Everything posted by Drftn280zxt
probably right about the direct ignition. How about twin T3-T4hybrid turbos. T3's are kinda small, plus that the same size as the stock 280zx turbo whoop-de-do (I'm not cliche)(power while meing unique is a rule). WHy wouldn't the aluminum controls arms be good (yes aluminum is soft but its used on newer cars and is drastically lighter I think)(the stock steel control arms weigh a ton!) and to think originally (like 4 months ago) i was thinking twin T66 turbos. what about a large turbo (high RPM power) and a small turbo (low RPM power) simlar to what is done on Supras?
I swear that I will never be able to let go of this car? Many times I have had the opportunity to but there is too much of a personal connection to the car. My sister often tells girls that ask if I have a girlfriend, that I don't exept for my car. The car to me is priceless. The mods only enhance its beauty, price is just a hurdle in the way of perfection. Complicated people like be like complicated stuff. Thus the complex crazy future fits perfect. If the 4-6years off college pay off. I should have a good salary being either an Automotive Engineer or Automotive Designer. Either one would lend a good hand in making my dreams a reality. Automotive Engineers alone from what I've heard make $150,000 easily in a year. I dunno about designers though, but look at Chip Foose he makes some serious bank and he designs cars for a living. Value is not of importance cause its priceless to me who cares what others think, what they will see will make there mouths drop and whatnot, kinda like seeing a ferrari or a lamborghini but a little better. Not to mention the power that will be made will hopefully blow those high-end cars away up to maybe 120ish. Speed is excilarating in a line, but in a turn sliding its pure enjoyment, being in your own car just makes it even better too. In the words of Aerosmith (I shall and will always) DREAM ON
My Front Skirt adventure is over...finally.
Drftn280zxt replied to akeizm's topic in Body Kits & Paint
I'LL POST SOME PICS OF MY OTHER DESIGN ONCE I TAKE PICTURES OF THEM. BATTERIES DIED IN MY DIGITAL CAMERA AGAIN. IT SUCKS UP JUICE LIKE ITS GOING OUT OF STYLE OR SOMETHING. BELIEVE BE THE OTHER DESIGN IS TEN TIMES BETTER. FOLLOWS THE ORIGINAL LINES BETTER. -
I don't think so. Let me know if you find one! Those are crap. Go with NGKs or something comparable. ...and your right, that will be a huge project: be prepared to spend a lot of $$$. Aluminum axles=CUSTOM MADE cast aluminum L28 block bored to 3.1L=CUSTOM MADE THANKS FOR THE SPARK PLUG INFO. I DIDN'T KNOW NGK MADE SPARK PLUGS. ONE THINGS FOR SURE THE PROJECT WILL MORE THAN QUINTUPLE THE VALUE OF THE CAR. i'M SURE IT'S AT LEAST $50,000 IN MODS BUT ITS WORTH IT TO HAVE A ONE OF A KIND 280ZX.
All right here is one design. I've gotta another one I need to take a pic of cause I took it work. and the views and just for heck of it here's my Z THE Front THE Back THE Side It's my baby. Gotta get the hood painted. Should I just get the whole car painted?The paint is oxidized big time and is starting too flake off. -
nice garage!
OR I could just make it sit higher and squish water bottles between the seat and the console like I do now!
What to use for painting/coating underside of car?
Drftn280zxt replied to 80LS1T's topic in Body Kits & Paint
I always thought a cool undercar treatment woulf be diamond plate steel. it looks awesome and is stainless. As far as roving the other stuff goes carb cleaner or brake cleaner my work good. -
looks pretty good.
that would be pretty cool. RHD, people would definently get confused.
that's looks really good for rattle can. You must have a steady hand because I don't see and paint streaks.
