Everything posted by sweetride2go
first off, chek the fuse if u havnt already, then throw a test light on the switch, that would be the first places i would check... i once had a switch that went out of adjustment and would short circuit internally and blow the fuse every time the pedal came back up... cheers
wheel spacer question
sweetride2go replied to gretchen/jason's topic in Brakes, Wheels, Suspension and Chassis
heh, i had 295's on the rear of my z for a bit, but they rubbed every time i murdered bee on the windshield... so i bumped down to 265's, and my friends still make fun of me, cuz if i still hit a good bump i leave smokey contrails off of my rear fender flares... course im runnin 10" wheels, and they easily hav an inch from the edge of the tire to the stock spring perch... so w/ proper wheel spacing i suppose i wouldnt hav this problem... well, hopefuly w/ my strutspacers(http://forums.hybridz.org/showthread.php?t=127150) i wont... good luck =) cheers ryan~ -
srry, i move stuff around in the photobucket accnt. but i think its working again... =)
well, progress is slow, but plumbing the car is the latest... here is the pics of the 1/2" stainless hardline that runs from above the half shaft in the rear, along the "frame rail" and up the firewall to the regulator... the brake system is next, *grin*... cheers ryan~
LT1 and Subaru Rack
sweetride2go replied to 78zlt1's topic in Brakes, Wheels, Suspension, and Chassis
wheelman, i measured my rack as best as i could being the boots are on... these measurements are approximate being that i was trying to feel for items to measure from under the rack boots... rack housing width: 18" +/- inner rack width: 23.5" +/- they seem to match your measurements... also, mine has the coarse spline... ryan~ -
LT1 and Subaru Rack
hmm, interisting... when i initially researched going to powersteering, i found some threads in here, and they wer using the mid 90's suby racks, hence mine... however ive talked to a couple other and they are using late model forester racks... my 95(course i got it from a junkyard) looks identical to the one 78ZLT1 has pictured... now u hav me wondering if theres any discrepencies, ill run by the shop on the way home tnite and take some measurements on overall housing length and see if i can feel through the boots and get the rack length, and then overall length from end to end, wich will end up being similar to the datsun overall obviously since im rolling it around like this... NAPA PN 269-3389 is for the outer, i had to replace one, and it says this fits all impreza's 93-06, and some forresters and legaceys of different years inbetween... course the computers at parts stores hav never been known to be completly accurate, haha.. this pic prolly wont help much... -
ya, they came out better than i would hav hoped, to bad u cant see them after they hav been installed, lol... it was easier designing them than machining, luckly i hav a couple of friends in the buisness so i gave them my bluprints.. i was a lil concerned w/the OD of the spacer, but after trial fitting it, i had room to spare... the only catch to mabe others is that the minimum thickness would 3/4" due to the length of the isolator studs... of course, one could always shorten the isolator studs, but then there would be a marginal gain... these were done at 1", i figure i need at least that much to keep mytires from rubbing the flare... cheers
LT1 and Subaru Rack
meh, i dont think i could get a descent photo of the overall length since its all sealed up, and that new inner tierod boot was a PITA to get on.. but ill get a pic of the installed version, haha... i had no clue that it was for a toyota, but ya, it all threaded together quite nicely... the toyota inner(now that i know) threaded right into the suby rack, and didnt bottom out the threads, so all was good there... my suby outers look just like the one 78lt1z has pictured, its kinda a short, stubby tie rod end... i havnt thrown dial callipers on it to verify, but the taper seems the same, no slop, no noticable difference... the hardest part was changine the inner tierods, and getting a secure hold on the suby rack while trying to break loose the original suby inners... ryan~ -
LT1 and Subaru Rack
hey, another NW Z... Moog EV167 i got mine from napa, someone else aquired them from car quest... i actually got the part# from another Z guy here locally... ive changed them out, they fit great... only thing is they dont hav the slight bend to them like the stockers do, so there may be a possibility of bumpsteer, mabe *shrugs*?... but it is a "bolt in" installation in regards to the tie rod assembly... then thers the whole fabricating mounts for the rack and making lines and such, lol... u must mean the middle U-joint?... i didnt want to route it that way, but no matter how i ded it, it wasnt gona fit w/ the 1-3/4" block huggers... sooo, in goes the center joint, then the support, gah... its tight, but no binding... i still might modify it again (this would be the 3rd time)and try to get some of the angle out of it... i made a polyurethane rag joint for it, iits the white disc in the assembly near the firewall/collum... this might be easier using the JTR style engine mounts, but the shaft out of the suby rack wanted to go right through the datsun mount on the crossmember... nuthins been easy on this build, haha, guess thats the challange of fabrication... cheers =) -
LT1 and Subaru Rack
mine has the coarser spline as well, but its out of a 95 impreza... i just canabilized one of the factory suby ujoints for my new steering shaft, tig welded it together... the factory suby fittings i cut and welded -4AN fittings onto, then ran to the tubing place and had some SS braided lines made... and if u use the right inner tierod, u can use the stock suby outers in the z w/ zero modifications... cheers =) -
im pretty sure itook a pic, but i think its on my brothers camera, ill hav to get back to ya on that... its quite simple really though, its just shaped like a C with the back side flattened out kinda like [ but w/rounded corners... this im hoping will keep the fuel from runing away from the pickup in a low tank, in corners... but in hindsight, again, lol, i would hav cut a small section out of the bottom of the tank and installed a proper sump setup... cheers
Jon's 2 year roll cage saga...
