350 SBC build parts list for your approval
I'm going to do a V8 swap into my 240Z. As with just about everyone’s build the idea is to keep the cost down and get the best performance/dollar possible. The tranny is going to be a T5 from a V8 camaro going to a 4.11 R200 open diff. My Target power is approx 300hp/350tq at the wheels.
(1) Junkyard 350 short block with stock oil pan. I’ll be taking everything apart and reinstalling it after a good cleaning with new bearing. I would like to not get the block machined due to cost.
(2) Pro comp Aluminum Heads (210cc Intake Port, 64cc Chamber, 2.02/1.6 Stainless Valves, .550 Lift Springs, Straight Plug)
http://www.ebay.com/itm/SMALL-BLOCK-CHEVY-GM-SBC-350-ALUMINUM-CYLINDER-HEADS-210cc-w-550-Lift-Springs-/380371004731?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item588fe0ed3b
(3) COMP XTREME ENERGY CAM XR282HR
http://www.ebay.com/itm/COMP-SBC-SB-CHEVY-XTREME-ENERGY-282-ROLLER-CAMSHAFT-CAM-/140639769947?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item20bec8955b
(4) Comp Cams High Energy Hydraulic Lifter
http://www.ebay.com/itm/Comp-Cams-High-Energy-Hydraulic-Lifter-Chevy-6cyl-V6-V8-/330645710785?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4cfc0527c1
(5) 7.4-inch pushrods
(6) 1.6+ rocker rollers
Let me know what you think of the parts list and if I can do better for the money. I especially would like to try and save a lil money by getting a cheaper cam.
My car already has upgraded brakes, coilover suspension, thicker front and rear sway bars, strut bars, 275/4017 tires on the rear and 255/45/17 on the front.
Edited by logan1
Logan1:
If the target is 300/350tq, for a little more cost those number will be more easily achieved by stroking it to a 383 cu in engine. For $200.00 a cast stroker crank can be had. Either way you will likely have to buy new Pistons anyway. The machining and cylinder heads will make the real difference in how the engine will perform.
Logan1:
yes but to do a stroker i'll have to get the block machined to a .030 over bore which will probably cost between $500 to $800 in addition to the cost of the crank.
Unless i can do a 383 by simply clearancing the engine for 3.75 stroke using a carbide bit and a die grinder.
Edited by logan1
If your getting a junk yard 350, it likely will have to be bored .030 over. If the appropriate connecting rods are purchased there may be no need to clearance the pan rails or bottoms of the cylinders. If the 5.7" original rods are reused (not recommended) then clearancing must be done. To do things right, the block should be bored .030 over, decked and crank bores line honed. Then use Scat 6" rods, pistons and 3.75" stroke cast crank. Then you have a very good bottom end.
Some of the budget 3.75" cranks end up NOT being a deal. They can take heavy metal to balance. That will blow your budget. Also, they are not always the roundest, straightest cranks. Buyer be aware!
I like your cheap idea. Check with your local machine shops for deals. We always have blocks, intakes, heads, etc.. My 327 steel crank was free and so was the 350 steel crank and 4 bolt block.
Watch out for the pro-comp parts in the heads. They can be not so good. We've even had seats from them that needed replacing.
What parts do you have already?
210 cc heads are too big for a hyd cam motor and your target hp. It will be down on torque and you won't be able to turn it high enough to use the heads with 350 cid. Some bowl ported cleaned up stock heads will meet your goal and save money. I recently helped a fellow freshen a motor with procomps and the core shift was so bad the intake barely sealed. Save up for some better heads or use some stockers.
jt
off topic but your z looks nice... are those bamf flares or just regular flares? and what spoiler is that?
The flares are regular ZG's and te spoiler is a sparrow tail.
I have decided to just to a 350 build. I will not be doing the 383 after all. Also after reading a bunch of reviews on line i have decided to not use pro comp heads as then seem to be cheap for a reason.
jt
Do you think a set of vortec heads would get the job done? Also how much TQ would i lose by using 210cc heads; I ask because they are a set of brodix heads for sale locally with 210cc intake port, 67cc chamber volume, and the valve size intake is 2.080 and exhaust valves are 1.600. Professionally ported have a 1206 intake gasket on them and there ported more than the intake chambers on the gasket.
