Everything posted by Fuzzydicerule
Wiper Arm replacement
Fuzzydicerule replied to 9/73-E31-260z's topic in S30 Series - 240z, 260z, 280z
On the topic of miata parts, i stole a wiper motor off of an NA parts car i have, and the mounting flange looks nearly identical, im going to try to retrofit it on my car, good to know about the wiper arms too OP, Ecology usually has one or two whenever im down there... -
New- Please answer some of my questions
Fuzzydicerule replied to KaiEstrada's topic in S30 Series - 240z, 260z, 280z
Dailying these cars can be fun, and if you have a good, well running example on one, then it most likely will be, But if you have one like my first Z (bought that pile for 900 bucks) or SDgoods' first Z, That doesnt like to stay running reliably for more than a week, or likes to laugh at you while the electrical system shits its pants and drains the battery after 2 days of sitting, youre gonna have a bad time, and one of two things will happen, A; You will get frustrated, sell the car, and never want to see a Z again, or B: you will get frustrated, and out the car down into a long term project that it may never see the end of. Just some food for thought, we arent by any means trying to dissuade you, rather just letting you know what youre in for, especially if you pick a sub-par candidate for a car. A good prerequisite, invest in a GOOD set of tools, a jack and jack stands, if you dont already have some, you will more than likely use them in short order. -
Like the Good man (see what i did there daniel?) above me said, Dailying one of these cars is not for the faint hearted, but it is doable, but be ready to work on the damn thing... -
AS the title states. i have a Long Nose R200 with a viscous LSD unit (supposedly rare, 88 300zx SS only or something like that) laying around that i need to get rid of. only issue is i have no idea what this kind of diff is worth. anyone have any input on that?
Junkyard, ebay, and craigslist are your best options, ive never seen any new or NOS available, at least not for the motor and linkage... While your at it, upgrade the motor (honda motors are the most common) for faster, and more reliable wipers. AVOID the parts store crap wiper blade, they use a plastic adapter to the stock style mount and it is not strong by any stretch of the imagination. my buddy (PO of my current car) lost one in the middle of a storm, unfortunately the only other option i know of is a ~70 dollar per pair NOS. They sure do look pretty though -
Out with the old, and in with the new.
Fuzzydicerule replied to ColtGT4g63's topic in Other Projects
im not a terrible fan of the way the 818 looks otherwise it would be a contender, that and i have an LS1 that needs a home and a fox body for donor parts -
You planning on coming to the del mar/56 freeway area? If not I can swing by whenever you've got time, I would come by today but I am currently on the tail end of a drive from SLO and I don't think I'm gonna feel like going to el cajon when I get home, let alone much of anywhere. I'm off Tuesday and Wednesday if you're gonna be around either of those days as well As far as kits, I'd love a Type 65 But I have a suspicion ill end up with a roadster due to my size, but that's why I want to stare at your car again, I want to see if there's any room for frame/ aluminum mods to get my fat ass to fit any better, -
Nice work Dave, good to see how she's improved in a year, You going to be doing any Work on it in the near future? I'm looking into ffr kits and I kind of want to take a look at yours again to see what kind of modifications can be made for more Driver room -
Air Dam with Front License Plate
Fuzzydicerule replied to Atozone Tonine's topic in Body Kits & Paint
I can contend to te "don't worry about it" mindset, I'm in Cali, I've never had a front plate on any of my performance cars and only once have I ha it even mentioned by a cop That being said I have a friend whose only been pulled over twice and both were for no front plate -
Make sure the linkage nuts(on either end of the throttle blade rod) aren't too tight or it may cause an internal bond, and as said before, remove that middle support, it not needed and only creates problems
I don't believe much, if anything is the same, only drivetrain components
Firewall bracing to support clutch master cylinder
Fuzzydicerule replied to RebekahsZ's topic in Fabrication / Welding
Do you have a strut tower brace? it would be fairly easy (as far as my overstimulated, under rested, insomniac brain is concerned at 1:45 AM) to tie in a bar from the STB straight back to the clutch and brake MC mounts (ive watched how much the firewall flexes under brake pressure, it needs it too... -
car looks awesome, but one note you dont want the fuel cell supported the way you do, those tabs are not for mounting, they just make for a convenient place to bolt straps on straps, and help with mock up i suppose, you MUST have a set of straps supporting the cell, or a box of some sort, or those tabs will crack the welds (or the tank, or themselves) and your shiny fuel cell will be on the ground. Most cell companies stopped adding those tabs because they are too commonly used to mount the cells. I used 2" wide, 1/8" thick aluminum flat stock, heated with a propane torch and bent in a vice to make my straps, fairly easy to do and doesnt really detract from the look, and can be cleaned up and polished the same as the cell.