sweetride2go replied to JMortensen's topic in Brakes, Wheels, Suspension and Chassis
we used laquer thinner, lots of laquer thinner, and lots of sanding... oh man, sanding tube chassis suks... heres a pic of the chassis, the mini diagonals are just above the seat on the left, we didnt use many of them actually, more or less just on the "main" cage, lol... just after paint to btw, and i must hav spent prolly 16 hours sanding onthat stinkn thing... cheers =) -
we did a chassis for a drag car, but we didnt use gussets, instead used mini diagonals at a lot of the critical right angle joints... of course, the gussets are quite functional, prolly a lil cleaner looking and a bit more compact... =) -
all righty, well here we go, first pic is of the new fuel pickup line, wich is 1/2" SS tube, tig welded to a -8AN steel bung, wich is later welded into the side of the tank... new pickup tube held into place, i later on built a baffle that mostly surrounds the pickup area on the bottom of the tank... here is where i added 5" to the tank, most of the way around... later on i found out how criticle ur welding is to a leak free enviroment... and here is the tank sealed off, new sending unit installed, and i got a lil carried away w/ the 2" sanding wheel, and played around w/ the top of the tank just for kicks, lol... lots of warping in some areas, big learning curve on welding on a tank, haha... cheers ryan~
Anyone use 1 3/4"header ?
sweetride2go replied to graham28's topic in Gen I & II Chevy V8 Tech Board
steering modification: 95 suby impreza rack, custom engine mounts, and 1-3/4 rewarder headers... -
finaly went and got a photobucket accnt. here is the finished strut spacers... i needed to counterbore the isolator holes a bit deeper, you'll notice that only about 2/3 of the isolator nuts are holding the isolator in... it was a bit of a hindsight deal, but at the shop im working at i needed it back onthe ground that day, so some locktite and thats the way they went in... least till i ever get bak to the rear suspension cheers ryan~
i also hav personal experience w/ world products heads and their crooked bolt holes/stud holes... yep...
chassis is yes, no problem, but i dont know about the stock steering as i hav retrofitted mine(i hav pics even, but dont know how to post them, bah)... it would be tight cause it was tight w/ the first engine i had in ther using the 'JTR style mounts' and usings hooker 1-5/8 blockhuggers, course i didnt hav the luxury of having the factory mounts still on the steering crossmember, so my engine may not hav been in the same place as most other 'JTR" setups... i looked at sanderson, but they seemed more expensive last i cheked.. -
oh, well i didnt know that, but i also have brand new isolators... that and i can design the spacer and get it made for nuttin but my time... i was just curious if there was much in the way of linial strains put on the isolator, and if i would creat an issue w/ the spacer... i dont know much in regards to suspension design...
eh, nice work jon!! just for kicks and the sake of curiosity, how many lenial feet of tubing do you have in there??? cheers ryan -
eh, Rewarder Headers makes a blockhugger in the 1-3/4 primary, but theres much discussion on how blockhuggers flow, and that they arnt much better than a iron manifold, but ya, dig around... i hav a set and they seem to be built well, thick flanges, ceramic coated, and not overly expensive... http://www.rewarderheaders.com/search_result.asp?CATEGORY=Block+Huggers&MANUFACTURER=ALL&DESCRIPTION=&PRODUCT_ID= cheers ryan -
so i need a lil more clearance between my tires and the fenders(early 74 260Z), and instead of installing a coilover setup(cause im cheap lol, and i need the money for the fuel system), i can make a spacer(1" aluminium) that will install above the rubber isolator that sits atop the strut (in the rear)... my question is does anyone forsee a problem w/ this regarding the suspension??? essentially im just pushing the whole strut assembly down an inch... thanks ryan~
Why does my LT1 run so rough?
sweetride2go replied to 80LS1T's topic in Gen I & II Chevy V8 Tech Board
this is a bit of a resurection, but heres my .02 for this peticular thread.... i had a similar problem on my 95 lt1, with a high ilde and low power... we chased it down to the 'idle air control valve'... after changing that and a broken spark plug(the doner car was wrecked) it ran like it was sapose to... for 6 months anyhow, haha, now i got a new problem... ryan~ -
LT1 runs rough in Closed Loop
sweetride2go replied to Bartman's topic in Gen I & II Chevy V8 Tech Board
i havnt checked fuel pressure in a while, but it was good last i checked... and sometimes it throws codes, but this last time i got a new one, an 'ignition grounding code' ? or therabouts... ill hav to go trough and check all my grounds... -
this is a carryover from another thread, but here is a quickchange in a IRS setup... i dont know how well it would work, but looks interisting enough, ha... http://www.cwiinc.com/quickchangeaxles.htm
