6
Everything posted by inline6
I don't know how to calculate dynamic compression, if that is what you call it. But my cam has more aggressive specs than the Schneider stage IV: Intake Seat duration 320 degrees .050" duration 290 degrees Valve lift with zero lash .565" Hot valve lash .015" Net valve lift .550" Exhaust Seat duration 315 degrees .050" duration 274.8 degrees Valve lift with zero lash = .565" Hot lash = .015" Net valve lift =.550" I've got three options in mind for how to proceed now... 1. Send the head off to have the combustion chambers welded up. I guess I'd put modeling clay in one of the chambers and sculpt it to fit (represent the finished chamber) - so they can see where to weld. If I do this twice, I can calculate the finished chamber cc volume (immerse the finished piece in water and measure the volume), which will allow me to calculate final compression ratio before getting the work done. This would be nice - so as to confirm that I am going to land at the 11:1 I am shooting for. 2. Tell Dave Rebello I need domed pistons - something with a 12:1 compression ratio with my E88 with 45.6 cc chambers... specify the pin height I need, and diameter... And then when I get them, machine them as necessary to fit my chambers. 3. Mill the head a bunch - order flat top pistons (with adequate valve reliefs) and see if it runs worth a damn on 93 octane with this radical cam. This last option will sacrifice HP (without quench) I'm fairly certain. And, it may detonate, requiring the use of racing gas. Not cool because that stuff is expensive.
Hi Pete, What you say makes a lot of sense... I was talking with Dave Rebello yesterday and he we saying pretty much the same thing. But, I was running a F54 flat top block with the head previously (something like about 10.1:1, right?), with a Euro distributor - the Euro distributor advance spring(s) and the vacuum advance (in combination with a Crane Hi 6 Capacity Discharge ignition) with 17 degrees initial, and 36 total, and I had no detonation on the 93 octane we have around here. That was with a stock cam... Now I have this monster cam I'm about to use (HUGE overlap)... which is the same one Zredbaron is using. I dunno. Seems like I should be able to run 11:1, but I'd like to have some quench. Rough measure of the combustion chamber says that .080" off the head surface still won't give me any quench (squish) to speak of, yet the compression ratio looks like it goes up to near 11.5:1 at that point. I'm thinking 11.5:1 with no quench is going to be trouble. Ughhh. Why am I finding out now that the E88 is not the best head to use? Because of this, I am toying with the idea of creating a mold of the cyl head combustion chamber and seeing if JE can make something from it. Welding the head is another option, but my engine builder doesn't want to send the head off for welding... According to him, there is all kinds of badness that can happen: valve seats loosening, guides loosening, head shrinking, warping in all kinds of directions... If I had a job number for a JE piston that would give me some quench with an E88 head, I'd sure be happier. I'll be using the Kameari chain tensioner, so I shouldn't need to put shims under the towers. But that is a minor point. Rod stretch... I was planning to run .024" piston to deck. Yeah. That is what reading the forums here and having no real world experience of my own with building these engines will do for you. I'll be running about 7700 RPM max. Gotta make some decisions soon. G
Did a sonic test on my block and we won't be able to go to 89 mm as I had hoped. Based on the numbers, I'm looking at 88.5 mm max. That means the compression ratio is going to be too low for the cam (~ 10 to 1). So, I need to put a dome on the pistons. So, how do I do that? I can easily calculate how much of a dome I need (in cc's)... But, how do I specify such a thing? I'd like to go with JE... Have no clue how to proceed. I'm guessing that they have several L series pistons in their database, but I really have no idea how to specify exactly the contour that I need with valve reliefs, etc. Shooting for 11:1 compression ratio... Anyone know how I should proceed? How do I specify what I need to JE? Garrett
Still have this? Garrett
Any idea of approximate cost? I'm thinking the block would have to be shipped there (where the machining and liners can be done) and back? Am I better off (time and cost) searching for another N42 block... say from 75? Theory being that with production variances or more regular changing of coolant, perhaps I can find one with thicker (enough) walls? G
