Kevin.pk
    4
Everything posted by Kevin.pk
  1. Got it off Amazon: https://amzn.to/4aS32Br And picked up a male pigtail off eBay: https://www.ebay.com/itm/134129914749 I actually replaced the wiper arms too. I used 93 miata arms which bolt up to the stock datsun wipers mechanism. Passenger arm is a little long so I may shorten it. For wiring, I followed this guide: https://www.electronixandmore.com/resources/automobiles/datsun/index.html Note this is very specific to the later wiring for 1978(maybe 1977 too) and would not be applicable to earlier years.
  2. Well... its been almost a decade... better get restarted... Started messing with a new front turn signal. Cutting up airdam brake ducts and integrating a turn signal from a late 90's integra. I flipped the turn signal to better match the contours at the bottom of the airdam. What else is done or in the works... New interior - dash, center console, door panels, seat, carpet, gauges, sound deadening Vintage air HVAC control panel upgrade Coolant and heater hose upgrades Hydrualic hood hinge setup Silvermine Power steering Apex rear strut bar Subframe connectors Passenger seat - corbeau fx1 pro Vinyl wrapped hood Sanded/polished exterior light lens Exhaust work.... again and still Mfactory lsd T3 front sturt bar T3 harness bar Honda wiper upgrade LED headlights Skillard front lip More posts to come soon.
  3. My car is a 78, so it originally came equipped with cats. I've had a couple inspections where they have said, "you know technically you are supposed to have catalytic converters" but that was about it. Only a visual inspection, definitely no emission testing. For a 72 you are definitely free and clear. All they do is make sure the lights, horn, turn signals, parking brake, and brakes work.
  4. Condolences to his friends and family. I never met John and don't know that I ever even had a direct conversation with him even over the internet, but I felt like I knew him just by reading his wealth of knowledge on here for the past 13 years I've been a member. His presence will be greatly missed. The z car community and the world has lost a great person indeed.
  5. I've been stock piling more parts than I have been installing them. Parts waiting to be installed: Corbeau FX1 pro 5 point harness Speedhut Oil pressure guage Speedhut Water temp gauge New exhaust pipe to get the exhaust tucked a little higher. Parts actually installed: 240z Front bumper Soooo here is a pic with the new bumper installed...
  6. Front isolators for the 240z and 280z are the same.
  7. I realize now that I should have said "new to me" instead of "new" fenders. I picked them up used off craigslist, they just happened to be a similar silver.
  8. Quite the contrary, where do you think we source our engines from
  9. Finished out the Camber plate install. Bought a a pair of new-to-me fenders off craigslist and headlight extensions from a member. Looking at paint options now. 255/40/17 Toyo R888 put on the back
  10. Can you drop the engine in by going sideways over the fender instead of from the front. This is how I have pulled my LS1 and installed a couple times, but without the trans attached. Have to remove wheel and carefully place some jack stands so they wont interfere with the crane though.
  11. Still no track time on the car since the install. Probably have a few thousand miles of street driving now and it has all worked flawlessly. Great kit!
  12. Looking for the exterior scoops/fender extension. Email sent to zedsn.
  13. Looking for metal headlight buckets. Need both drivers and passenger side.
  14. Installed one of the T3 Camber Plates. I made rough cutouts with a drill and hole saw bit. Then followed up with a mini hacksaw and then finally a lot of filing. During cuttting. Mostly completed. Need to do a little more cleaning up and then throw some paint on it.
  15. The reason for the specific years is because camaros and transams from 93-97 with the LT1 also came with a t56. The LT1 style T56 will not work on a LS1 with out modifying it. I don't know all the detailed differences, but know the input shaft is different. Yes, the main reason for the LS1 T56 out of a 98-2002 F-body is because it positions the shifter in the correct spot. The t56 came in everything from vipers to mustangs to aston martins, but the one you want is out of a 98-2002 f-body because no modification need to be made to the trans and because the shifter position is correct for a S30 z car.
  16. Correct. The 98-02 T56 puts the shifter further back. It is the one you want for swapping into a Z. 4l60e is the stock automatic trans that came with the LS1 on the 98-02 f-body. It will work. There are always other options though.
  17. The original one you had in the car is actually a larger 280z booster that a previous owner may have installed at some point. The smaller booster is actually correct for the stock 240z booster. http://forums.hybridz.org/topic/99516-240z-vs-260-280-z-pedal-assemblies/?p=933168
  18. There isn't a coyote 5.0 swapped 240z that I have seen/heard of yet. You would be jumping into uncharted territory. If you are not mechanical and are doing the swap yourself, this is probably not the route you want to take. If you are looking for a daily driver, consider that a 2014 mustang GT is going to be wayyy more comfortable than a 40 year old datsun. Also don't expect a final weight near 2300 lbs. See this thread for some basic discussion on the swap: http://forums.hybridz.org/topic/103409-coyote-motor-in-240z-thoughts/
  19. It is an LS1. There are several variations of the t56 transmission. The corvette had a T56 transaxle which would involve converting it to a traditional transmission that bolts to the back of the engine. It sounds like you only have the engine though. Assuming you want a manual, the T56 you want is out of a 98-02 Camaro (Z28 or SS) or Trans Am. This is the most common manual transmission for LS1 swaps.
  20. Installed a front tow hook. Purchased this: http://www.amazon.com/gp/product/B00DJSRSSM/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 I think the the threads in the the hook are 12x1.75.The part that threads into the black part of the hook was discarded. So I went to to the local hardware store and got a long 12x1.75 bolt and some 1/4 steel plate. Cut the steel plate to size 4"x2.75" and drilled two holes for mounting it to the stock front bumper location. Welded the bolt to the steel plate and done. Finished product before paint: Hook can be oriented in any direction since it is screwed in place. I chose to have it swing left and right because it can fit in the space to the side of my grill. I don't know how much I trust the strength of the $11 piece of red aluminum but it hopefully will handle pulls on to a tow bed should I ever need it. I may search for an all steel ring that will screw on to the same threads.
  21. only carbon fiber G-nose i have seen is cobramatt's It says he got them from "Brian Kostrba at Z Car Customs in Oregon" http://www.zccjdm.com/ in this post: http://forums.hybridz.org/topic/99357-my-dream-ls7gtzproject-underway/?p=1095846 Pics of completed piece http://forums.hybridz.org/topic/99357-my-dream-ls7gtzproject-underway/?p=1100764
  22. Keep it up. Fun to watch all the updates and the progress.
