tube80z
Super Moderators
    25
Everything posted by tube80z
  1. Check Amazon. They have shipped by Amazon for the plastic piece of $115 and free shipping. I know you'll need the rest but this may help. https://www.amazon.com/ACDelco-89018187-Original-Equipment-Manifold/dp/B00S0A2JHY/ref=sr_1_13?crid=AOD5M4YFK7S2&dib=eyJ2IjoiMSJ9.IrazLZcks-CeAYxm7Nnw9H2LntY3DpM73oIQRsYT5Q4kI1yKjso87_ovlL4gKf7IZwTBIOQwjcjoCZ-wm6uIlepFewMz9Ayqdldqr6r87dC5Ehy4pmoQSIDcWD7pFUPZlXwOMxtO4QzB-smVvXAPewzAbfdukibkpMTnaMkrNUtvILiaJONc57aR6maJaoARvNG1cv-nVY5gaN78BHLNFCheIc7_v1jAALZ5NVwAAZU.S7qhbRJHRfu8O6PFfX2faRbbpk6JiNPx6YMpDGWCdPE&dib_tag=se&keywords=chevy+ls1+manifold&qid=1727123364&sprefix=chevy+ls1+manifold%2Caps%2C151&sr=8-13 You can also get the Blazer SS too. Good luck. Cary
  2. When I need inspiration I check out your thread. Cary
  3. You can remove the core support but you'll need to add the structure back for support. If you needed the top out of the way you could make a new core support angled out of the engine bay for clearance. If you have a thicker cooling stack this could be moved out for engine clearance. I've seen a few on race cars where this is removable to make engine changes easier. There's been more of the make the top part of the core support removeable to ease engine changes. The often fall into the turbo DOHC engine swaps if I recall directly. You can do a search here or in Google (or search engine of your choice) and see how people have made this modification. Hope that heklps, Cary
  4. Aydin, I didn't mean the adjuster was electronically controlled. Just that with pressure sensors, if you found a sweet spot for brake balance wet or dry you could easily get back to it. Push pedal for 1000 PSI total pressure front to 700 and rear to 300 for a 70/30 split as an example. Easier than needing a helper use a torque wrench on a front or rear wheel to set balance. On the electronic side you could have a channel to send info to a stepper or servo motor connected to the adjuster cable and do fun things like preset pressure by corner or based on weight transfer (light vs, heavy braking). And you could implement the old 90s technology of pendulum brake bias. BMW and Mercedes had systems that used a hanging weight to adjust side to side balance on the front to help with inside wheel lockup. I think if you search groups on FB for E36 Bimmers and the 190 Mercedes they have pictures or video of them working.
  5. If you have a logger/dash and front and rear brake pressure sensors you can set it by pressure in the pits. Instead of turns. Turns are also hard to keep track of when you come running up to a corner. I have a Tilton pedal set and their bias adjuster already. I'm looking at changing from turns to a linear system of steps to easily change from max front to max rear. I've seen two systems I like. During the Schumacher era at Ferrari they created a stepped system so Michael could change brake bias between corners. Triple Eight racing (V8 Supercars) created a system like an ARB adjuster for their drivers and that's another option. I have had too many runs that rain started falling and I would have loved to be able to change bias and ARBs quickly. I'd like a Bosch motorsports ABS but it's too expensive to justify for me.
  6. You have packed a lot into your intro. There's some good advice below to consider in the posts to your question. But I have to ask you what is it about the 280 you love? I don't mean that coyly or as some flippant remark. What is it you really like? I'll give you why I like the Zs. I grew up around them when they were new, my uncle was a general manager of a Datsun dealership so we got to try out the new cars. We raced with my uncle at autocross and hillclimbs (I was a kid so I just went along). Back then the Z cars were fast and sounded awesome (I have the hearing loss to prove it), and were amazing at cutting through the corners both stock and modified. Our local racing club had about 10 people driving stock to all-out racing versions. 50 years pass and a lot of that coolness has mostly worn off except for the look of a lowered S30 with an airdam and rear spoiler. I have to admit the sound of a modified Z makes me happy when I hear it. But this site exists to help people get the most out of them. And the reality of that is as cool as the L28 engine is you're looking at spending a lot of money and you'll have an engine that makes 200 to 250 HP. Sure you can get more but then all the other parts that connect to that engine are starting to get pushed past their limits given the age. While I don't disagree with any of the posts below you should still read about a lot of the mods and why they were done. You'll find that in many cases they were driven by it costing too much, parts NLA, etcetera. A bit of advice from me. Never by an engine, transmission, or rear end unless you plan to use it within a few months. Even if you plan to use it that's not the same as ready to bolt in. If you want a street car with a certain coolness and triple Weber carbs, then build it. But when you spend 10K on an engine and find it's somewhat finicky to drive but cool all the same. But for less, you could have 350 HP V6 in the DI Chevy LV3. It won't sound the same as the L-motor but it's lighter, a lot newer, and will get excellent mileage, It will start anywhere if it's hot or cold by the sea or at altitude. This site has a ton of info on how to do the same for the suspension and how to get a cheaper rear diff, especially if you want an LSD. I could write a lot more but this is probably too long as it is. Welcome to Z ownership. Cary
  7. Here's the Mustang GT-4 camber plate I mentioned Here's a slightly better picture. You can see they moved the center a bit. You could make something like this but has a square shape or even just a flat edge and easy shim adjustment awaits. I was looking at this for being able to make faster adjustments between runs when testing for autocrossing. Having to jack up the car wasn't going to help make it faster. In some of the events I run, we may get 10 minutes between turns. You need to add in looking at the data to see if it helped if the lap time doesn't seem to show an improvement. I have a long list of items I want in my next car. At the top is a lever adjustable brake bias with presets. So while driving I can change between slow corners and fast corners. Drive adjustable ARBs, and externally adjustable ride height.