As i stated above i will not be using pro comp heads as they seem to be very low quality heads.
Edited by logan1
Good move on skipping the Procomps. They are a false economy.
If the 215 heads you're looking at are ported bigger than 1206's, they're a pretty serious race head, and it's going to take a pretty serious intake to work with them. Neither of these are going to work well with a low compression hyd cam stock shortblock, you will be disappointed. The big heads won't have enough velocity to make good torque at lower rpm, and the stock shortblock won't turn enough rpm to get the heads really working.
I think a set of vortecs would be excellent for your goals. You'll have to use centerbolt VC's and a vortec intake, but that's not a big deal.
Why don't you check out Ryan's stroker page? It's a compilation of builds with dyno results, and you can learn a lot there. You can meet your goals without blowing the budget, all it takes is some planning. There's over a hundred combos there.
http://ryanscarpage.50megs.com/combos1.html
jt
Those lifters are not for a roller cam.
I would buy a "complete" 350 vortec engine with a factory roller cam. Look for a 96 to 2000 350 vortec engine from a truck. these engines will make 300hp with just headers, intake and carb.
Can get a good used vortec engine for less than $800. modify the heads for more lift, swap the cam for a little more duration, add a rpm intake, holley 3310 750cfm, block huggers, and you can easily make 350 to 400hp (depending on cam). Should be able to do it all for under $2000.
Edited by Pyro
Pyro has the right idea. The used Vortec 350 engines from '96 to 2000 have fuel injection and are usually very clean and little wear because of it. The Vortec heads need to have the valve guides milled to a shorter length to allow more valve opening. A good valve job, good valve springs and good cleanup will make for a good set of heads. An aggressive solid roller lifter camshaft, solid roller lifters and 1.6 ratio rockers will yield HONEST good valve lift to take best advantage of the Vortec heads. Since the stock Vortec short block will likely have pistons .025" in the hole, use .015" head gaskets to get the best squish/quench.
1 bad thing about the vortec heads....they are prone to cracking. We had 6 heads in the shop only 1 was good.
I like them. They top aout at ~235cfm on the intake at around .500 lift. so you don't need a huge cam. We made ~370-377 hp (engine dyno) with a set, on a professional product low intake, 750dp and 1 5/8 longtubes. The other problem is the intake selection. I mean, they're out there but they only fit the vortec heads. So you're kinda stuck. But the vortec BOTTOM end is a great place to start.
There is a LOT of bad advice in this thread, and a little bit of decent advice. If you don't have a short block going with a complete Vortec engine is not a bad proosition, HOWEVER it is not likely that you can find a low miles complete running engine in good condition. SO you'll probably be looking for one with a spun bearing as it is fairly common.
Get a good vortec engine with a spun bearing and have the crank fixed and either have the rods resized or throw them away and get a good set of Scats. Get a set of cheap flat top pistons with the propoer compresion height (1.560-1.565") and a cheap rering kit. At this power level you don't need to worry about getting fancy on rings and bearings, Kind Bimetal bearings are fine and hastings, Perfect circle (mahle), or speed pro rings will be fine. Assuming your heads are not cracked have a good valve job done on them with a wide chamber cut and the throat opened to 89%. Assuming you want to reuse your HR valve train find a cam around with around 220º duration @.050", an RPM intake will work fine if you want to run a carb (I prefer EFI now). A good set of headers and a decent carb and you'll be around 425hp at the flywheel for a total around $2K.
DO NOT OVERCAM THESE HEADS. with nothing more than a good valve job they do not work well with more than 225º duration, your tq drops off fast and you don't pick up much hp.
Ok guys here is the play so far:
The motor will have a stock bottom end with all new bearings and flat top pistons. I will be using a set of vortec 350 heads. I would like a cam recommendation that will allow me to make between 300 and 325hp.
Edited by logan1
I am also going to run the vortec heads, I'm gonna make it a 383 though. I've heard the lt4 hot cam can be made to work. Beehive springs, special retainers and locks may be required though. I'm probably just going to have the heads machined though for a larger cam as I am shooting for over 400 horse
