BAlford
Everything posted by BAlford
Why beat your head on a wall? Here is what will fix the problem. http://www.waskomtexas.com/zcar/re_car/engine_cooling.html
Thanks for the "grease" advise. How do you get a picture to show up in these windows?
My car was running 220 degrees or so, I tried several things here is what worked. I put two heater cores under the front finders ahead of the tires. http://www.waskomtexas.com/zcar/re_car/engine_cooling.html Not much math just results. It now runs under 190 degrees.
My car was running 220 degrees or so, I tried several things here is what worked. I put two heater cores under the front finders ahead of the tires. http://waskomtexas.com/zcar/re_car/engine_cooling.html Not much math just results. It now runs under 190 degrees.
I should have another rear end to put into my car by next weekend, an R200 3.36. What kind of grease should I put in? I saw on one of these posts that someone had used something to lessen the noise, I think it was a Ford product, does anyone know what it might have been?
gramercyjam New Member Member # 2325 posted July 09, 2002 02:43 PM Â Â Â Â Â Â Â Â Â Â Â Â Â ------------------------------------------------------------------------ I parted out my 1 owner - low mileage '83 Turbo car some time ago after it sustained extensive body damage in a double T bone. I have been saving this complete 3rd member for a 260Z V8 swap but my priorities have changed. I am now autocrossing so I no longer need this. It is a complete third member including the R200 diff, half shafts (CV joint type) axles, calipers with ebrakes, rotors, sway bar, brackets, bolts and I think I still have the matching drive shaft too. I don't remember the ratio, but this was a car with the BW T5 transmission, so it may be the lower 3.whatever ratio. If interested, I can check again. When I pulled this diff from my car, it was perfect and made no noise. My shopping list includes: Triple 45mm carbs and intake racing type clutch and lightened flywheel LSD for an R180 L28 pistons, not dished (1 mm over) trick sway bars (1 1/8" front, 1" rear) 16X10 wheels John B
OK, we pulled out the rear end. BAD ! The ring gear looked like the teeth had been scooped with a spoon. The pinion teeth were sharp enough to cut you finger. The pinion had also been cutting the housing for the spider gears. Now what do I do? I would like to replace the ring and pinion with a 3.36 to 1 ratio but all of the bearings are shot also. I belive the spider gears would be OK and even though the housing is scored it should not be hurt. Since this is a rear end with the CV axels I would like to repair it. What size bolts hold the ring gear 12mm or 10mm. What size fit the 3.36?
OK, A stupid question. If the CV joints are stronger than U-joints then why don't the outer U-joint break on the CV axels? I don't know just asking.
My First Post Here. I Want To Build A V8 240z for under $10
BAlford replied to a topic in Gen I & II Chevy V8 Tech Board
Sounds like dog races to me. wolf, wolf -
If I am figuring my math right these are the speeds that my car would be traveling at 3000 RPM. My tires are 76" around the tire. I understand that a tire jacked up and a tire setting on the ground or pulling may not be the same distance around the tire. My car was a 1982 280ZX turbo automatic with CV joints, it now has a Chev 350 with a turbo 400. The ratio that I have in the car is 3.54 to 1 and when I am turning 3000 we checked with another car and I was doing 60 MPH. If I replace the rear end with a 3.36 to one I figure that I will be going nearly 65 MPH. A 3.90 to 1, which does not interest me, would be only traveling 55 MPH. Does the 3.36 ring gear have the same bolt pattern and diameter bolt as the 3.54 and will it fit in the housing?
Looks like I am going to have to change my rear end noisey rear end. I saw a post about new in the box 3.36 ring and pinions some place on her in the last 10 days or so. Does anyone remember where it was. Also I read a post by about a 3.36: Rick Bowers Member Member # 2349 Tried to e-mail him and could not get the e-mail to work. If you see this please contact me at. waskomtexas@waskomtexas.com
If the 300 are too wide then how do you fit an 87 R200 with the ribed case into a 280ZX.
Maybe there should be a section for the fast and the beautiful then all of the guys with "fast only" cars wouldn't feel bad. Seriously, I'm in the Zcar for the fun. This is a great web site for obtaining excellent information. Remember, I didn't start this post.
I found a 1987 300 2+2 AT with a CV rear end. I do not know anything about how good it is, about 160,000 miles. Its at a salvage.
The 280ZX several posts up is my car. I bought it form a guy that showed the car and won. We have done a lot of work getting it back on the street. We kept the sound system that was in the car and added amps. We may show it but probably not. We are driving it and having fun with. We are planning to rework the motor for more horses soon. I would like to install a new radio/CD/DVD player, it would be a great place to watch a movie. Also I would replace the rear view, which you can't see out of anyway, with a monitor for the DVD and with a small video camera in the back I could see out the back. I would never have thought I could have bought a can that so much money has been spent on. Its a great ride. Silly, sure but you get that way when you get over 60 years old. Thats why they make black cars and red cars. http://www.waskomtexas.com/zcar
My rear end is going out it is a 1982 280ZX, turbo 2+2. Yesterday I found a 1987 300 2+2 AT with a CV rear end. I do not know anything about how good it is, about 160,000 miles. Its at a salvage. Is anyone interested? Found a 1986 300ZX with CV axels and two extra CV axels today at a salvage. Will the 1986 model fit in a 280ZX that has CV axels? It was an auto trans, what gear ratio would it have.
The motor and trans were gone. I tried to see anything that would tell me and did not see anything that said turbo.
I found a 1987 300 2+2 AT with a CV rear end. I do not know anything about how good it is, about 160,000 miles. Its at a salvage. Is anyone interested? Also a 1983 280ZX 2+2 AT with open U-joint rear end.
I checked the manual some more and find that they cal it a tri-pod joint, I think is the term. If I can not find the same type at the salvage, can I switch to the open u-joint rear end? Also is the CV type better?
What kind of a rear end is this? We pulled a rear end out of a 1980 parts car and it was a R180. We have another parts car, a 1982 but the rear end is a 3.9 to 1 ratio, so we do not wnat to use it. We took pictures of the rear end of the car that we are driving, a 1982 280ZX 2+2, and it does not look like either of the rear ends in the repair manual. What is this? Please check the pictures on the web page below: http://www.waskomtexas.com/zcar/re_car/rear_end.html You don't need a password, just click OK.
HTIS MAY BE A REPEAT: How do we get pictures to show up in the window? Please go to our web site to see the pictures. http://www.waskomtexas.com/zcar/re_car/rear_end.html What kind of a rear end is this? We pulled a rear end out of a parts car and it was a R180. We have another parts car but the rear end is a 3.9 to 1 ratio, so we do nto wnat to use it. We took pictures of the rear end of the car that we are driving, a 1982 280ZX 2+2, and it does not look like either of the rear ends in the repare manual. What is this?
We are looking for an R200 rear end. http://waskomtexas.com/zcar/re_car/re_index.html Let me know if you have a good one.
