HowlerMonkey
Drag racing...breaking things, NEED HELP!!
HowlerMonkey replied to rwill300x@hotmail.com's topic in S130 Series - 280ZX
Unplug the head temp sensor near the 5th spark plug. You will probably find it corroded and making bad contact. When that happens, you get exactly the symptoms you are describing. -
84 Distributer on 79, extra connector on module?
HowlerMonkey replied to Niku-Sama's topic in S130 Series - 280ZX
The extra connector is much like the "spout" connector on a ford. It allows the ecu to affect the advance of spark. The module that has two connectors is E12-92 and the single is E12-80. I believe just going to the E12-92 module will retard your spark 8 degrees so the distributor will have to be advanced and possibly loosen the bolts on the bottom of the distributor for more adjustability. Other than needing to advance it, it should run the same but there could be slight differences in the advance curve. -
Is this nissan extinct in United States
HowlerMonkey replied to HowlerMonkey's topic in Non Tech Board
I never knew why manufacturers don't release their baddest cars in a market (US market) that is known for craving performance cars. Renault and Peugeot released lame cars in the united states and let europeans have the kick-ass rally cars. I imagine things would be different had they released them here but I still think they would have had the same longeivity issues..........but........many americans forgive that kind of stuff if they get the performance they crave. Either way....... I never liked the fact that chrysler/mitsubishi cashed in on the "EVO" nomenclature. To me, a real "EVO" is...... Ford RS200 EVO or Ferrari 288 GTO EVO Lancia Delta S4 EVO......which is the car that killed group B rally racing by being so damned fast. I believe chrysler used "evo" moniker with "lancer" which sounds a lot like "lancia evo" much like GM is re-using famous engine designations like "LS1" (originally a 427) or LT1 or LS7....etc. -
L6 squish discussion... (the battle against detonation)
HowlerMonkey replied to OlderThanMe's topic in Nissan L6 Forum
At Z-shop of miami we used to get cars that were never driven hard which would come in sounding like they had serious bottom end problems. We would take them out and run them hard with high revs and the noise went away. Apparently the very small space between the piston and the head would stack solid with crud at TDC and running them up and slightly beyond redline would liberate said crud. RE: Squish..... I'll bet a lot of big block chevy guys look at the L88 closed chamber heads a lot differently than they did way back in the day when everybody said open chamber was the way to go. There was a good article about at least a decade if not 20 years ago where Jim Feuling (olds aerotek engine builder....1000hp quad4) did some big block chevy heads that could run something like 11 to one compression on 89 octane making like 700hp......Wish I could find it as it had lots of discussion of "squish". -
XT6 did not have turbo. The XT6 shares a distributor rotor with the Z31. That was the 1.8 liter XT 4 cylinder. The SVX would have been cool except for the bizarre little windows and the fact it weighed a ton.......and they shared a tranny with early pathfinders which never lasted too long. I loved the S12 except for one thing................the seat was so low you could feel if a penny had slid under it. I'd hate to run over some debris and have to explain ass damage.
It was at Palm Nissan on military. They moved to Royal Palm Beach so I will check if they still have a specialty and performance shop there. -
Some of my new tools and equipment.
HowlerMonkey replied to xxjoeyxxeb's topic in Fabrication / Welding
Score of a lifetime!!! Make yourself available if they need you. -
It's easy to "caulk" with a mig welder and think you just welded something. I use a gas torch to preheat my work sometimes. This does wonders if you're mig welding thick stock. One thing many people screw up is the building's ability to pump enough current to a welder. I always try to stay as close to the main breaker box as possible.......which is necessary because I use a 110 volt 140 amp mig welder.........It's not as big an issue with 220. Before anybody slags the 110 welder, it is a 140amp welder with 100% duty cycle and weighs a ton.......the only one I've ever seen with 100% duty. In 110 welders, it's all about the transformer.
auto diagnostics desk job available in Boca Raton area.
Job is probably still available for a technical support representative since I am now gone which means.............they don't have anybody within the entire company that is ASE certified or even knows the first thing about car. -
The gassers were.... 1st.......3.321 : 1 2nd.......2.088 : 1 3rd........1.308 : 1 4th........1.000 : 1 5th.........not listed I have a maxima 5 speed but the haynes manual I have only lists 4 of the ratios so it may be the ratios for a 810 4 speed....which should be a fs5w71a. Lots of bad info. in the haynes for this car which lists 1977 to 1984 years covered.
