tube80z
Super Moderators-
32
Everything posted by tube80z
For cost that's a little hard to say as I had a lot of bits and pieces already. Speedway Motors has AN line kits for hotrods. I was converting over to Tilton masters and wilwood calipers and took the opportunity to convert all of it to AN. I ran a small section of braded line from the masters to hard line to make them easy to change and deal with any flex in the firewall. I'd have to say less than $200 including the flaring tool. You need a different flaring tool (37 degree flare) for the AN fittings. They use a compression sleeve and a nut to mount that compresses against the backside of the flared section on the tube. Another alternative is if you have a Parker hydraulic store in your town is to use their fittings. My local dealer quit stocking AN-3 because they didn't want people doing what I'm doing. The majority of the cost will be in the few metric to AN fittings that you need if you use stock masters and calipers. If you use aftermarket calipers that have pipe threads the fittings are less than $3 a piece. When I first did double flares I had a lot of leaks I had to chase down. My experience with AN fittings so far has been no leaks at all. It's all I use on my race cars. And if I had a street rod I'd do the same. Cary
Billet Ali Rear Subframe
tube80z replied to BlackBeaut's topic in Brakes, Wheels, Suspension and Chassis
Have you considered an X bracing for the verticals? It would need to be spaced out to clear the Diff but I think there is space. This should be stiffer. Cary -
For chamering I used a small 6 fluted countersink tool on a battery operated drill. I then used a small file to prep the outer edge of the tube as well. Then I used one tube flaring tool to create the bell and another to finish it. It was a lot of work to get it to not leak. When I did the brake lines for my new brakes I threw all this stuff away and converted to AN. It didn't leak a drop and was much easier to do. You need a new flaring tool and different hardware for connections. Braided lines ar e a lot cheaper this way too. If you're looking at repacing everything you may want to do this. And if you use or are thinking of using Tilton pedals (or similar) they alread are setup for AN ends. Cary
CHEEEEEEEEAP pyrometer... possibly.
tube80z replied to JMortensen's topic in Brakes, Wheels, Suspension and Chassis
What do you think of running no rear Sway Bar?
tube80z replied to cyrus's topic in Brakes, Wheels, Suspension and Chassis
If you're looking to put power down better than a smaller rear bar will be a better option. If you know all the data about your car you can determine how much roll resistance each axle pair has in total and you can use this to switch between spring and bar. One trick I've used that I think works quite well is the use of droop limiters. I started doing this to use less limited slip and trying to improve turn-in. What I found is that it also helps to put the power down. This isn't something you run on the street but can be quickly added (cables and turnbuckles) when you race. I use an 1/8 to 1/4 inch of droop in front and around 1.5 inches in the rear. This helps to keep the limited travel in the suspension being used for what we wanted, not overall body movement. It's a path to explore at least. You may find it doesn't work at all but you won't be out much trying. Cary -
Bumpsteer spacers................
tube80z replied to Vintage-TechZ's topic in Brakes, Wheels, Suspension and Chassis
I think a lot of the difference has to do with how you use the car, tire type, weight, etc. In my case the car is an autoxer and I use really short 13 inch tires (20s or 22s). It may be that my RC isn't that much different than other cars on a lot taller tires. For the most part I have my lower control arms near level. I also make sure that the inner lower control points (TC rod and LCA) are level too. If not you'll introduct anti geometry and this will induce understeer, or at least that is what I have experimentally concluded. I also use spring rates very close to the corner weight supported. And I run the front with less than a 0.25 inches of droop and the rear around 1.25 to 1.5 inches of droop. I don't think you'd want to copy any of this for a street car. For softer rates you'll need a some anlge down towards the wheel. I think the sweet spot is close to level when cornering. I don't if this helps at all Cary -
Savage adjustable control arms?
tube80z replied to auxilary's topic in Brakes, Wheels, Suspension and Chassis
If you look in the newer version of the how to hotrod book you'll see something like this on the Bob Sharp 280Z racers. I think it's a good idea and you can go further by connecting the rocker to the TC box and forward to the crossmember. All this can help to triangulate the bottom of the engine compartment to make the car stiffer. Cary
If you don't want or have time to find a spindle tool you can do the same thing with a stack of washers and 3/4 inch nuts. It's slower but will remove the pin in the same manner. 12 AM the night before a race will make you resourceful Cary
Why don't you do what a lot of racers do. Convert the struts into uprights and make a top and bottom a-arm. May not be as good as a dedicated piece but you can use the stuff you already have. Unless you have nothing and then you're free to put what ever you want on the car. I'm with John on this. I don't know why you'd want to put Pinto pieces on your car and expect it to handle any better than a Pinto. To do this right you really need to design pieces to work with the rest of your car. Otherwise you end up with an expensive project that won't work any better than plain ol' struts. Cary
This is one 240Z strut I would like to have.
