4
Everything posted by Savage42
				Lightweight, longer lasting, better performing, lithium battery upgrade
Savage42 replied to Savage42's topic in Drivetrain
Absolutely. It's really the cars with Nav, security system, multiple computers, etc. that have a huge draw and parasitic draw that are the cars that need a big battery. The only reason most cars have 40-50 pound batteries these days is to be able to sit for a few weeks with all the draws and not kill the battery. For older cars like ours, which don't have much of a draw at all, it's all good. Just don't sit somewhere cranking the stereo for an hour without the car running. -
I would say most but V8 sedans that are heavy with electronics, but outside of that, you are right. It's just a matter of knowing how to maintain the battery if not a daily driver. That's about it. Now back to watching John Morton run the 240Z and several other Z cars here at Road America at the Runoffs. Watch it live in 5 min on www.speedcasttv.com I'll be ready to get back to Florida tomorrow, as it's dang cold here! -
HowlerMonkey, the battery I reference is 100% compatible with all standard charging systems. A lithium battery has a testing voltage is 13.8v (lead is usually 12.8v) and typically alternator output is 14v. That being said, there is no way for the battery to deliver higher than 14.1v (in regards to the issues you referenced), so unless the alternator puts out to much voltage, it won't be an issue. Djwarner, this battery is much more reliable and robust than any lead battery. When it comes to extreme use/conditions, it will outperform lead batteries by 5-10 times the life cycles. In a daily driver, in temps ranging from cold to hot, you should expect to get the 5000 cycles, which is 10+ years. For reference, Corvette Racing was one of the first teams in the American Le Mans to use a Braille lithium battery. They used to go through lead batteries every couple races (6 per car per season) and they just sent back a pair for testing. They have been run hard in racing conditions for 3 years and when tested, the specs are actually 3% better than when they left the facility brand new. That is the kind of abuse, heat & vibration that will never been seen in a street car. Hope that helps. -
This is the smallest and least expensive model designed for an automotive application. The next smallest model in the GreenLite line is a 2.3 pound G9 that is used in powersports/motorcycle applications up to 1200cc. There are smaller & lighter models in the MicroLite line, but then you are looking at carbon fiber casing and $1000-1250 bucks. By going smaller (the GU1R is already 80% lighter than the stock battery), you start working the battery harder and out of spec, so while it may work for a while, it will cause premature failure and only get a couple years out of it instead a decade or more from a battery made for the application. To address your comment about CCA specs, let me educate everyone on exactly what those ratings mean. The CCA & CA ratings were developed decades ago for flooded lead-acid batteries and is a rating that does not apply to lithium batteries due to the dramatically different delivery of energy compared lead. CCA - a test to determine the amount of amps a battery will deliver sustained for 30 seconds at 0 degrees. CA - a test to determine the amount of amps a battery will deliver sustained for 30 seconds at 32 degrees. So, unless you have an ancient motor that requires cranking for 30 seconds to start and are in sub-freezing temps, it is a relatively irrelevant rating in today's engines. You will see that all of the batteries on the Braille site, AGM or lithium, have a PCA rating, which is Pulse Cranking Amps. PCA - a test to determine the amount of amps a battery will deliver sustained for 5 seconds at 70 degrees. This is the most accurate rating that applies to starting events in modern engines. Another cool thing about lithium is that it performs better is cold temps. They will often work better in cold temps down to -30C (22 below zero F), as they self-warm when used. The first crank may be a little weak the first time, but will get stronger and stronger as you pull on the battery. Another method is to turn on the headlights before starting for 30-60 seconds to warm it up and you will get full cranking power, same as in warm conditions. The GU1R combo has a LIST price of $629.99 plus shipping. For a limited time, I can set you guys up with the combo (charger lists for $104.99 itself) for $549.99 plus shipping and throw in a universal FRP mount kit that has shorter j-hooks if you are mounting in the stock location or relocated but still using a j-hook setup. (kit retails for $20.99) http://www.braillebattery.com/index.php/braille/product_batteries/gu1r_combo http://www.braillebattery.com/index.php/braille/product_accessory/universal_frp_kit_8_j_hooks -
