HowlerMonkey
Posts posted by HowlerMonkey
  1. I pulled a u-haul trailer from front royal virginia to Orlando.....then back up to virginia empty for another trip down to orlando in 3 days..........paying only the one way trip from front royal to orlando.
    Good thing I was in front royal where they were too lazy to even watch me hook up or Uhaul would never have allowed a 280zx to connect up a trailer this size.
    I built a large receiver type hitch which used the bumper shock bolts in addition to bumper mounting but was short enough such that I didn't worry about something pushing the assembly into the fuel tank if I got hit or hit something.
    I packed a few rubber dogbones in the rear springs to limit the down travel of the suspension and carefully loaded the trailer to keep tongue weights managable and the car drove perfectly level and smooth.
    Of course, the turbo seized only 200 miles into the trip so I cut a thin piece of stainless from a floppy disc, undid the two bolts on the turbo drain, slid the metal in to block the turbo drain, replaced the "T" on the oil supply with the gauge sender, and disconnected the wastegate actuator to keep the gate open.
    Then I drove around a large tire tread from a truck on the highway and it clipped one of the long tire valve stems and cracked it such that centrifugal force would only cause leaking when the car was going fast.
    I noticed it when I was filling the tire and found a very short flat head wood screw and used it as a buttress to keep the valve from being pulled by the forces at speed......but not before using ultra black to seal it.
    10 miles later, I got my second flat tire in 23 years but I happened to have a zx turbo swastica wheel and tire I was transporting so I used that as the spare congratulating myself on fixing the other tire instead of swapping the spare at that time.
    I drove on that tire and seized turbo for 6 months.
    I later towed a 1984 maxima with a car dolly using the 280zx.
    Great car for towing as long as you only brake in a straight line and don't even attempt it if the zx has bad rear shocks.
  2. Took a bit longer than I expected.
    It seems to be relatively unworn for the high mileage but it only did duty on a 1984 maxima with an automatic transmission.
    The cv type axles butt against the spider gear pin which has a flattened section on each side.
    This is what you see inside the axle hole.
    Here's an impression on the ring gear if the detail is not enough on the photo.
  3. These roads here will have 5 inches or more from trough to peak on a washboard surface one day and be dead smooth the next.
    I'm sure grumpyvette knows what I am talking about and that the amount of energy that the shocks are being asked to absorb is pretty intense.
    It's an extreme situation but I endure it every day and I would rather my shocks not be insulated by an air gap from any cooling I can get.
    I'll try to measure the heat next time I have to endure it.
  4. I just populated the ecu connector with the missing wires when I made a ECU testing harness for this.
    Blue Streak electronics had harnesses and wiring diagrams for all of the nissan engine management computers.
    I probably could have skipped making a harness for this ecu but the orders came from the canadian facility.
  5. For this setup, your basic need is an engine management system that you can select your spark timing.
    I'm running 8 pounds of boost on a f54/p90 setup on a unmodified factory M30 ecu that has crazy aggressive timing in stock form and it's close to being too much timing.
    Even a stock type ecu will work fine if it's either purposed for turbo use or the timing map has been optimized for boost.
    If you are able to pull timing, you should be able to get away with 10psi on 93 octane.
  6. I pretty much only have the soundcards left of that setup and am looking for a newer motherboard that can fit them or a more modern card that uses PCI slots instead of the old ISA slot.
    When that workstation died, it had the awe32 card and two terratec ews88d cards used through a Vm200 digital mixer using adat inputs and outputs.
    Those old awe32s had a spdif digital output which was largely undocumented.........but sweet for avoiding any analog passes when mixing and recording either the onboard emu8000 synth. or using same to play samples.
    I haven't checked but technology surely has passed my by in the DJ industry but it seems latency is still an issue for many types of equipment.
  7. Two tech12s, cheap numark mixer, ABIT KT7A-raid based digital workstation with circa 1995 soundblaster awe32 stuffed with 32megs of sample ram allowing ZERO latency (zero....not low latency) live sound through soundfonts, cheap midi controller, cheap midi drum surface, a monophonic a/b stomp box connected to a digitech rp-8 to which a cheap kramer guitar with a floyd rose stuffed with a duncan distortion pickup........which was used to make crazy sounds mostly as a safety net. And a cheap cd player.
    Soundfonts, when used old school in hardware has the response that no software synth. can ever match.
    At my best, I could flip hard between Grace Jones' "slave to the rhythm" (princess and the frog mix) with James Brown's "super bad" without a trainwreck.
    Nothing in the world sounds like a guitar connected to the house PA of a good sized club when you've got the bar pushed so far down the low e is vibrating at 16hz.
  8. Then I guess the 280zx runs richer than 10:1 when you unplug the 02 sensor......which causes black smoke when the car is run.
    At Z shop of miami, we used to coordinate test drives for the first services of the day to have at least two cars.
    Following a 280zx with bad 02 or it unplugged always netted black smoke.
  9. I'll take the cover off tomorrow.
    My factory service manual for a 1983 maxima shows 3.7 for the auto and 3.54 for the manual.
    This might be because the later 4n71b auto transmissions had a pretty steep overdrive as well as lockup torque convertors.
    I wonder if the maxima c/v type axles are short enough to use on the s30?
  10. Sweet.......exactly the type of information I need.
    I'm going to experiment with this on a 2002 nissan frontier supercharged ecu but I figured the MS guys are on the sharp end of external peak and hold drivers.
    One thing I want to do is check any tuning differences between running dropping resistors and external peak and hold drivers on the same car under the same conditions.
  11. This is from a 1984 maxima sedan automatic with 225,000 miles.
    No clue on the 110 or 115mm question or whether splines are the same as earlier diffs. but the application above is correct so checking whether the 1984 maxima indeed has the proper differential would be a good idea as it came with CV type axles.
    I did rob a few bolts but not enough to open anything and will update the pics with all the bolts installed after I go through my bolt drawers.
    I did not hear any undue noises when it was pulled out of a daily driver car to be replaced with a 3.54 R200 and 5 speed and has been stored inside for 3 years.
    UPS estimates around $47 for shipping from west palm beach to a random zip code in huntsville, AL via ups ground with a 2 or 3 day transit time.
    $130.00 with shipping included.
