt replied to OZZ240's topic in Fuel Delivery
I didn't know Weber did this as well. Good to know. I am no Weber expert so this helps out a bunch, I do dabble with them from time to time. And yes, I agree with Drax240z, he is absolutely correct about causing issues... Dirt (straw, crud, debris, etc.) will cause issues too, gotta keep them holes clean! -
Yes, you should look at the progression hole count and size, idle mixture screw type, and the idle air bleed type. Their are two types of both the last two and I don't know how many types of the first item. The first item is the progression holes, they are located under a slotted brass 'slug' (meaning it has a "-" {minus} on the head and uses the same type screw driver to remove it.) This slug is sometimes steel with a coating to prevent rust which may look gold-ish or at one time looked gold-ish in color and I have found is always a phillips head (meaning it has a "+" {plus} on the head and uses the same type screw driver to remove it). The 'slug' is easy to located in front of the idle mixture screw which is located toward the back side of the carb (where the butterflies are located on the carb body), on the top of the carb, located by the carb mounting surface to the manifold. Their are three bass things in a row on the carb. First is the accelerator pump jet holder the second is the brass slug and the third is the idle mixture screw. The hole count and size need to match. For example you may have a large hole and three smaller holes. I would not suggest you mix and match carbs of different progression holes, as it will effect the characteristics of the progression phase of the carb. Second their are two types of idle mixture screws. The first idle mixture screw is a fine thread if it is encased by the aluminum carb body. The idle mixture screw is recessed into the carb tower a bit. The other type is a course thread where the idle mixture screw is somewhat exposed and the tension spring is 100% exposed with no aluminum shroud around it. I guess you could mix and match these but I wouldn't suggest it, as the idle mixture may vary between the carbs. Third you need to make sure that they are either the non-adjustable air bleeds that have the air bleeds located in the carb body or the other type has the air bleeds on top of the idle jet like how Mikuni, Weber and others have done it. Locate the jet cover, usually black or orange plastic, sometimes aluminum, remove it, and pull the idle jet from the carb body. The idle jet (two per carb) is the smaller two of the four brass parts located under the cover. The other two are the main jet, E-tube and air corrections jet (or air bleed jet). Their are two ways to tell. First if their are numbers stamped on the side (like 7850.1), or second if you have two rows of holes drilled in the jet holder; one row above the threads and one below the threads, than you have the idle jet version, if not then you have the carb body version (no stamped numbers, and only a single row of holes drilled above the threads). The idle jet is located on the bottom of the idle jet holder on either version. The carb body idle air bleed vs. idle air bleed jet isn't an issue other than to make sure that you have three carbs that have the same type. If not, I do believe that the carb body is drilled slightly differently for it's passages and this may effect the idle characteristics of the two types of carbs. Not sure though, I have never mixed them before. I would not suggest it, as it may effect the idle and just off idle characteristics of the carb. If the tuning parts are not identical, no worries man, you can always pick them up from several sources, like VW performance shops and some still sell Dellorto parts. Dellorto DRLA and DHLA use many of the same parts. Auxiliary ventures maybe the hardest to source and cold start parts too. But you really don't need to use the cold start function for performance minded personnel. Happy motoring. -
I can't speak for the Nissan Competition parts manifold, but the Cannon, TWM, and Mikuni Manifolds are all the same spacing. Even the FET manifold I have is the same, so is the generic no-name that came on a set of well worn rebuilds. I wonder if the holes were simply miss-aligned when machined after casting clean up. Maybe the guy running the mill had tied one on at lunch. Just a thought. Those Mikuni air horns are horrible to try and wrap a filter around. I have, in the past, just bought the oval K&N filters and cram the air filter around them. It causes the filter to protrude out a bit around the ends but it's either that or cut them (eeeeeeeeaaaaaaakkkkkkkkkkk!!!!!!!!!!!!!!!!!). Custom air boxes are always nice. The guy that sells those extrudabody throttle bodies shows you how to make a low buck, easy to build air box. You only need the air box back plate/carb face plate. http://extrudabody.com/TechInfo/Plenum_Building.html I haven't built one using this method yet so I can't comment on that. But I can say I am a fairly experienced fiberglass man... pay special attention to item "C"... get a box of good nitrile gloves for about 7 bucks for a box of 100. You will thank me later. I promise.