Since I've had a few technical questions and I know that there are more than a few "tech geeks" that would like more info in that regard, here some some stuff to add. Charging: Braille lithium batteries are 100% compatible with standard charging systems. As long as there is an output voltage of 14 volts (max of 14.8 volts), the battery will stay fully charged. External chargers: People often ask if they can use their lead battery charger and while the answer is "yes", it is not recommended in order to ensure maximum performance and life of the battery. (not to mention warranty) The main difference is that lead chargers typically have an output voltage around 13.6 volts and charge at a pulse rate as to keep the battery from "cooking" since they are limited in the amount of current they can take without overheating and being damaged. Some lead chargers also have a desulfation mode to knock the crud off the lead plates and since lithium doesn't have lead, it can potentially damage the battery. Lithium chargers put out a full volt higher at 14.4 volts and at a constant rate since they can take much more than lead. One example is where the Formula Atlantic National Champion runs the 6 pound ML20C. Those cars run all the engine management, data logging, paddleshifters, fuel pumps, etc. for a full half hour and do it without an alternator. The superior electrical delivery of lithium makes a dramatic improvement, especially in the paddleshifting, which is solenoid operated. (as reported by the team) You can throw a 25 amp lithium charger on that little battery and fully charge it in about 20 minutes with the battery handling that type of use (or abuse) for many years. Lead batteries start losing performance and capacity very quickly in a "total loss" application like that. The most commonly used lithium model in the LMP 1/2, GT cars in the ALMS, every DTM & Super GT cars and others is the 8.8 pound B128L. Another cool benefit of lithium and it's higher capacity and quicker recharging is that race teams can use it for alternator strategies, typically setting up a "push to pass" button or alternator cut-off at full throttle and then kicking back in at all other times as a sort of "regenerative charging" setup. If you look at "Useable Power Curve" pdf, you will see that in high draw events, lithium delivers a stable 13 volts all the way to nearly 90% discharge of the battery where lead batteries will show a linear drop in voltage and will hit the 10 volt threshold (where most cars will just shut down) at 40-50% discharge. This is why lithium also has a LAh (lithium amp hour) rating, which is a lead-acid equivalent needed to deliver the same run time in high draw situations. Lastly, if Peter Brock endorses and sells Braille Lithium, it has to be "the bomb"! -
	Hey guys! I just thought I'd pass along some "real world" facts about the battery upgrade I did several months ago and will put the same battery in my Z when it gets to Florida next week. I don't want you to think that this is just some "marketing hype" or anything, as I just wanted to pass on some information that some of you might find useful, especially those who are all about getting the most performance out of our cars or maybe just tired of battery issues. As Director of Motorsports & OEM Programs at Braille Battery, I thought I'd take it upon myself to test a new lithium battery that the company debuted at SEMA last year and won a "Best New Product" award from Racecar Engineering magazine. This new model (Braille GU1R Lithium) is a "consumer market" product that was designed specifically for the "Import Tuner" crowd. It is a 6.6 pound battery with nearly 950 cranking amps and is ideal for 4 to 6 cylinder daily driver/track cars and even small block V8 race cars. When my OEM Group 49 flooded lead-acid battery had "given up" after 6 years in my 2000 BMW 540i 6-speed with a 4.4 liter V8, I figured I'd test the limits of this new model by replacing the 53 pound monster with the 6 pound lithium unit. I tested the car and it takes roughly 400 amps for roughly 2 seconds to start the car, so the battery really isn't working too hard to do that. In fact, the car spun up and started noticeably faster with the lithium battery than the lead battery. We had been getting data from the factory Corvette team in the American Le Mans backing the fact that since lithium delivers a higher, cleaner & more stable voltage, they had seen: quicker starting (especially in hot starts during pit stops), improved engine management and data logging performance, less horsepower draw from the alternator due to efficient charging (5 times faster than lead), which doesn't include lasting 3-5 times longer than a lead battery and signficant weight savings. I've had the battery in the car for 3 months now and it's been flawless and I did notice smoother and better acceleration with the lithium unit. Everything electric works better (fans, pumps, etc.), as it's like switching from pump gas to race fuel for the electrical system. Now, just to give you more information specifically on Braille's lithium technology, Braille was the first company to bring to market a 12 volt lithium starter battery almost 5 years ago. Currently, Braille lithium batteries are used in every Indycar, every DTM (German Touring: Audi/BMW/Mercedes) and SuperGT (Lexus/Honda/Nissan/Subaru) car, every Le Mans Prototype (P1/P2) and GT car (including factory Corvette, Viper, BMW, Porsche) in the American Le Mans series, most of Formula 1, top teams in Nascar, drag racing (16 volt