HowlerMonkey
Posts posted by HowlerMonkey
  1. If the car had an oil cooler, then the ball is in the adapter housing and a small freeze plug is in the block.
    I'm not sure if the later manual transmission 280zx turbo had the oil cooler but all of the automatics did.
  2. Many of the chryslers don't turn on the fans until 230 degrees F.
    The reason for the high temperature is that they are sampling the temperature of the cylinder head itself instead of the thermostat housing.
    I run a M30 ecu on my L28et and use a laptop to pull data from the consult port and the temp sensor on the head is always a bit higher than the temps I deduce using the lookup tables for the brand sensor installed in the thermostat housing.
  3. I had a mazda RX-2 that did this every once in a while.
    One day, I pulled into a gas station and decided to fuel up while trying to figure out what was wrong.
    When I remove the gas cap, it was difficult and a large sucking sound was heard as I got the cap off.
    Apparently the tank was ending up with a vacuum in the evening after the sun went down in Washington DC and the temperature dropped 30 degrees.
  4. Initial overheating might have been air in cooling system......very common on first starts.
    I always run the engine a few times and ease up to the point that the thermostat should be near to opening.
    Then I shut it off and let conduction do it's thing.
    Upon restart, I am usually greeted with a significant lowering of coolant level to which I add coolant and let run until I see flow through the radiator.
  5. The VH41DE did not have the variable valve timing so its rated hp and tq were correct. the heads also didn't flow quite as good. There are rumors that it is 1" skinnier. There are tons of other differences.
    It is already under the 4.2 liter limit for the class in stock form.
  6. Before you start chopping things up, check out the 1992 nissan stanza throttle body.
    I believe it is far better starting point and it is the same size.
    There are a few flavors of the 60mm throttle body on nissans made by at least two manufacturers.
    some fit better than others.