Brake confusion, some one kill me
brokebolt replied to wax's topic in Brakes, Wheels, Suspension and Chassis
You may want to see if you can find an aftermarket hat what you can bolt an aftermarket rotor to to get the offset you need. This would be an added expense for you, but you would get better rotors, lighter parts and maybe even an aftermarket caliper that you could bolt on. I haven't looked into this but WillWood or someother manufacture may have the answer for you. I also have not done a search here on Hybridz for such a conversion. -
Here is another link where he used the brackets you have: Here is a good post for anyone interested in brake conversions. http://forums.hybridz.org/showthread.php?t=103767&highlight -
Here is a good link: This is the set up for the Port D set up. I do not prefer this set up. Just my opinion. But an excellent look at the other bracket with the screwed on dust shield. Also the rotor is unique to this set up, unlike the Port E which uses the more widely used rotor on the Maxima, 280ZX, 240SX, and 200SX. -
Read the ebay pages for any help they may offer and advice before contacting the sell and see what you can resolve. Just my $0.02. Best of luck on that ebay action...as well as the rear brake conversion. -
You would need to cut and weld the flat bracket and bore the center hole to fit around the hub of your Z. Not worth the effort in my opinion. Better bet is to buy an aftermarket set of hub brackets and part your rears together with reman parts from the auto part store or buy a full-on complete aftermarket package. Or if you're junk-yarding parts together look for those years your interested in and pull the Maxima hub brackets. This bracket is the better of the two OEM Maxima hub brackets that are "bolt-on" in my opinion. Don't forget the dust shields and stock OEM hardware that are not pictured here. The bolts are longer then the stock drum brake set up so you will need the longer bolts. The dust shield just keeps junk out of the back of the rotor, a good idea in my book. You will still need to mount them which means removing your stub shafts but that is really just an opportunity to service the rear bearings and seals that most likely haven't see the light of day since installation at the factory well over 30 years ago. That isn't a easy job, not like servicing the front wheel bearings and seals. But that is just my $0.02.
Ya that sticky really isn't cut and dry, and goes off in several directions. Worth the read though. It is also worth noting that the Maxima had the same hardware BUT some of the hub brackets are welded on (well most I've seen were welded). What your looking for really is the hub bracket, select your caliper and rotor based on the hub bracket. The small pad version of the rear conversion uses the bulky caliper that looked like the front calipers used on a B200 (if memory serves me correct). I would recommend the other set up with the larger 280ZX/200SX/240SX pad. What your really after is the bracket pictured on the sticky on page #5 post #93. Best of luck. -
The flat Maxima brackets will not work, but their are two other Maxima brackets that will work for a rear disk conversion. Here is a basic list I have put together years ago for the two versions on the Maxima bracket that are of the "bolt-on" style. Port D: Small Rear Disk, Small Pad Brake Conversion 280ZX 4 X 4 1/2†lugs. Major parts include: 1979-81 Nissan 280ZX 15/16†master brake cylinder 1982-83 Nissan 280ZX rear caliper and hangers 1982-83 Nissan 280ZX rear rotor 4 X 4 1/2†lug pattern 1980-84 Nissan 810 Maxima Sedan rear bolt-on brackets that have the floating dust shield No E-Brake extension available after market but they can easily be fabricated. Rear axle must be removed to install the hub brackets. Port E: Small Rear Disk, Large Pad Brake Conversion Maxima 4 X 4 1/2†lugs. Major parts include: 1979-81 Nissan 280ZX 15/16†master brake cylinder 1979-81 Nissan 280ZX rear brake calipers and hangers 1979-81 Nissan 280ZX rotors 4 X 4 1/2†lug pattern 1980-84 Nissan 810 Maxima Sedan rear bolt-on brackets that have the screwed-on dust shield E-brake extension available after market and they can easily be fabricated. Rear axle must be removed to install the hub brackets. Best of luck on the conversion. -
I say stay with the SU's. Rebuild the Webers and sell them on ebay to generate some funds for more fun stuff. Just my $0.02. Or keep the Webers and play with them on your combo. Rebuild kits are still readably available for those 32/36 DGV carbs. Google "weber carbs" for lots of links.
Remove the peddle and use a constant amp/volt setting and try "scratch starting" the arc. I bet your using a high end welder that has high frequency start and other goodies that may interfere with your ability to learn. Later you can add in the peddle and high frequency start after you have mastered puddle control. The electrode will become contaminated a bit but for learning it is a trade off.
That would be used for a Heat Riser tube that pulls hot air off the exhaust and into the fresh air inlet on the air cleaners assembly. This was used on carb cars usually and on the later SU set up for the Z version. Bell tops and bucket tops both used this heat riser set up, early bell tops had nothing, later bells had a winter/summer selector lever on the inlet snout you had to manually turn under the hood and the later bucket tops had an auto set up that did all the "hard work" for you. They were used to heat the air coming into the carb for cold starting and cold weather driving.
Here is good thread: http://forums.hybridz.org/showthread.php?t=82485 As far as the T-5, WC T-5 discussion, the input shafts have different spline count and diameter, even between Non WC T-5's; as stated the bell housing is also different. Adding a shift kit like the B&M Pro Ripper that I added helps stiffen up the shift a lot and adds a level of security with shift stops. Take a good look at the stock Nissan T-5 shifter and you will see it is nothing more than a stamped steel piece with a shifter ball attached. Not the best design but quick and dirty to get the cars off the assembly line IMO. The Nissan version in the B box is much better as far as a nice solid shifter as far as feel and stiffness in the stick. Ratios are different from the T-5 and better out of the hole if you don't mind banging the first two gears rather quickly...Stick in a 4.11 gear set and your ridiculously whizzing through the gear box. These boxes also have issues with extremely high Torque engines and...not an issue for us wimpy engine guys: http://www.myrideisme.com/Blog/world-class-t-5-transmission-upgrade/ Yes I know that is an article about the WC tranny but the Non-WC is even weaker. Eeeaakkk!! Just my $0.02.