model), off-road and so on. The product was designed for the extreme abuse and performance needs in racing and that development & construction goes into every model produced today at the facility here in Sarasota, Florida. Anyway, this battery is roughly 90% of the performance of the carbon fiber ML20C lithium model used in NASCAR, Pro Mazda & Formula Atlantic championship cars and so on, but it's 1/3rd the price. The ML20C is only 6 pounds, is smaller and has a little more power, but you can't beat the "bang for the buck" with this one and is a quick way to take 30-35 pounds (or 47 in my BMW) out of the car and get the electrical performance benefits. The other benefit is that lithium will do 5000 cycles, which is 10 years in a daily driver and 15+ in a weekend warrior/track car. The other benefit is that lithium does not self-discharge like lead batteries. If there is not draw on the battery, they can sit for over a year and still have over 13 volts to start the vehicle. I just got a call recently from Rhys Millen Motorsports and their guys pulled out the "spare" lithium battery that they go 2 years ago that had been sitting (new in the box) in their parts cabinet and it still registered 13.5 volts! We had another parts truck pull one that had been stashed away and was 27 months old and it was at 13.4 volts. Pretty cool. The ONLY downside (besides the extra cost on the front end, but will save you money in the long run vs an Optima), is that if used in a modern car (like my BMW) or in a car that has extra accessories/alarm/etc, the battery just has to be maintained a little differently. We recommend using the 2 amp lithium charger if the car is going to sit for more than a couple weeks, at least for those of us with modern electrical & drivetrain upgrades. In a more stock Datsun, the only draw may be the clock, so it could sit for a long time if that is the case. It obviously isn't going to be able to sit for a couple months without a charger like the 40+ pound lead batteries that most of us have or do use. (ie. Optima, etc) So, if any of you are interested in this (or other) lithium model or one of our lightweight AGM batteries (to at least shave some weight), I can hook you guys up with a club discount and can put something in the Vendors section for that. Just thought I'd share my experience, as I had a new yellow top Optima go bad from sitting too long without use or put on a charger and it sucked to have a $200 boat anchor sitting on the shelf. Now I know that if a lead battery is going to sit in a car (disconnected) or on a shelf, make sure to give it a "top off" charge every few months, as they self-discharge 5% or more a month, so it can go dead in 6 months to a year if just sitting there depending on several factors. (heat, capacity, etc). Hope that helps. For now, I'm anxiously awaiting the arrival of my Z on the transporter so I can go terroize a bunch of Porsche, Corvette and other sports car owners at Sebring, Road Atlanta, Barber and other tracks where they hardly ever see any old Datsuns, period! Usable Power Curve.pdf
	I believe Horsepower Freaks in Portland has a dyno and they do quite a variety of car builds. It's right over the bridge from the other one, so worth checking out.
	You are good to go. Only have a couple left and that will be it. Glad to help out.
	Got you covered.
	I still have these on the shelf if anyone is interested.
				LSx s30 Longtube group buy thread
Savage42 replied to 1 tuff z's topic in Gen III & IV Chevy V8Z Tech Board
Are there really more LSx powered 240SXs out there than Z cars? http://www.motoiq.com/magazine_articles/id/2838/hooker--ls-engine-swap-headers-and-mount-kit-for-nissan-240sx.aspx -
				240Z Rack in 280Z, Upgrade?
Savage42 replied to m1ghtymaxXx's topic in Brakes, Wheels, Suspension and Chassis
Well, you got part of it right. The 240 rack does indeed have a quicker ratio, that much is a given. The only difference in the rack itself (between the 2) is that the 240 rack has aluminum spacer/mounts compared the 280 rack, which uses larger bushings since it doesn't have the aluminum spacer/mount on it. The rest of the rack is the same, so there is not weight savings to be had. You just have to make sure you the the correct rack bushings to match whichever rack you use, but it is a direct bolt-in swap for quicker steering. That is all. Hope that helps. If you want quicker & lighter steering, look at the electric power steering setup. -
	Yes, it is the custom bracket, but it is made of stainless steel and that price includes shipping.
	Bump! Still have them in stock. PM me if you want one. Thanks.
	That would be great. Thanks!
	Hey Guys! I was helping a local Z owner with a '77 280Z upgrade the bushings on his car. The rear control arm bushings were totally gone, but the rest of the job went according to plan. When I got to the front, the driver side main bolt holding on the control arm was seized into the sleeve in the bushing. The only way to get the arm out was to cut the bolt on both sides of the arm. That was easy enough, but now I need a bolt & nut. Does anyone have one laying around that I can get? If so, how much to get it to me in Sarasota, Florida. I appreciate the help.
