JMortensen
    68
  1. Cheney: "I'm getting pretty good at this. You can't even see my lips move when he talks" Jon
  2. "So then we put the electrodes on Saddam's nuts and WHAMMO!" Jon
  3. "Extend the Patriot Act, come on, you can trust me! What's wrong, don't you trust me???" or "They DID have WMD's. I swear." or "I wish Cheney would get his hand out of my @ss" or "No no no. It's supposed to be DON'T tax and DO spend." I'm sure I'll have more... Jon
  4. That sounds like a hard to build/fab version of the infamously crappy dual Weber setup... Jon
  5. This is the way to go if you want a P90 on a NA engine, IMO. http://geocities.com/zgarage2001/p90.html Jon
  6. Maybe he's got a planetary gearset at the wheels like a Hummer or a UniMog... Jon
  7. Boy that's dumb! That's taking my whole "big rims look like wagon wheels" thing to the extreme. Put the yoke on the horse and attach it to the front bumper, we're going cruising! On the plus side, those would probably take away 30hp and make any ricer type car REALLY slow off the line by affecting the final drive ratio, so maybe its not such a bad thing. If you're dumb enough to buy those, maybe you don't need that much power... I wonder if they're going to develop 25" rotors to fill the wheels up... Jon
  8. Putting a 185 on an 8 inch rim is a different proposition though. It would be REALLY hard to get that tire to seat on that rim. Anyone else who has had a crappy tire mounting job in their lifetime like I have should be able to back me up on this. The beads of the tire will be nowhere near the rim, and they won't be even close to straight up and down. I don't know this for sure, but it seems apparent that the beads of a tire that is properly sized for the rim would be less likely to have problems because when given a side load the tire can flex a lot. If the tire is already flexed because you have a 6" tire on an 8" rim, there could be issues. Again, never seen it myself, but it always worried me, especially with the 4000lb Caddies riding on 185/50/13 on an 8" rim, vato style. I agree with Pete, if it doesn't make the car faster, don't bother. Jon
  9. It's done for looks, it's the JDM style. I always wondered how much more likely debeading a tire and possibly digging a rim and flipping the car would be... Jon
  10. Keep in mind the dude was DYING when he recorded all that stuff. The one that even I can't handle is his Bridge Over Troubled Water. I hate the original, so that might have something to do with it. I'm also a long time Cash fan, so I may be a little biased. Road trips with the family when I was 7, it was Folsom Prison Blues all the way, baby!!! Jon
  11. If you buy a 50 gal drum it can get as low as $3/gal I'm told. At that point I'd rather buy race gas for $5/gal though. Jon
  12. His version of the NIN song Hurt is better... Jon
  13. Maybe I'm thinking about this too hard because I'm bored, but now I'm thinking that moving the rack down would be a way to fix the bumpsteer. Same thing I said before applies, if you were to move it down an INCH you'd still need to slot the crossmember to fix the control arm angle, but I'm convincing myself that lowering the rack (probably like 3/8") would be another way to fix the stock bumpsteer issues. My reasoning: if the control arms sit flat relative to the tie rods, then you need to raise the control arm pivots or lower the rack to fix. Since I have raised the pivots, then I would assume that lowering the rack would also work. Very few move the rack on a Z, so I guess I wasn't thinking about it correctly before. I was getting confused with some other vehicles I've worked on... sorry. Jon PS How about denting the header?
  14. I just had a thought. You could relocate your front control arms down by slotting the front crossmember as I have done. I slotted it to raise them up, but I see no reason why you couldn't go down if there is enough room on the crossmember to allow a little movement. This would lower your roll center (not a good thing) but you might have enough room to fix the bumpsteer if you moved the rack. All in all a bad thing to do, but not as bad as moving the rack down and leaving it be. Jon
  15. Usually the cure for bumpsteer is to raise the rack. This is the case with our Z's too. If you lowered it, you would make the bumpsteer worse. An inch is a LOT. I would think that would drastically change the bumpsteer for the worse, but of course I've never done it. I definitely would be against the idea of cutting and rewelding your tie rods or steering knuckles too. The 510 guys heat their steer knuckles and bend them, then heat treat them for Ackerman, if you decide you have to mess with the knuckles, that's the way to go IMO. I'd either lift the motor (realize there would be driveshaft alignment issues to work out if you went this way) or get a different set of headers. Jon
  16. My former employer just called me about a similar scam. Apparently the one he fell victim to involves a person making a large purchase, and a "relay call" to a foreign country. Needless to say he got a fraudulent cashier's check, but only determined that after he had sent $1000's of dollars worth of merchandise out of the country. I won't do biz outside the US, period. Jon
  17. The normal answer to this question would be "use the search function". Since the search funtion is not working, I'll tell you that this has been discussed a lot, people have done it, and if you dig through the brakes, wheels, suspension and chassis forum you'll find posts on it. Seems like people are using Ford parts, one guy found that the WRX rack is nearly identical to the Z rack, but I don't think he's gotten it installed yet. Jon
  18. The best Soundgarden songs: Searching with My Good Eye Closed Like Suicide Jesus Christ Pose Birth Ritual Nothing to Say Jon
  19. You could report him to http://www.ebolamonkeyman.com! Sorry, couldn't resist. FBI would be my first suggestion. Jon
  20. http://www.thepetdoorstore.com Don't like to use the forum to advertise myself, but since you asked! Also, this would be easier to get done if someone already has an established consulting side biz, or if someone works for or owns a web design biz. Jon
  21. Search on http://www.mcmaster.com. You might be able to find them cheaper somewhere else, but McMaster Carr has EVERYTHING. Jon
  22. Here's another two stories. When and buddy and I were gas welding in auto shop in HS about 12 years ago, he had an accident. He had a brand new welding rod and he had the car up on a rack, and was welding on a new muffler. His hands got sweaty, and the rod swiveled in his fingers and fell. The hot tip went through his coveralls, jeans, and undies and about 1/2" into his skin about 1" from Mr. Winky. He wasn't too happy about that, but the rod cauterized the wound, so it didn't bleed. About a month later some guys from the class were welding a banister on in front of the classroom. They finished and left, and about 30 seconds later I jumped up and sat on the banister. It took a couple of seconds for the heat to soak through my pants, then I jumped off and ran around like an idiot yelling "My butt is on fire!" for a few seconds. Luckily there was a large crowd on hand to see this. Jon
  23. Also you want the front brakes to attach to the larger reservoir on the master. You can just bend the stock lines by hand so that the fronts go to the big reservoir and the rears go to the small one. Jon