  8. @AydinZ71 I'm not sure that bending the strut will work for Konis as they are generally tight. I've heard rumors but never seen them in person about a certain BMW team that had a jig that mounted in a hydraulic press to bend in some extra camber. Getting the tube out of the is going to be some work but I think that might be the best way to go. Another option would be to build a custom strut and use Nascar hubs 5x5s I think are called. That will help with pad knockback. Another option if you haven't used them is 280Z struts. They are thicker and should flex less. Or you can show up with some DTM inspiration Cary
  9. It's funny how certain rules are set in stone and others are ignored. You could make a custom camber plate that is mounted to the top of the strut using the tower edges. There would be no more center hole in this design as it would all be covered. If they challenge it you could argue that you wanted to be able to swap springs more quickly out the top. Take a look at rally car service videos and many of those cars come out the top. My personal choice for camber plates would be a square/rectangle design where you can shim for camber or caster/strut angle (rear). Ford has a really cool design I meant to steal but couldn't find it again on their GT4 Mustang. Hope that helps, or inspires some rule bending.
  10. You can use autotranslate to get a version that will give you the gist of what's being discussed.
  11. To be fair to GC the plates aren't intended to be used with that much track increase. You may need to back that off to stay legal in EP rules. I don't have a GCR so I'm not sure what you can or can't do with the shock tower and camber plates. When I widened the front track in my car, I moved the camber plate to almost under the fender mount. I've also used a porta power to add some positive crash damage but that needs to be done before you tie into the roll cage. Cary
  12. I have a long history with sidedrafts and used to have tons of jets, emulsion tubes, etc. The advantage you'd see on just a 45 mm throttlebody is that you don't have the auxiliary venturi and the chokes. So you'll see more airflow with EFI than with the carbs. Do you need a larger throttlebody is the question? Do you currently see a vacuum in the manifold? If your engine makes over 300 HP then I'd be inclined to look at a 50s or 55s. I'd call Rebello and ask him for a recommendation as he'd know best. Cary
  13. Look up used NASCAR parts on eBay for some stuff (window nets, fire suppression, etc.). I'd check local club newsletters for used parts and any of the facebook groups for used racer stuff. But you probably already know all that. And you can ask around at some of the races/track days to see if you can find anything. Cary
  14. If you want to do a modern flush mount look this is probably what you need to do. I'm half-assing it with a different method for my car, at least at first. And that's gluing the windshield and then using RTV to fill the gap and smoothing it. I saw this back in the 80s and 90s on a few of the IMSA cars. I asked a pit member how they did this and that's what he told me. I'm also thinking about a 3D-printed rain gutter bridge to make air flow down the side of the car better. Cary
  15. Can you give a summary of what this method is? I went to that link, which required a signup and only found a group with a ton of emails.
  16. tube80z
    Pictures
    Do you have an example picture you're trying to upload? You can send to me at tube80z@gmail.com
  17. A friend built an endurance car (Chumpcar/Lucky Dog) and was going to use a new Nissan gasket. I talked him into gluing the windshield and was amazed at the results. The difference between this and a normal gasket was the same having a strut bar or not. This car has been used hard, ridden some large curbs, and never cracked a windshield. I'm not saying it can't happen on the street but I'll be gluing in my street car's windshield when we get to that point. Cary
  18. Hard to say. The only L-series engine I weighed was a friend's race car long block and nothing but a Peterson dry sump, Alloy crank pulley, and dry sump drive. That was 325. So I don't know if that is going to be 50 lbs, but it's probably very close.
  19. The problem is HybridZ has no idea how to deal with a ".jfif" file extension so it only shows as a download. change it to ".jpg" or a ".png" and it should work fine. Hope that helps, Cary
  20. Hey Mike, great to hear from you. I'd also take a look at https://www.race-technology.com/gb/gopro software for pulling data on most newer gopro cameras. And if you want to be able to mix and match data Track Attack is nice software to use. It also can integrate most action cameras into a feed with overlaid data. Cary
  21. So sorry to hear the news Stony. Glad you're alright and we'll all morn the beast you created. Cary
  22. Hey Aydin, I would do one small mod that will save you down the road. Use a small section of flexible brake lines that goes from the masters to a block on the firewall that terminates the hard lines and has a high spot for a bleeder (one with a check valve). When I got this advice I thought it was stupid until I needed to fix a master that was leaky. I had it removed, new one installed, and blead in about 5 minutes. When a friend had a similar issue the hard line kept leaking and this similar process was a half hour or more. Cary
  23. The LV1 only came in vans as far as I know. The LV3 is more widely available but has displacement on demand (DOD) that needs to be removed. You can pull the balance shaft out and they work fine from what I've read. For some reason these are super pricey, which seems odd as there should be a bunch on the used market. They came in a number of trucks and small SUVs. The LV1 and LV3 are 100 pounds lighter than the equivalent V8. Scoggin Dicky has some dyno videos where they used a pulled LV3 with DOD delete and a new cam and it made 368 HP and had over 300 ft-lbs of torque at 2 or 2.5K.
