Kevin.pk
    4
Everything posted by Kevin.pk
  1. Looks good! I just picked up the same battery for my ls1 swap and was looking to mount it in the same spot. I modified my battery tray area when I did rust removal and welded up all the holes in engine bay, but may try and mount it in wheelwell still.
  2. almost two years ago... finishing ls1 swap now.
  3. I've got what ya need.... Its kind of heavy but think it should fit in a $15 flat rate box through usps. $25shipped and its yours.
  4. I just ordered a Odyssey pc680 and going to likely mount it exactly like you, behind the passenger seat... or possibly underneath it, if it'll fit. I've heard mixed reviews about the PC680, but figured i'd give it a shot anyways. Driver's manifold modified. I originally did the passenger side in 2.25" but this is 2.5" with a ball and socket flange. I'm going to pull out the passenger side and re-do it. It'll be a tight fit, but I should be able to get it fitted. may just get a v-band flange for the other side actually. Need to order up bends for the rest of the exhaust and also need to get welding gas, I ran out. going to get these ceramic coated when I get a chance too.
  5. Tach Installed New brake fluid reservoirs Passenger floor board rust repair and transmission mounting point reinforced with 16 gauge. Trans mounted but still need to coat the under side where metal was replaced.
  6. Chassis wiring reconnected New brake line bent New front fender. It needs a little bit of body work, but virtually no rust. Fan wiring done. ECM will control the Taurus fan with this Volvo seam sealer Starter and alternator wiring are done.Still working on where I am going to mount battery. Cable to the left is just for hooking to battery to test things. Drive shaft is in. Heater lines blocked off. Drilled new hole on throttle bracket so the cable has a straighter shot at the throttle Rubber shift boot installed Dash is back in. Driver's brake reinstalled Upper Radiator hose Steam vent routed to water pump
  7. I wouldn't say they are indestructible. I had the same thing as calpoly-z happen. I went to tighten lugs on the rear passenger side and the whole strut assembly came down. The rubber tore apart with a fairly minimal amount of torque.
  8. Thanks, Me too.... JTR Intake piping done. Just need filter and a couple more clamps. PCM mounted. Fuse block mounted up on the pedal box. Passenger manifold mocked up. Needs to be full welded still. Bascially just chopped off the flange and welded on an extension. Waiting for drivers manifold to ship in... its going to get some similar cutting done. Already made new passenger front brake line that will go along the top to the frame rail. Rear brake line will just be bent out of the way of the exhaust
  9. Looks like the manifolds in the in first post are custom.... Full build thread for it though... http://forums.hybridz.org/index.php/topic/56956-the-turbo-is-coming-along-pictures/
  10. I should be up and running in the next couple weeks if you want to check out a completed swap.
  11. Engine going back in after bolting up transmission Shifter placement couldn't have been better. This was kind of lucky since i never mocked up the engine with my mounts with a t56. Alternator mounted and clearance looks good. Bolted radiator in. Upper hose is going to be close. Might just try and chop up f-body hose and splice it. Lower hose fits perfectly overview
  12. Done for the day. Got wiring loosely mocked up.(PSI Conversions Harness) Brake booster/master cylinder installed Tilton 7/8" Clutch master cylinder installed Lokar LS1 Black braided stainless Throttle cable installed.
  13. Bringing the Z back from paint. Pushed it up in to the garage. Engine in new home. Working on getting some stuff mocked. Found out i need to slot the holes for the mounts a little more... I'll have to borrow a camera to get some better pics sometime... my cell camera is lacking.
  14. Just got home from painting.... went with the Audi Daytona Grey Pearl Effect color.
  15. wet sanding. found a couple small things that i need to touch u,p but all-in-all it looks pretty decent so far. Scheduled to get it in my friends booth early next week and while its there I'll bring in the donor and pull the engine/trans.
  16. Finished with the engine bay body work... Primetime!
  17. Done with everything to do with fuel system except wiring the fuel pump. Hatch and taillights put back on as well. Seam sealed and painted. Starting to look like a car again... need to get flip down license plate bracket still Haven't done much with the engine bay.. going to try and get it mostly finished up this week and then hopefully to my friend to paint it in the next week or two. While its off to paint, I'm going to bring in the donor vehicle and yank the engine and trans out of it.
  18. YAY... New compressor.. need to move my retractable air hose and get a regulator on it.... just got it today. Recessed box all welded up and some primer on it. still need to weld the tube for the filler neck in place. New hatch deck welded in. Welding still in progress. Fuel line ran to the front of the car. The metal line only goes about a foot under that frame piece and then it is nylon tubing the rest of the way covered in some closed cell foam. And toys... tilton master cylinder, belt, pulley, and clutch hydraulic line. and.... I've got a donor car. 01 YAY... New compressor.. need to move my retractable air hose and get a regulator on it.... just got it today. Recessed box all welded up and some primer on it. still need to weld the tube for the filler neck in place. New hatch deck welded in. Welding still in progress. Fuel line ran to the front of the car. The metal line only goes about a foot under that frame piece and then it is nylon tubing the rest of the way covered in some closed cell foam. And toys... tilton master cylinder, belt, pulley, and clutch hydraulic line. and.... I've got a donor car. 2001 Camaro LS1/rebuilt t56 with 75k miles on engine, 15k on trans. Fun stuff should start happening soon.
  19. I'm just in Plano and working on a ls1/t56 swap. I had a sbc previously. My problem is I got distracted doing 100 hundred other things the car needed. Need to get my engine bay painted and should be dropping motor in the car within a month.
  20. If I ever get this thing back on the road, definitely. lol. ____________________________________________________________________ Well... its been a while.... Started working on the car a little bit after work each day this past week. I have pretty much all the big fab work for the fuel tank install and fuel filler relocation done. Basically just a bunch of welding and some grinding left. Small box I made to recess the fuel filler cap behind the license plate. Piece of exhaust tubing cut to act as tunnel for the fuel filler to pass through and keep it all separated from the interior. This is the filler tube coming up from the tank. New sheet metal to cover the top of the fuel tank up.
  21. http://www.4moores.com/280z/files/JCI%20Install%20Update%202.pdf or ya know... just look 4 posts up where the entire thing is posted.
  22. I'd imagine the threaded potion in the rail is a NPT size. Most likely 3/8" NPT.