1973 SU (flats) swap to 1972 SU (roundtops)...
brokebolt replied to mamba_888's topic in Fuel Delivery
I do agree from the picture, the third feed is plugged into the balance tube. My best guess is it feeds the vacuum side of the vapory recovery system. And the other two are carb feed and return. That is my best guess. Remove the carb feeds and use a clean tube (hose) and blow with your mouth gently to see what is routed where. It would behoove you to clean the internals of the metal feeds and replace the hoses so I wouldn't fret about cutting that old rubber. Those look to be the original hose clamps so I would guess that is 30 year old stuff your working with (could be wrong). The picture of the front of the engine I would guess that the top two are fuel and the bottom is a vacuum feed (just a guess). As far as linkage, I bought a new center linkage from MSA years ago. Don't know if they still sell them but might be worth looking into. I unfortunately do not have any old SU stuff...trippple carbs...yes...old SU stuff no, sorry. That U-tube link, what is he asking for parts cost and shipping to USA? Might be worth it. I used to buy aftermarket from super-shops and online speed performance sellers, piecing stuff together, quite a chore to locate all the tidbits. Same stuff he sells, but if your going aftermarket, I like the heims that bolt in place. Had a plastic ball end joint become dis-attached once! Throttle jammed at wide open throttle (in the fully open position at the top of a shift) on my bell top SU's. Slapped the throttle pedal (which did clear the condition), jumped out, open the hood, reattached, did a bit of cursin', jumped back in and drove off a bit wiser. Stuff does happen... Best of luck on the project. -
M12 X 1 x 18 It is a shoulder bolt and has a flanged head so you may want to try an E-Bay search for some New Old Stock or your local Nissan dealer *maybe* able to get them for you. Best of luck.
Here is a nice page: http://e85prices.com/ In Rocklin California, $1.85 reported on Dec. 7, 2008. Gas listed as $1.75. I paid $1.69 today. She's getting more economical to drive...just in time for winter!
Yes, the Round top carb (I call them Bell top carbs) will fit on the Flat top carb manifold (I call them Bucket top carbs), as far as the bolt flange pattern is concerned. Best of luck. -
Arazona Zcar intake vs. Fuel Injection-Long-pix
brokebolt replied to 280zex's topic in Fuel Delivery
I think they call that real world data! 280zex thanks for the follow up post on your results. Nice work buddy! Are you using a G-Tech meter to achieve this particular G-force result? -
Oops! You said single throat carb, scratch what I said.
Largest I am aware of is a 58mm side draft made by Weber. The Dellorto Tech hand book stated that Dellorto made a 52mm carb but I think that is a miss print, I have done some research and haven't seen or heard of any that large. Largest Dellorto I seen is a 48mm DHLA. I do believe the largest SK is 50mm as well as Mikuni, don't know a lot about those two manufactures so I could be wrong. Seen a set of 58's on a late sixties Formula 1 car in Sonoma, CA. at Sears Point Raceway, I think it was a Ford power plant (I could be wrong on that) and had two large air boxes (air scoops or whatever you kids call them today) on each side of the engine. Closest I have come to them. In any case it was one of those vintage race cars that show up at the Indy car races and entertain the crowd. You got to wander around the pits before and after the track time and look at the cars...the vintage cars not the Indy teams. Fun day!
Interesting read from Extrudabody's webpage: http://www.extrudabody.com/TechInfo/FlowInfo.html Shorter overall length has a tat higher flow rate according to his independent testing. Not affiliated with them in anyway. Doesn't state who the competitor is but knowing a bit about the company I can take a guess.
I run a 5 inch disk super trap muffler, I have been pulled over in Ca. for loud pipes. You would need to use another muffler/silencer somewhere else in the system to keep her hushed up. But I do like the tune-ability. "Loud pipes save lives"...the guy on the HOG for one. Drag your lawn mover down and ask the judge if you run this bad boy will you expect more citations? Sounds like a subject Adam Corolla would have a few words on (chicken "S" ticket). After all it is statistically proven that more murders and thieves started their lives of crime disturbing the peace and not properly displaying front plates.
Reaction Disk pictures and walkthrough
brokebolt replied to blue72's topic in Brakes, Wheels, Suspension, and Chassis
The hiss is a vacuum air leak. Some times the engine RPM's will raise slightly do to the addition of air into the intake. I would replace it as you "could" cause engine damage, and your brake booster is a vacuum device so you are loosing brake pedal efficiency, meaning you have to push the pedal harder to make the same fluid pressure in the brake lines. (Some older cars, race cars, and aftermarket set ups do not use a brake booster.) Follow his links posted here for the set up on the master cylinder push rod length. They may need to be adjusted for the 280ZX master cylinder upgrade. I say this as when I did a 280ZX upgrade and Toyota 4X4 calipers my rod was in no need of adjustment. blue72, thanks for the pics.
