yetterben
    4
Everything posted by yetterben
  1. About 2.5 here for cost. The little things get you, Hose, clamps, fittings etc.
  2. Will get some. Tach issue was because i was jumping my fuel pump off the + side of coil. It also woke the car up once i moved the pump on it own circuit and gave it full power. need a smaller air corrector i think as well.
  3. What are you pulling for vacuum on that carb. Is it just one barrel or both on that carb? I echo a valve issue if its just one barrel. Chances of a carb being fubar after 1.5 is slim unless you dont run filters.
  4. BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOST. Had a few leaks at first causing some major issues but i am now boosted. Think i still might have another leak. Timing is at 18 and feels like there could be lots more power there. Will play with timing in the morning. Thanks to TonyD for putting up with my insatiable thirst for knowledge. side not tach stops at 3 grand... ideas?
  5. Installed a longer push-rod seems to work dandy.
  6. Using the same bearing and collar that was driving the centerforce plate. All i did was change the plate and disc and re install. Plate and disc are for a 81zx.
  7. Also i should ad that there was a centerforce plate in the trans i put the stock plate back in but kept the bearing/collar that was driving the centerforce. Also when i had someone step on the pedal i noticed there is about .5 inches between the back of the fork and teh trans like there is more room for it to go. SO i dunno if the centerforce plate had taller fingers than the stocker or what. Will try a longer push rod in the morning and see if that rectifies it.
  8. Master slave are new as well. Its just very strange seeing as how the slave rod comes out and moves the fork 1 1.5 inches it looks like. No howling or crazy noise.
  9. Went to take car out after turbo build. Car wont shift into gear. Bleed the whole system nothing. Slave rod pushes out 1.5 inches or so but no go. When the drive shaft was not hooked up the trans shifted fine. Kinda stumped here. New clutch kit when in without a issue as well. Ideas?
  10. Last thing i gotta do is cut gasket for hks box Little nervous Friday is the big day. Surge tank in dual pumps in...wiring in......
  11. yetterben
    From the album: Akuma Zeto
  12. yetterben
    Akuma Zeto
  13. Ugh that plug is dry rotted to crap and i doubt i can get my 6 pin uego wire in there.
  14. What hole in the firewall is the best to route gauge wires threw?
  15. RE posted on rx7club.com http://www.rx7club.com/showthread.php?p=9907129#post9907129
  16. Not worth the trouble i am sure. Maybe but i doubt it. Looks homemade at that.
  17. Anyone have a source for the Ball cap ends (cupped deals) that mount to the throttle actuators.
  18. L20 god i hate this frank guy its always shady a$$ lies. Auto trans GTFO. the numbers they show overlayed on the video dont even match whats on the dyno pc. if i had a l20 making that power there would be a shot of the block stamp for sure.