I had to do it Hetfield style including the "yeah" at the end of most sentences. Great album.......It almost made me switch over from Black Market Baby and the punk scene in DC to metal but the big haired metal chicks I love so much had not yet descended on the metal scene. Henry Rollins used to serve us ice cream back in arlington.
I doubt he needs that since the lobes of the cam are up instead of down when the rotor is pointed at number one...........unless his spark plug wires are not in the right holes.
Most of the time, that kind of tach behavior means you have a body ground issue.........in most every other car......maybe not in yours, though. It doesn't cost anything to connect a pair of jumper cables between a strut bolt and the engine to see if the problem goes away.
LOL at Shift00 making a medical conclusion from a picture. I was actually concussed at the time the pic was taken. I was sore all over but the next day I woke up with my right lower leg tingling and terrible back pain. The trauma caused swelling in my spine that damaged some nerves and I'm lucky I didn't wake up paralyzed from the waist down. The back pain slowly subsided in 3 years of me working out daily and the tingling only subsided after 14 years. Damaged nerves will many times repair over time.........a very long time........long enough that even though I now have what seems like full nerve action in my leg, I will have many more years before I undo the muscle atrophy that resulted from the nerve injury. If you ask me, $50,000 was not near enough. I also suffered a double hernia partially because the owner of the pathfinder I was test driving after service was very short and had things behind the seat meaning I was in an unusual driving position because I'm six five. Customers complain when you even move a mirror so I usually try to not move a seat because we had another technician who crushed a $10,000 briefcase when he moved the power seat back into it. I bent the steering wheel and the brake pedal because I was sitting at an a red light and had time to tense up as I saw the car coming toward the driver's door. Thanks for playing Shift00. I drive this turbocharged maxima all over the area soon to replaced by this M30 with L28et. Yes those are 1984 300zx 4 lug wheels with 215/50s that bolt straight on with no spacers and they don't rub though I should have gone with 225/50s since they won't rub either. I'll be taking it to moroso very soon with a for sale sign on it as it does the rocking horse down the quarter mile. Any west palm beach guys know what happened to the Z car performance shop that used to be part of the nissan dealership on military near southern? I'm out of words........I've used my daily quota. -
At this time, I work for nobody but I spent a long time wrenching nissans.......mostly Z cars. My last job killed my soul and I need to recover. That one pictured ended up on it's side during a nissan van demolition derby. Imagine a bunch of technicians who know there is a very large parking lot full of vans that will be going to crusher and you can imagine what kind of stuff went on. If they had bad shocks, they would do wheelies and stoppies. -
New Floor Pans and Frame Rails
HowlerMonkey replied to tonycharger72's topic in Fabrication / Welding
Sikaflex is good stuff. I used to use the 241 sikaflex at hatteras yacht custom yard and you had to be sure you really wanted whatever you bonded with it was in it's final place because you would surely never get it off. We had a guy bond teak to the top of the transom on a multimillion dollar yacht and he had put them such that the lettering was opposite of what the owner wanted. They had to cut it and re-glass the top of the transom because the owner came in after they pried it off and it took mucho glass with it. Nice build........I covet your rotisserie. -
This is one I've always wanted.
Excellent!! I'm glad someone else remembers that album. I sang that song last weekend after teaching a friend the riff because he challenged me that I couldn't sing "real metallica" and then went on to play riffs from the black album.
I haven't seen one since I prepped the last one for the crusher at our dealership (VOB nissan) in bethesda, md in 1994. I snagged about 20 primo captains chairs from these. They were so bad and that nissan bought them back from the customers because they would catch on fire shortly after being parked........not good if it happens in your garage. I did two campaigns on them that essentially replaced most every rubber part in the engine compartment including seals, pumps, and many gaskets and didn't pay jack ♥♥♥♥ under warranty. A year after doing the campaigns, we prepped them for the crusher as nissan made some good offers to get them off the streets. Yeah that's my dorky ass after finding a camera under one of the captains chairs and only half an hour after being broadsided in a pathfinder which eventually netted me a $50,000 settlement.......minus lawyer fees.