LS/T56/240z Project Mentor Wanted
Fuzzydicerule replied to RebekahsZ's topic in S30 Series - 240z, 260z, 280z
IM impressed that you were able to find a pair of stock brake switches, i had to find something else to work then the one died in my maroon car... Why did this get moved to the projects section btw? -
Technotoytuning coilovers
Fuzzydicerule replied to yessire's topic in Brakes, Wheels, Suspension and Chassis
As far as the original question. The TTT Complete Coilovers are indeed bolt in, but they are just sectioned struts with Ground control style sleeves and springs. The fronts are very easy to install, if youve ever done a wheel bearing R&R, its little more work than that. , the rears are not as straightforward.The biggest issue is that the rears do not come loaded (i.e Bearings, stub axles, seals, etc) so i recommend trying to source some new bearings, inner seals, and some 280z Stub axles while youre at it. you will need a press too. One of the harbor freight bottle jack operated presses did the trick when we did that setup on my friends car. -
Ol' Purp II, electric boogaloo
Fuzzydicerule replied to Fuzzydicerule's topic in S30 Series - 240z, 260z, 280z
The alternator swap has been done, and although i dont notice a huge difference, its definitely better now. I also lost brakes driving the other day, the wheel cylinder i -thought- i fixed ended up blowing out again, luckily, i got a box full of drum brake parts from a friend, so yesterday i was able to swap the shoes and wheel cylinders, and i installed new hardware and hoses, and the brakes FINALLY work properly, i may have a few small bubbles but they actually do something... Today, i replaced my wheel bearings because i noticed a scratching sound when i would drive next to things, so i did it preemptively. More importantly, i figured out why my car has been undriveable with these damn webers. after i did the distributor swap, (im sure it was an issue before that, i just didnt notice) i was having a HUGE rev hang issue. As in i would accelerate to 3k or so with as little gas as possible, and it would either hang at 3k for a few seconds, or rev as high as 5 k, and i would have to pull on the gas pedal with my foot to get it to come down. This made driving absolutely NO fun. after loostening and tightening all the linkages, adding ANOTHER return spring, i finally did what i should have done from the start, i took out the center support tower. I believe the difference in height was just large enough to cause a bind with the shaft, now that there is only two it is damn near impossible to have the same kind of bind in the system. my only concern doing so was that i may introduce play into the center carb, luckily however, the shaft appears to be plenty strong and has very little play, and the best thing is, NO MORE REV HANG!, i can finally drive my car and enjoy it... except my clutch is slipping immensely, ugh, its always something. new(ish) clutch is going in next week, and from then on i should be good to go.... Also, a few misconceptions id like to clear up I was informed (through the write up) that my stock 240z tach WOULD NOT work with the E12-80 ignition module. That was a lie, and it saved me from having to mangle my dash cover to get the tach out of there... It works great and is smooth as can be now. I was also told the ammeter wouldnt work with the 280zx alt, it appears to work (although doesnt fluctuate so it may just be broken), either way it looks like its working... -
The meet is called Tacos & Tuners, we meet near the Wahoos Tacos In Encinitas (target shopping center off Leucadia and El Camino Real[i5 north->Leucadia BLVD East-> Its on the right/south side of leucadia) Every Thursday at 7PM-Whenever Its not a Datsun meet, its all makes all models (albeit with a large bias towards Jap crap and Euro Trash, But when my Z's arent running i bring the Amerishit to the table) The main Goal is to have fun, but that means fun for everybody. Hooning about isnt welcome, as we have already had issues with the police for various reasons (stupid high school girls riding on the hoods of their cars, and a locked diff are the two major ones. Typical turnout is 30-60 cars, but there has been more and there has been less, depending on alot of variables. Here is a terrible paint map, its in the middle of a large parking lot, so it can be slightly difficult to find, just look for the Party city and the panda express
Yeah, up until that big group of S30's showed up there was only 3 or 4 that showed up, it was a nice change
