Please note that Tony is talking about SS HARD LINES here, not braided hose. As Tony is suggesting, use hard lines for running from the back to the front, and only use flexible lines to connect the hard lines to things that can move or vibrate with respect to the body or each other, like between the tanks (if you use a surge tank), tank to pump, pump to hard line, hard line to engine, etc. Basically just use the flexible stuff for the interconnects.
You'll also want to use tube nuts and flare the ends so you use a proper bulkhead fitting for the interconnects.
Hose sizes for the interconnects should be (minimum) -8 for the .500" hard line size, -6 for the .375" and -4 for the .250". Tube nut sizes should be the same, but I'm not familiar with the actual dimensions of that tubing, so the supplier should be able to get you the right sizes.
Also, after having used stainless braided hose for years, I have become a much bigger fan of the nomex braided hose (Aeroquip Startlite, Earl's ProLite, etc). This stuff is much lighter, has plenty of pressure capacity, uses the same AN hose ends, won't destroy anything it touches, and won't start a fire if you drop a wrench across it and the starter terminal. Plus its much easier to work with and it won't prick your fingers while you're tryng to assemble it!
