bunkhouse
Everything posted by bunkhouse
  1. My late 70s build had an ignition key, and the door keys fit the hatch.
  2. 4 psi is enough but the fuel supply can meet pressure requirements and not meet volume requirements for an engine under a load.
  3. Check the banjo filters where the fuel enters the float bowls. Then I'd do a fuel pressure and volume test. The symptoms all relate to a lack of fuel.
  4. Will the engine rev to 6000 rpm when there's no load on it? Years ago I was driving my 71 on I-5 when I found the engine wouldn't go any faster than 4000 rpm. I kicked in the clutch and found it would rev to 6000 but under a load it wouldn't go past 4000. The problem turned out to be a partially plugged fuel filter.
  5. Are you sure it's getting fuel? Running for a few minutes and then losing power or dying could be fuel starvation.
  6. Any possibility of oil getting oil on the new clutch disc or pressure plate? I've seen old clutches shudder when they had oil on them.
  7. If the noise goes away when the clutch pedal is pushed down, the noise is coming from the transmission. The disengaged clutch stops the transmission from spinning.
  8. When a stock oil bar is clean. solid and working correctly, the oil coming from the oiler holes lands on the cam lobes at idle.
  9. Interesting. I hadn't heard of a V-12 Z at SEMA. Last year I sold a left door skin to a fellow who was using it on a V-10 Z for the SEMA show.
  10. I'd pull the valve cover and take a good look to see if there's any loose parts.
  11. The folks over at Classic Z Car Club (czcc.com) are very knowledgeable on this subject.
  12. I'd start by checking ground connections.
  13. What is the battery voltage when it's time to add the jump pack? I'd also check everything from the battery to the starter for heat (either a fingertip or infrared sensor) after trying to start it.
  14. I've never seen a release bearing that wasn't smooth, not that it has to be if it fits properly into the diaphragm tangs. Seems like one might hear an occasional click when pressing on the clutch pedal as the bearing meshes with the diaphragm. I'd love to hear the theory behind this supposed improvement. Just had another thought. Is it possible it's supposed to stay meshed with the diaphragm and spin all the time? Which would mean reversing your adjustment.
  15. There's a flat stop screw on the bottom that can be removed. It prevents the mixture screws (jets) from being removed.
  16. Here's the simplest method for checking float levels I've found. The fuel level should be 3/8" below the carb bridge. Remove the carb domes and pistons. Turn the mixture screws and raise the jets to their top position. Now turn the mixture screws 9 1/2 - 10 turns down. (9 5/8 turns is 3/8") The fuel level should be close to the top of the jet. It doesn't have to be exact, close is good enough. Re-adjust the mixture screws to app. 2 1/2 - 3 turns down from their uppermost position.
  17. I can confirm they're not US Indy wheels. Mine have the brand name on the inside. They could possibly be Anson Sprints.
  18. I've used a smashed piece of copper pipe to back up small holes. I like the idea of a magnet to hold it in place.
  19. I'd do a compression test to on all cylinders first. There shouldn't be water in any of the cylinders.
  20. The noise sounds like a bad bearing to me.
