We need to get together to set a Sat. so everyone can meet up and go. The better spot is Arlington Trinity location. Its safe and no po po. There are lots of 11 sec. cars out there, and yes very hard to beat.
All Zs should be on the net soon, Ill ask Jerry tomorrow at the Cowtown Z meet. If He dosent have it He will get it sooner or later and is very reasonable on prices. 817 483 0383 All Z car care specialist (all z car yard)
Just get a bright light and a long screwdriver and most of the time you can get the tentioner back in, It may take 3 to 4 hands to get it done. I have had mine come out completely and used a magnet and a flat head to slip it back in NP.
Ck the tentioner and make sure it hasent poped out this is usally the prob. Use a long flat screwdriver to get it back in , unless its out beyond putting it back in that way. U may need to take off the front cover (suc). Ive used a magnet before to get it lined back up, just as long as the spring hasent poped out too. Good Luck
Did u try Jerry At All Z's? Or the Cowtown Z car Club ? We are meeting next Thurs @ No Frills In Arlington I think. And there ae some good ones @ pick-n-pull from time to time.
It bakes the injectors when u do that. If it the heat your worrying about, ceramic coat the manifolds. If the prob is just access get a wobble 12 and 14mm and a mirror and flashlight. Ive got it down to 20 min now, its not bad after the first 2 times.
83 NA 280zx here are the readings
High speed
Standard Current Reading Result
HC (PPM) 152 123 Pass
Co(%) 0.97 1.47 Fail
co2(%) 13.8
NOx(ppm) 1082 597 Pass
dilution(%) >6 15.3
LOW Speed
HC (PPM) 157 163 Fail
Co(%) 0.88 1.19 Fail
co2(%) 13.8
NOx(ppm) 1084 814 Pass
dilution(%) >6 15.0
If anyone has any advise Please Help, I just changed the O2 sensor and there was no change. I have to get the car running for my wife because I just Totaled her 04 neon last Fri. suc
I have a turbo motor in a na car with the na ecu and dizzy set up. I could be wrong but I believe the oil pump is the same bolt up but the output is higher (to supply the extras). I had to change the shaft and dist. mounting spacer to make it work.
find some RC injectors they make any cc in a zx style injector. plus there balanced and blue printed so you dont run a chance of going lean in a cyl or two.look them up om the net http://www.rceng.com/
Is there a way to get this thing off easy? It seems the rubber has fallen apart on my 83 zx and the metal part of the trailing arm bushing has welded it self in. This is the big bushing that connects infront of the back wheel. Short of taking the whole assembley apart and a big press Im not sure of any other way to get it out. Any sug?
