Read with caution because as you can tell and hopefully already know, no two benches will give the exact same numbers, especially since the operators often dont follow the same procedure as another, and they are not listing the methodology used either (flow bore diameter, atmospheric pressure, etc).
The slightly higher flow of the Impy head, but lower compression and less timing your forced to use, do not make it worth it. A quick clean up in the bowl will get better than that, just dont go overboard if you dont have the experience.
You can convert to OBD I fairly inexpensively, and programming is cheap. I'm not sure where in CA you are, but if you needed a hand with OBD I stuff I could help you out provided you had Tunercat, or if you are semi nearby, or I know people throughout the state who also have experience tuning.