I dropped off most of the engine parts with my engine builder today. The block is an N42 from a 77 Z (had round port head). Quick measurements on the bore thickness in a couple of accessible areas make me think I won't be able to do the 89mm overbore. This is going to be a NA engine... but we measured .175" in one spot on the front cylinder (freeze plugs are removed). Back cylinder, where accessible was in the .2 something territory. It will be sonic tested in the coming days. From some threads I found here, the guidance seems to be .125" thickness for cylinder walls. Anyone have thoughts on this? I hoped to go 89mm on the bore with this block. Now, I'm thinking 88.5 will be more likely. And that might put me at .115". G
I got it from Kinetic Sunbelt in GA. It has a lot of duration. Based on some info in the forums here, Sunbelt was one of the last who did any L series development with the cams. That lobe profile is assymetrical, and designed to work with valve springs that only have 190 lbs at .550" (max) lift. At installed height, spring pressure is only 56 lbs. Less spring pressure (if adequate) should translate to more power and less stress on the valve train. Max rev dictated by the springs is 7700 RPM. Intake Seat duration 320 degrees .050" duration 290 degrees Valve lift with zero lash .565" Hot valve lash .015" Net valve lift .550" Exhaust Seat duration 315 degrees .050" duration 274.8 degrees Valve lift with zero lash = .565" Hot lash = .015" Net valve lift =.550" G
***********Edit: Moved the following post to a separate thread... I dropped off most of the engine parts with my engine builder today. The block is an N42 from a 77 Z (had round port head). Quick measurements on the bore thickness in a couple of accessible areas make me think I won't be able to do the 89mm overbore. This is going to be a NA engine... but we measured .175" in one spot on the front cylinder (freeze plugs are removed). Back cylinder, where accessible was in the .2 something territory. It will be sonic tested in the coming days. From some threads I found here, the guidance seems to be .125" thickness for cylinder walls. Anyone have thoughts on this? I hoped to go 89mm on the bore with this block. Now, I'm thinking 88.5 will be more likely. Garrett
Looks like I only have one of them. Pretty good shape. Painted with epoxy primer and then black back in 1994. Both pins are perfect and there was little if any metal corrosion. Garrett Edit - by the way, I think they are side specific. This one has an R on the backside.
Yes they say "240z", came from my 12/70 car. I believe all of the pins are there. Let me see if I can find them. Garrett
What condition is acceptable? I think I have some of the quarter panel ones, but the chome is maybe not there anymore. I painted them black and used them for a while before I bought and used new plastic ones.
Yeah, spensive. A little less than my first car cost me. Which is really insane... Took my N42 block to be cleaned and sonic tested last week. Should get it back this week. Still looking for some Glyptal if anyone has some sitting on a shelf. Otherwise, I guess I'll have to buy some new and then what is leftover will sit on my shelf... probably until I'm dead.
The crankshaft has arrived from Castillo's! Stroke came in a little less than I had hoped (3.165 instead of 3.188), but it was dictated by the factory stroke being a little under spec as well as tolerances when stress relieving the crank which happens during rod journal resizing. As was mentioned before, it probably isn't worth the bucks spent for the small amount of stroke increase I have ended up with. However, those of you buying Rebello 3.0 liter stroker motors are pretty much doing the same thing. Here are some large pics:
I took these off of my L28 with E88 head very recently... They are quite nice. They are the 4 screw (early) version that is desired. I had them rebuilt in 1994 with new Nissan OE: thottle shafts, thottle plates, throttle shaft bushings, jet nozzles, screws for domes, screws for float covers, and the hoses that go from the float chamber to the nozzles. I replaced the stock N27 needles with the "SM" needles which are the hot ticket for the L28 engine. I put some attention to polishing the domes some time ago. That is why they look pretty good. They could use a maintenance polish to make them really shine again. While replacing one of the shaft bushings during the rebuild, the aluminum around it broke. This was expertly tig welded (and run on the car since 1994 with no issues). Also, one of the air filter tabs was tig welded and redrilled at the same time. They do have some miles on them - probably 70k since the rebuild, but they work great. I have the heat shield also... If you think you are interested, I will post a few more pics. I was getting ready to sell them on eBay... I'm not sure on pricing because I haven't looked to see what they are worth yet. I know that Ztherapy ones are like $600, and these obviously aren't anything near that nice. My rough guess is $250, but let me look around and see...