Ive got an 03 cobra, not a perfect example, but not a terrible one either. Mine has basic mods, lowering springs, and CC plates, and subframe connectors (a MUST with any fox chassis) and handles pretty damn well. Granted, that is probably due to the IRS over the stick axle. AS far as the 4.6, My Supercharged DOHC 4.6 is a blast, but gets obnoxious in hot weather (heat soak makes the power go bye bye and taking off can be tedious) from what ive heard, and had limited experience with, the SOHC is a decent, albeit largely underpowered motor, but they respond well to mods. i would say a PI swap would be a wise investment. It might not be a bad idea to look into the 99-01 cobra Vert, for the sole purpose of having the DOHC and the IRS Suspension wise, at least stock, the front suspension is passable with lowering springs and CC plates, In the rear, you would want at the bare minimum a set of control arms, If you can afford it, a Torque Arm/Panhard bar setup (or some other 3 link/Panhard bar setup) or if youre crazy and want to spend lots o money, a Watts link. Or go pick up a cobra IRS for 7-900 bucks, and have a different set of problems. The IRS is poorly designed, and has a tendency to wheel hop, a delrin bushing kit is a must (i have yet to do the upgrade, although ive had the bushings in my garage for almost 2 years) It is also heavy, which isnt really a bad thing in these mustangs because they are nose heavy to begin with so it kind of helps with weight distribution. The brilliant thing about the IRS is its damn near bolt in to any fox chassis mustang that had a quad shock setup. The front mounts are the stock LCA mounts from the solid axle, and the rears are the quad shock mounts (i would reinforce both heavily if installing into a stick axle car) However, this is the main reason that the IRS is considered poor, it does not have alot of rigidity with the unibody, and can wiggle around a bit One other downside to the IRS is it tends to be a bit unpredictable in a slide. It has a tendency to tank slap quite easily and can be a bit of a handful. Alot of cobra owners do SRA swaps because of this. Benifits are: A Much better ride over stock, and a substantial increase in longitudinal and lateral grip For Example: I had a 1992 GT with a modded 5.0 before my cobra, and at the local track(1/8 mile) i spun first and second, and i had to let off in second to get anything done, ran a best of 9.4 (most of my runs were mid-low 10's), same track in the cobra i had a small amount of spin in first (not the tire rape i had with the fox) and no spin in second, and ran a best of 8.9(most runs were 9.4 and below), all with almost 150 extra HP and TQ (keep in mind i only took each car once, the fox was in december, and the cobra in July, however, being in San Diego, the temperature difference between nights was 10-15 degrees at most)s as far as driving, ive had much more seat time in the cobra, and compared to a Z with similar mods (SFC's, lowering springs, etc) it handles about 30 years better, and is honestly way more confidence inspiring in the corners, however, i have yet to go balls to the wall in either car. im sure in a well setup Z (Coilovers, sways, etc etc etc) it would be way more fun than in my stock ass suspension car with sticky tires and tokico springs... Sorry for the poorly edited novel, just trying to throw in my .o2 cents after a long day of work
Dont start your car in gear
Fuzzydicerule replied to SUNNY Z's topic in Gen III & IV Chevy V8Z Tech Board
Sunny, thats a given, why were you diving the car on a dead clutch anyway? I murdered the L series started in mine trying to get the L28ET running, another killer of starters, surprisingly, is starting too much -
Kris, saw your car there last week. It looks awesome man
Small update. I was able to get the wheel cylinder to stop leaking, the brakes still suck, but they work, so im okay with it I also got a box of rear drum components for free, so i can replace whatever i need to to get this **** working. Other update, is the car is registered.. Blue plate FTW I also took the stupid spacers off the seat bolts to get it lower so i can actually fit in the car (im 6'6", so that 1-1.5 inches was murder) Annoyingly, the car developed an incredibly strange, and hugely annoying misfire while getting it registered. It reminded me greatly of when my other car would run out of fuel while driving, and after a few quick seated incarnations, it settled as a HUGE miss under 2k rpm. Over 2k, it worked just fine, but as soon as i got under that, it would damn near stall, then rev up, stall rev up, etc etc etc. unfortunately it kept doing this in traffic. I assumed it had something to do with the HEI setup and the mag pickup dizzy. I replaced those with an E12-80 81Zx dizzy, as well as got replaced the alternator belt (was having belt slip issues, and i thought that may have been part of the issue. This all took place in the dark, and luckily, it seems to be running GREAT now. Not bad for under 150 bucks for the dizzy, Tomorrow im planning on doing a 280zx alternator conversion on my lunch break (i love working at an auto parts store) so that should about do it for any electrical issues ive had or will have -
The seats and the door panels I'm gonna replace. The rest of the plastics I'm gonna dye. Pm me of you're seriously interested
Glad someone does, I'm in process of dying it or replacing it. I think it hideous