well after 4-6years of college I guess I finally be able start my huge project on my Z. Future Mods consist of: Suspension -Coilovers -urethane bushings -aftermarket sway bars -Maybe a camber kit -strut tower braces -maybe aluminized control arms -maybe a four link system Brakes -12" slotted rotors all around -fourpiston calipers with semi-metallic pads -stainless brakes lines Drivetrain -Aluminum axles -aluminum driveshaft -limited slip differential -heavy duty halfshaft U-joints -all new bearings and seals where needed Wheels/Tires -17"x 10-12" in rear with 265-295tires -17"x8-8.5" in front with 245-255tires Engine -cast aluminum L28 block bored to 3.1L -p90 head (maybe) -forged pistons -peformance camshaft kit -port and polish -twin turbo conversion with T4 turbo with adjustable wastegates and blow off valves -electronic boost control -intercooler -oil cooler -oil valve -oil pump springs -aluminum radiator -electrc fan -larger fuel injectors maybe off a 350Z or something -perfomance computer -perfomance spark plugs (splitfires, or bosch quads) -valve job on the head -custom made headers with Jet hot coating -performance computer -Crane Cams XR3000 electronic ignition with the HI-6S Inductive ignition -high performance coil from Crane Cams -Spark plug wires from either NGK or this company in europe who makes spark plugs out of more conductive silver delivering a hotter spark. -replace all bushings with urethane where possible -new engine mounts -new gaskets -new seals and bearings where needed Transmission -short throw shifter (all ready done) -performance clutch -maybe a 6 speed tranny swap -aluminum flywheel Interior Mods/Security/Stereo -Corbeau racing seats -four point racing harnesses -autometer gauges -fiberglass dash -custom fiberglass door inserts for speakers -full custom fiberglass stereo in the rear (already designed) -Five amplifiers -optima batteries hiddens behind seats -2 12" woofers -2 10" woofers - array of 6.5" and 6"x9" speakers -array of tweeters -maybe a fold up 15" monitor -alpine head unit with MP3-DVD-CD-AM/FM capability with a 7" monitor -custom fiberglass console (that sits higher that the stock one did, and accompanies to cup holders and place to put switches. -motorized rear hatch via remote -array of blue LEDs hidden throughout interior -blue or white backlighting on the dash (don't like the orange) -new carpeting -full polished aluminum roll cage (simple roll cage) with blue padding -smaller 13-13/1/2" steering wheel for drifting and good looks -drilled aluminum racing pedal pads (not APC crap) -alarm system Exterior Mods -full custom urethane bodykit -four inch custom flares in the rear to accomadate the huge rims and tires -large Carbon fiber/Aluminum Drifting/GT style wing thats sits level with roofline. (possibly custom as well) -Custom tail lights (already designed) -Custom headlights (already designed) -front and rear cameras -full LED undercar light kit with musical response -full diamond plate under body protector/aerodynamic enhancer (skid plate) -NISSAN daytona blue paint with a gloss black hood with silver hood pins. blue on wing too -recessed chrome accent for front with custom LED turn signals -recessed chrome accent on rear valance -HELLA blue fog lights for front fascia -custom motorized sunroof Exhuast -custom 3" stainless steel mandrel bent piping finished with an APEXi turbo muffler
this is off subject but KillerKlownRodz how did you post a pic like that? also tha idea for the fender is quite neat it could help in the future with accomadating 17" rims while keeping the car only 3-4" off the ground. Good thinking
you mean like cardomain.com? so i have to make site then post the link. Can't you just paste a pic somehow like some of these other guys do. How'd they do that? -
Well the big brakes will have to wait. My parents won't let me put $700 worth of brakes on my car. They said all I can do is perforance brake pads, new OEM calipers in the front and stainless brakes lines all around. Darned it. This is gonna be a big project car after college at this rate. My parents flip out when I want to put money into my car. I'll probably end up thanking them someday but not now. I want an awesome car and they just want it to stay running. Opposite sides of the playing field. Well at least I know what I can do as far as brakes go once four years of school is out of the way, yeaaa, (not). I'm a youngin only 18.
It looks very nice and I like what you've done. I went to the drift track yesterday and some serious drifting was layed down by some locals. How do you post pictures? -
Sir Daniel your 280zx 2+2 is awesome. Nice to know i not the only one sportin a big wing. I reccommend that you make some brackets for it though that way it sits on the car correctly. I've thought of a design similar to what you see on drift cars that would look awesome on 280zx's -
I HAVE A SET OF ORIGINAL 280zx TURBO WHEELS. dO YOU THINK THE BRAKES WILL FIT AND GET ENOUGH VENTILATION. SO IF THEY DO FIT HOW DOES THIS SOUND. 12" ROTOR 4 PISTON CALIPER KIT UP(JSK) FRONT AND HIGH PERFORMANCE BRAKE PADS WITH EITHER SLOTTED ROTORS OR OEM ROTORS, AND NEW OEM CALIPERS WITH STAINLESS BRAKE LINES.
lookin good man. You've got some time on your hands. Are you retire or something or do you just have nothing better to do. Either way it's awesome that your doing it all yourself.
Brush on Ceramic sound deadener technology
Drftn280zxt replied to ZR8ED's topic in Body Kits & Paint
Cascade makes som really cool stuff and it works better than dynomat. Saw it at SEMA here in Vegas. The guy put it on some large cimbals and geez afeter a hard whack almost no noise came out. I was impressed plus it seals and does a bunch of other things. -
okay dangit how do you post a pic. I'm a noob to this. But better late then never. -
Holland!Sweden! geez that's far. I live in Las Vegas, Nevada, in the States.
I'd like to do some sort of led/HID projector job with the clear cover. I could draw up a design and post if you like. I can think up stuff almost instantly. Doesn't cost much to draw stuff on paper .
