bunkhouse
Everything posted by bunkhouse
Years ago I had the dreaded clunk. I found the source by putting the car on jack stands, started it up, pulled the e-brake and had a friend shift into first and reverse while releasing the clutch. I was under the car and saw the nose of the differential going up and down as he let out the clutch. New bushings cured the problem.
mechanical AND electric fuel pump
bunkhouse replied to jvandyke's topic in Gen I & II Chevy V8 Tech Board
Many Z owners have used the 1st gen. Mazda RX7 (80-81) elec. fuel pumps. They are quiet, cheap and avail. at any chain parts store. -
I replaced a starter that tested OK at the parts store. Much like yours, the solenoid would click but the starter motor wouldn't turn the engine over. The problem was the starter motor wouldn't put out enough oomph to turn the engine over but it would spin like crazy on the test bench. The tests have no way of putting a load on the starter.
I'd put a starter on the engine and do a compression test to verify the compression is good. If it is good, as reported, I'd leave the head on.
If the original sender is corroded but still has elec. continuity, You can soak the sender in CLR for twenty-four to forty-eight hours and it will remove all the corrosion. I've revived a couple of senders that were so corroded the float wouldn't move.
Ask over at Classic Z Car Club (classiczcars.com). They have a lot of members on the east coast and all Z owners hoard parts.
Diagnosing flywheel/transmission vibration
bunkhouse replied to bawfuls's topic in S30 Series - 240z, 260z, 280z
Slide the pilot bushing onto the trans. input shaft and check the fit. In the pic above that shows the pilot bushing installed, what is that silver, shiny object just below the brass bushing? -
1978 280z Engine Sputtering/Bogging ..
bunkhouse replied to cclxxxz's topic in Trouble Shooting / General Engine
Describe "the same spot". Anything unique about that spot? Hill, curve, the same amount of miles till it dies? -
Water may have come with the recent fuel fill. Underground fuel tanks usually have a bit of water in the bottom. The water in the bottom can get stirred up when fresh gas is pumped into the underground tank from above. If you're filling your tank at the same time as the underground tank is being filled, water can be pumped into your tank. My Dad wouldn't stop at a station that had a tanker in the lot. I'd try a bottle of Heet in the tank and see if the problem returns. -
Water in the fuel? -
I'm glad to see there's enough bolt left to grab or weld onto. That simplifies things. I've found that alternating heat and cold along with any of the methods suggested above will usually free them up. I use a propane torch to heat the bolt and surrounding area. Then apply cold to the bolt only, as much as possible. CRC Freeze-Off works well but I've also used dry ice and plain ice. I have better luck using good Channel-Locks than Vise-Grips. If it won't crack loose on the first attempt, try turning it in(clockwise) then reverse direction. Keep turning it both ways while spraying penetrant onto it. The theory is the cold will shrink the bolt allowing penetrating fluid to seep into the threads.
3 1/2 total psi. Anything much over 4 psi puts a strain on the needles and seats that can cause premature failure and flooding.
There's a lot of electric fuel pumps to choose from. You'll want about 3 1/2 psi fuel pressure to feed the carbs. Most of the complaints about elec. pumps are the noise. Many have found the 1st gen. (1980ish) Mazda RX7 pumps work great. No pressure regulator needed and they're nearly silent. Reasonably priced at any auto parts store.
1978 satay fuel problem cranks but wont start
bunkhouse replied to Tito's topic in S30 Series - 240z, 260z, 280z
Ask the question over there. They deal with gremlins in stock Z's all the time. -
Call it a repair or modification. Either way, it's not stock.
Replacing the entire floor pan is a PITA compared to inserting a few patches. Replacement floor panels need massaging before they fit, especially the 280 floors.
It is a close ratio box. The single mount on the left rear of the tail shaft housing is the clue. The gear ratios were the same from 80-83 with the exception of 5th gear. 1st.-3.062 2nd-1.858 3rd-1.308 4th-1.00 5th-.773,1980 5th-.745, 1981-1983
We'd like to see more pics and info about the car and engine. Vin#, engine, and head #s, etc. It has a later 280 vented hood. I'd pull the head from the block and take a look at the rod and main bearings. Send the head out to check for warpage, change the valve seats along with a valve grind, new valve seals, timing chain, etc. You may find the bores and pistons looking good, which is usual. It would also be a good idea to pull the freeze plugs from the side of the block and clean out the coolant passages. Good luck and keep us posted of the progress.
2020, Denver Colorado.
Branson, Missouri.
@Chickenwing Try nicoclub.com/datsunservice manuals. You may find the info you're looking for in the 73 manual do to the Dec. 73 build date.
Leveling Out an RB25 Engine Before Fabbing Mounts
bunkhouse replied to Jboogsthethug's topic in Nissan RB Forum
As I understand driveshaft angles, the most important thing is to be sure the front and rear angles are the same.- 21 replies
I'd treat the area with a rust converter after ridding the area of loose rust. Ospho (it will seep into the seams) is my favorite but any acid (muriatic is effective but extreme, phosphoric is better) will convert the rust. Then a zinc rich primer and on to paint.
A bit of research on Wikipedia shows that the sd33t was powered by a turbo diesel. That said, I'm going to assume that your L28 is fuel injected. Likely the injector on #6 is either not firing or gunked up based on the reported good compression and spark. A long screw driver used as a stethoscope will tell you if it's clicking like all the others. If it does click, the injector is probably plugged.
The same problem exists on the underside with the undercoating. Air pockets that allow surface rust. Both surfaces (inside and out) need to be cleared of rust. Hopefully you won't find any spots that have rusted thru the sheet metal.