Did you get some of these? I have a nice set of L-28 stockers from an N42 motor. Let me know.
Hmmm. Hadn't thought to use the carbide cutter... Thanks for that. A great example of when two heads are better than one. As for the rods, I am using Eagle brand for a Toyota Celica. My engine builder says they are ok, but not as 100% ready to go as others. That is probably why they tend to be more affordable. I forget the weight, but something like 560g vs. 710g stock - I think? I will be taking the block to my engine builder after I finish removing the casting flash. I don't anticipate any issues with the block... I better not have any that is, because it would be wasted time and effort to remove the flash only to find out that I should find another block. He'll spec out the block, proceed with mocking up crank and rods to see what we need spec-wise for the pistons.
Crankshaft should be arriving any day now. Can't wait... In the mean time, I've learned from reading the forums that combustion chambers should be polished - not glass beaded! So, I did that. You can see the undercut on the side of the chamber here. I was copying a 510 head I had done by Malvern racing long ago. I also learned from the forums that the N42 block is the one to use for 89 mm bore. Wow. I was going to use my F54 block. Luckily, I still have my N42 block from an earlier motor. How about this casting flash??? I spend a couple of hours with an air powered hand held belt sander... belts are 3/8" wide by 13" long, one of my latest tool aquisitions. Going through belts rather faster than I had hoped. I am using Norton 60 grit. Looks like it is going to take about 5 to do most of the inside of the block. Anyone have some left over Glyptal on the shelf? I don't think it takes a full quart to do one block, but that is the only quantity I can find for sale.
Are those carbs modified (tapered bores)... or standard bore? The openings look bigger than original. Also, why did you make an impression of the pistons? That was just to get an idea of the volume of the pop up?
I'm no engine builder, but I think it is somewhat common that bores are out of round by .001" even when freshly machined. At least, that is what I recall a performance L series engine builder telling me once. I recall him saying something about his cylinders being rounder than many because of his equipment (and something about honing technique) and that because they were rounder, engines he bored would break in quicker than some. So, I'm sure one of the more qualified will weigh in (and their comments should be worth more than mine), but I'm thinking all you may have to deal with a slightly longer break in period. Other than that, with fresh hone and new rings, I think you will be fine.
Yeah, he doesn't have what I need. I'm in no hurry. I've got 3 carbs that will make a good triple setup. Just need a couple of parts to finish the rebuilds. Will consider whatever people have. I could use a usable main body... Have two side feed float covers with one top feed... Anybody have some with age, heavy use, etc. just kicking around, let me know. G
I need a couple of Mikuni parts... I believe these are the same for 40 and 44. 1 float height/support spring - number 16 in the Mikuni manual. 1 throttle shaft spring - not labled separately in the manual (goes on the throttle shaft between the two bores. Could also use left side (when face bore entrance) throttle bracket, spring, etc. Could be interested in some 39 or 40 chokes as well (these are for the 44's)
I don't really think I need a full quart (which is how it is sold) to do one block. Just wondering if anyone has some usable Glyptal on their shelf that they think might outlast them before they ever use it again. Let me know.
I have a bunch of LD28 parts I'm looking to get rid of... and I'm in Barboursvile, VA. Let me know if you need anything (the crank is gone).
Nice. That makes for a really nice rod to stroke ratio. Pin height on those pistons is going to be what... about 25mm? G
