Everything posted by 80LS1T
Actually putting an LT1 or LT4(96 Vettte motor) in a early Z 70-78 would probably be much easier than putting in a carbed engine. Since the disributer is on the front of the engine behind the harmonic balancer you dont have to move the hood latch. Also you have a much better hood clearance! Though the cost is a little higher, I think in the end it is a much better set up for the early Z's. Plus you get alluminum heads and intake and it's Fuel Injected! Now if you go LS1 or LS6 you are talking some BIG bucks to swap that. Those engines aren't nearly avaliable as the LT1's are. Plus the mounting is different from the old style mounting. However with an all aluminum engine you will probably be close to weight with the L6's or L28', which for most of us that is important. I can't remember the name of the guy who is swaping an LS1 into an early Z but search the Chevy Board for "LS1 Swap" and you should find LOTS of info on that. That's just my $.02! Guy
Hey just to let you know it's kinda hard to read with that lightning background. But otherwise nice site! Guy
Hey Tomahawk have you visited my site lately? I updated with some new pics and they are clickable. Let me know what kind of pics you guys want and I will take them tommorow, I promise! Like do you want to see them mounted to the rubber mounts attached to the crossmember or something else??? Let me know! Guy
Autometer gauges for my 280zx SBC project.....
80LS1T replied to 80LS1T's topic in Miscellaneous Tech
Well I've already order them so I guess I'm on my own! I will update you guys when I start! Right now I am in between puttin my engine bay back together(just finished painting it, see my pics on my website) and putting my R200/CV set up in. I am a very busy person to say the least! Guy -
Ok I'm not in CA but from what I understand about their emissions is that you have to have the same year of engine or newer and all smog equipment that was on that engine. So if you have a 77 then your motor needs to be 77+ not older! So you might run into some serious problems! Maybe Greimann will chime in, I think he is from CA and has done all of his modifications legally. Guy
Ok I haven't seen your Z but I can't see spending money on a 4 cylinder that will be slow in most guys book even with those modifications do you? Aleast with a Z there is potenial for speed and power!! Besides you don't really want to become a RICER do you? Just my $.02 Guy
Yeah you can't put the motor in the JTR position but you might be able to use their mounts, not sure though. I have choosent to use MSA's mounts and I think they are going to work great. As for you rear end... is it a R180 or R200? If your car was a manual transmission to begin with it is most likely a R200. If it is and it is in good condtion then it should hold up for a while anyway. I am building a 1980 ZX with a LT1 and T56 with about 425HP+. I am also using CV halfshafts and not U-Joint halfshafts. You have to remember that these parts are 20 years old so there is no telling how long they will last. The R200 will deffinetly take more of a beating than the R180 though! Guy
Well I measured them last night while they were in the dash and heres what I found... The 3 center pod gauges are 2 5/8" and the speedo and tach are something like 4 9/16" if I remember correctly? So my question is will the 5" gauges work? Where do they measure from? I think I will just skip on replacing the fuel gauge and the water temp gauge for now since those are not 2 1/16" or 2 5/8". Thanks, Guy -
Hey how far do those stick out from the center 2 ports? Thanks, Guy
*bump* -
Autometer gauges for my 280ZX SBC project...
80LS1T posted a topic in Gen I & II Chevy V8 Tech Board
I posted this in the misclanious section but that section doesn't get many responses, so here it is... Well from what I have read so far I have come to the conclusion that electric gauges are easier to install but mechanical are more accurate. I have chosen to use electric because I am using a 93 LT1 and T56. I have also chosen to use Autometers Phantom Series guages. Now heres the questions.... What size are my tach and speedo, What size are my fuel and water temp, And what size are my volt, oil press., and clock? Also will the fuel guage work in my car? and if so how does it hook up to my old units wiring? I think that's it but for some reason I feel like I had another question! Thanks, Guy -
I have an 80 ZX and I am using Konig Monsoon rims. They are 17x7 but I am also using Ross C's wheel spacers so I can use the 40mm offset. I "think" the widest you can go with out coilovers or flares is a 7.5" wide wheel. I know of one member who is running those, but he is also using Ross C's wheel spacers. If you want a larger select of rims your going to have to get wheel spacers. Heres the link to his site... http://www.modern-motorsports.com/ He is a VERY reputable(sp?) guy. I think the spacers are about $225 or so? Very good idea if you want aftermarket rims. Guy
You might want to post this in the drivetrain section or the datsun L6 section? Just a thought though! Sorry I couldn't really help, Guy
You know now that I think about, I don't think I have a 20mm in any of my sets! I am going to have to check now. I swear some of the stuff you guys think of just blows my mind! Guy
Taurus 2 speed fan wiring to a toggel switch... Do I have th
80LS1T replied to a topic in Ignition and Electrical
How much can you get one for new? Thanks, Guy -
Can someone with a 280ZX do me a favor???
80LS1T replied to 80LS1T's topic in Gen I & II Chevy V8 Tech Board
Hmmmmm... Was that an exact measurement or a estimation? Cause if it's 2" I might have found a header that will work! Don't know for sure though. I just emailed the guy and he hasn't responded yet. I really hope they do. Oh the wait is killing me! Thanks Greimann! Guy -
Son of *****! I thought I had the 2 speed the whole time! So will this cool my 400 HP LT1 with the 26X19 Griffin? Or should I start looking for a 2 speed? Guy -
I need to know how much space is between the steering gear box and the exhaust ports in the middle on the drivers side. I need to know for a 350 or equivalent. Thanks, Guy
Can someone tell me if I got the right Taurus fan? It has 2 wires on it 1 brown and 1 black. Heres the pic... Thanks, Guy -
Oh on step one I am refering to the post reply page where it says "Instant UBB Code." That's what I ment by "right below this box" Guy
Heres how I do it... 1. First click on "Image" (right below this box) 2. Open a second window on your computer with the webpage that has the pic. 3. Right click on the pic and go under properties and highlight the web address. 4. Select "copy" 5. Now come back to this page and paste in the address in the box that popped up for the image buttom you pressed in step 1. 6. Click ok and continue on typing whateveryou have to say! Easy as pie! Guy
Sorry how about this one? Guy
Not sure if picturetrail will host but...here ya go.... Those look very nice! And I really like your rims too! Guy
Yeah I left teh AFM mount there because I am probably mount the MSD box there and/or coil. I will think of something! Or it might serve as a mount for the cold air intake to mount on before going out in front of the radiator. As for the rest of the car... I have to wait until the end of March before I will have my engine rebuilt(doing it at school on my own(tech college)). After it is in I will be painting it. So probably in the middle of April before I am completly done. As for the battery tray. I just couldn't see how 30-40lbs could make all the difference I weight. However if and only if my car is like 50 lbs off of 50/50 weight distribution front to back will I move it. I just want to see how close it is before I go to the trouble of moving it. By the way I updated my site so that the pics are clickable. I also have bigger pics of the paint job too! So you can get the full effect of the paint! Guy