	Not quite. If you look at the pulse amps, they are significantly higher with the Braille, it have tested both. Just like Johnson Controls makes batteries for 20 different companies, an Optmia has a different construction than Die Hard, Deka may be the constructor, but they are made to a different spec. The 3121 you have is a rocking battery and have seen them in many a Corvette! The Corvette Factory team in the American Le Mans Series has run Braille batteries (the 3121 and now lithium) for many years. Performance is worth a paying little more, just like tires. With all the electronics on modern cars, the power supply is becoming more critical and now batteries are a viable performance upgrade.
	The Odyssey PC680 weighs 15 pounds and pulses out 680 amps. As a comparison, you can go with this one, which also weighs 15 lbs and pulses out 1067 amps and has 20% more capacity. http://www.brailleba...batteries/b2015 My car is getting the lithium equivalent, same size, but only weighs 6 pounds, pulses 917 amps and has 3 times the capacity. http://www.brailleba...batteries/ml20c The downside to either smaller AGM battery is that if the car sits and is a "weekend warrior" vehicle, you will typically get 1-2 years out of them. In a daily driver, 2-3 years, if you are lucky. AGM batteries self-discharge 3-5% a month all by themselves, which is why they will go flat all by themselves in a matter of weeks if a charger isn't left on them. Lithium discharges at less than 1% a month and with 3 times the capacity, they can sit for months without a charge and still have high voltage and most of the capacity. The lithium battery will also last 5 times longer, delivers higher/cleaner voltage, charges 5 times faster than AGM (so less HP draw from the alternator) and significant weight savings. It's the best of all world, other than the initial cost. The ML20C is the race spec model, but Braille will be coming out with a G20 and U1R (Miata size) model for under $499 in a couple months that will weigh less than 5 lbs, which will be a cost effective upgrade over the long haul. Here is a video of the ML14C (4.5 lbs) starting a Dodge Cummins turbo diesel truck, just as an example. You will start seeing lithium as an optional battery in many cars in the very near future for several reasons.
	Those whale tails do bad things at high speeds. The car gets light at high speeds without one, but it actually creates more front lift. I also saw one where the tail actually bent and nearly ripped the rear hatch off the car. That much drag also won't help with fuel mileage. Just my 2 cents.
	Guess I should have specified that. I put several in different 510s, so that's what I always had around. Good to go!!
	I ran one of those diffs in my 510 with a VG30 turbo for many years with daily driving, autocross and hillclimbs without an issue. Torque is what kills them and I was putting out roughly 400 ft lbs of it. You will be fine. A friend of mine ran one for years with a VG30DETT and no problems. Definitely worth it over an open diff!! Just my 2 cents.
	The slot design has nothing to do with rotational direction of the rotor, as they just let the hot gases between pad & rotor surface escape. Now the vanes (slots in middle of the rotor) come in direction and non-directional variations, so that would have an impact on which side the rotor should be on, as the directional vane rotors direct airflow through the rotor..
	Sure, I'll get it done for you. On the Porsche GT3 that we treated brakes for (previous post), we now have 5 track days at Sebring, 1 day at Daytona and 1 day at Roebling Road.......they brakes still look just about new. We have a 2 day event at Road Atlanta this weekend and then another 2 day event at Sebring in 2 weeks, then we will pull the pads & rotors to measure wear. Needless to say, it's a fraction of the non-treated brakes that have the same use. Stay tuned for pics and info in the coming weeks.
	You just need a set of stub axles from a 510. Shouldn't have a problem getting them. I did this swap back in 1991 when nobody knew if the stubs would swap. You are almost there!
	I put an R160 3.70 LSD into my VG30ET powered 510 and it's lasted a good decade. It had custom exhaust, euro cams, Wolf ECU with 300ZX wheels. A friend also ran one behind his VG30DETT for many years w/o any issues, as well. If you can get one for a good price, it's worth a shot. There is one in my other 510 that I put in back in 1991 and the diff was out of an '88 XT turbo. That car had an L16, L18, L22 with Electromotive/TMW induction and then VG30 for that last decade and the diff is still going strong. Would I put one in a V8 Z? Nope, but they sure seem to stand up pretty good to most 4 & 6 cylinders, unless you are talking about drag car with slicks. I just autrocrossed, hillclimbed and daily drove my cars all those years.