tube80z replied to a topic in Brakes, Wheels, Suspension and Chassis
I thought VDP was velocity dependent pitson, learn something new everyday. I run the low buck ground control advance design shocks with custom valving. I would love to have been able to use Penskes or Ohlins T44s but they were well outside of my budget. Do you set those up with internal droop limiters? I'm currently running around just under a quarter inch in front and about one and a quarter in the back. Cary -
Okay, I came to the game late. Is the 55/45 discussed above front to rear or rear to front? I was a little lost on that one. For what it's worth I ran at the Bogus Basin hillclimb with my car, which is L6 powered and 2 percent heavy with me in it to the rear. My first run up the hill was faster than any I've seen from previous results from Kim. While this doesn't mean anything it seems to be the argument that he uses for why rear weight isn't needed. Forward weight bias for hillclimbs is generall seen in Pikes Peak cars. If you look at the 4WD monsters this is how most of them are setup. I think it has to do with trying to get equall traction from the tires at a dynamic state. Not really something we'd see translate over to paved hillclimbing. Most of the fast EMOD cars autoxing are heavy to the rear. They do this to help with traction out of corners. They generally try and hit a 45 front to 55 rear target and work well. My tube frame car is built to try and hit this number and the back of the engine is 1.5 inches of the car centerline (completely behind the firewall with a 5.0 Ford). Good discussion though. It seems to validate my weird little view of the world. FP Z car using GT engine setback and little 13 inch wheels and tires. The only thing I saw missing here that relates to PMOI is gyroscopic forces from the rotating components. Which is why I think 16 inch wheels are wrong for an autox car. Cary
For the record that was the front roll center. I have never used a rear RC underground. I should also point out that my car was using 20 inch tall tires at the time. With the current 22 inchers the RC is actually above the ground. It seems to be a common notion that getting better camber compensation will solve a lot of problems with our cars. I have tried this numerous times and never seen the results it would indicate. What I have found is that you're better off not worrying about that and trying to keep the tire from laterally scrubbing. At least in my experience that did more for grip and overall driveability. If you can go with a longer link then you have a little more freedom to play with this. What ever you do in the back of a Z think really hard about making the outer strut pickups double shear. In the stock setup you can see a lot of flex that changes the toe setting. If you have an automatic car (stick would probably work too) try adusting your rearview mirror to watch the tire and powerbrake the car. What you see may surprise you. Instead of alternate holes make the design so that you mount it using spacers. This is a quick and easy way to make changes. Cary
Custom adjustable t/c rods please critique
tube80z replied to 240hoke's topic in Brakes, Wheels, Suspension and Chassis
The clevis is bolted down and is solid when tight. The difference is one bolt versus two on the stick TC rod. That can have a tolerance too, but when you tighten it it doesn't move around. I guess you forgot the rubber bushing that's usually at the end of all this that moves around a half inch or more. And even if you did install delrin or some other ball and socket option it will flex too. This is a proven and tested design, which in my opinion is a lot better than what Arizona Z offers. -
Roll Center...What is desired
tube80z replied to Jolane's topic in Brakes, Wheels, Suspension and Chassis
650 was my upper limit. That would be 1.5 times the corner weigt on the EMOD car. To get there will require more development work on the shocks I think. Last year I ran 1 to 1.2 times the corner weight on the unibody car. Right now it has 400 lb springs all around from an event we ran late last year where it was cold. Cary -
The weak link is on purpose. This is what lets the motor exit out the bottom of you really stuff the car. Welding in the crossmember will make the front a lot stiffer but if you get in a serious accident the motor will be coming through the firewall. It's your choice. Cary -
I think it depends on what you do with your car. John had good info below on what he did on an actual racing course versus what I do in SOLO II. The tube frame car will have an underground front roll center too. But the 1 inch below ground RC is on my unibody Z car. It has a cage that ties into the stuts. When I got the car it had above ground front roll center and some weird spring choices. It was fast but was hard to drive. I gave up trying to make a three wheeler work and decided to try some advice I'd seen on the FF underground about using spring rates that were some portion of corner rate. I started with 400 lb springs, AD inserts, and GC camber plates. The rest of the suspension is monoballs in front and the delrin bushings in the rear, altough I want to change that to monoballs too. Front roll bar is 15/16 and rear is 5/8. Nothing too out of the ordinary. I guess I do have one thing that is a little different. I droop limit the front suspension, which has a major effect on the roll center. I have tried up to 600 lb springs on this car and it seemed like a good direction to go. Part of the problem is I can't lower the car enough to isolate for the spring change to say that's exactly what it is (I'm assuming people know that you have to change ride height to isolate spring changes). A lot of this will depend on tires too as you have to take into account their spring rate to determine the actual wheel rate. The one thing I do a lot of is change chassis rake to balance the car. And this does change the roll couple. So I agree that it has a major influence on your car. So we are in definite agreement that this is a key tuning tool. I just happen to play in a different speed range with my toy. Hence my advice is for SOLO II. I'm just offering it as something to think about. So what are normal Z spring rates these days? Cary "who only wishes he could afford to play on real tracks" -
Good info. For what's it worth my car rarely gets over 80 MPH and never in a corner. At most course I run the average apex speed is 45 MPH or less. Which may be why I like this. Cary -
Okay, I was a little harsh on that one. But you can get all this for a lot less in other books. It's still a good one to have but it doesn't need to be one of the first purchased. Cary -
Lengthening the control arms is a good thing. Remember the TC rods and tie-rods too. Cary -
I think Race Car Vehicle Dynamics is a great book, but it really doesn't tell you anything about struts other than give you basic definitions and tell you they suck. Before I bought that I'd look at some more basic books like Staniforth's Race and Rally sourcebook or Haney's book on tires. Those at least have some useful info for the DIYer trying to make their car go faster. Cary -