Tranny behind the LD28 maxima is a FS5W71b. If you want to sell off stuff you don't want out of that package, try link below. There are lots of very rare and specific parts on that engine and you might be able to fund the rest of your project. Of course there are guys who fit the diesel with a turbo and then put that combination into an early Z car which nets near stock performance and almost 40mpg. Might come in handy if gas goes back up to $4.00 a gallon again. http://nissandiesel.dyndns.org/index.php
Cam out of time 180 degrees? It might be pointing at cylinder 1 but I would pull the valve cover and see if the cylinder 1 cam lobes are facing up. If not, do what was suggested above by re-indexing the oil pump shaft.
It's getting difficult to find a muffler that..........muffles. Most companies cater to people who want to mount a rear muffler that makes the car louder than the stock iteration. Amazing job on getting clearance where there is none. Back in the early 80s, I used to run rotaries (RX-2 with bridge ported 13- and one had to run three mufflers to make the car tolerable without killing the power. On a "long primary" system (the collector is at the rear of the car instead of the front) we used two straight through bullet mufflers packed with stainless wool on the primary pipes and a huge honking rear muffler that cost a fortune.......I think it was called a "primaflow" muffler. The price of the primaflow was excessive so on later cars I made a "Y" after a certain distance of collected exhaust and ran two "turbo mufflers" side by side oriented 45 degrees for clearance issues (too tall when standing up). As I get older, I like my cars to make less and less noise. I also haven't had a ticket in 20 years which I attribute to super stealthy exhaust note. You should submit that design to borla and get some cash.
Interesting (Manual) Method of Driveshaft Balancing
HowlerMonkey replied to eec564's topic in Drivetrain
We used to balance plane props with nothing more than a fast strobe and a video camera on a tripod but the new digital cameras might work even better since they net a much clearer picture of each frame. I used to use a strobe type spin balancer (just the strobe and trigger) and mount the strobe trigger to the tailshaft of the tranny and then to the diff. Then all you had to do was have somebody up in the car run it at a certain mph and read which number you saw illuminated by the strobe to find the heavy side. Got the idea from watching Danny Arredondo using the tire spin balancer at Z shop of miami. The problem was finding the speed that worked with the balancer and the fact that a driveshaft shop can balance one infinitely better. -
The end result is that you have to change your driving style when comparing most locking type diffs to an open or VLSD diff. Most every locking diff will induce power-on understeer for the basic fact that most locking diffs will fight having both side wheels going a different speed to some extent when power is applied. While testing at any track with a carousel in an r200 equipped car, I've found that the VSLD to have the least power-on understeer but the stock nissan implementation will never carry one through even half a season of Improved Touring racing let alone a higher powered class and many VLSD only last a few laps in classes that don't allow a pumped diff. cooler. I'm sure there are some crazy expensive VLSD out there but I am not aware of them. They just weren't made for long term thrashing. With a VLSD, you can get on the power sooner while a mechanical locking diff. will require you to change your driving style in that you "re-index" your braking/turning/acceleration events to later in the turn to keep the power-on understeer from rearing it's head to the extent it either eats up front tires or hurts your lap times because you encounter understeer as you power out of the corner. This means a change from getting all your braking done in a straight line and powering out to braking deep and putting power down only after you are again going relatively straight. Then you've got the guys who use slip to point the car in while braking late and can get on the power sooner but that technique requires a lot more driver attention and is subject to being hard on rear tires and brakes. I am a lexus tech and lexus uses open diffs. and computerized braking schemes to control yaw and, as said above, will burn up brakes quickly on a road course........but lexus designed the system thinking of the average driver who got in over his head or ran into an unexpected change in road conditions. I'm not sure open diff./electronic controlled braking for yaw control will ever be ironed out for road racing because you need your brakes for..............braking and any braking usage beyond retarding the car's speed is counter productive to brake heat and wear.
I believe the one in the picture has a thermostat like the early rotaries I had in my RX2s. I think if you unscrew that bolt near the fittings, you should find a bypass/thermostat there. Back in the early 80s I had many a discussion on oil versus water temperature on Improved Touring RX-2s with the Kearneys who ran at summit point.
