Project RB-Z then VQ35
Which style arm rest is that too. I need to get one for mine.
Id be interested in a 240 console, maybe not the dash insert as i have a vintage air kit and a radio. but defiantly the lower console. As long as its reasonable..
Sorry for the delay as couldnt pass by that shop, they now told me center console they can not do it as they made changes in mine and wrapped it, but the instrument cluster can be done provided there are atleast 5 orders with different configurations etc...
I got an old armrest with the car just got it refinished in alcantara
As I said earlier when the shop was doing wiring i sent crank covers and intake manifold for polishing, so today everything came back and was installed along with coil pack and camgear covers in carbon fiber
Got this long time back today installed it
Compared to Chinese Nismo one
Replaced
Custom radiator cooling plate not liking it much but will fix it later maybe cut in half and some more bends, was done in aluminium then chrome plating.
Got aluminium covers for headers and turbo plate and removed the stock ones
Coolant overflow tank custom made according to the body curves in aluminium
Chrome cam covers with coil pack cover in carbon fiber
Cam gear cover changed to the carbon one, some changes were required as cover was for series 1 and Neo is slightly different.
Intake manifold installed
With fuel rail
Got the last set of missing parts some new emblems, strut covers, door handles and misc clips and stoppers
for Nadri had to buy both Momo and workbell adaptor still the horn button is loose any suggestions?
After the wiring got the car on dyno (AWD Mustang) but couldn't go above 230-240whp, coils start misfiring, but did the tune and car is running perfect now, pushing around 215-220whp on 5psi. Will change the stock coils, plugs and do a retune after a month or so.
Did a quick cleaning job, all left now is to check the brakes as pressure is very low even after 1 inch willwood brake master cylinder
Installed some generic pedals
Will install Nardi after all the mechanical work, interior is all set now
Edited by docaam
Below was not going in the above post
Installed the front Cusco strut bar cheery of the top for the bay :), loving the engine bay some cleaning of nuts bolts is there but thats more of an ongoing project
Installed spacers front and back fitment is superflush
Edited by docaam
I just ordered those same wheels in a different color and offset about a month ago. Now after seeing your car I'm wondering if I should have gone with a more aggressive size/offset. I went with 15x9 -28 front,15x10 -28 rear... Hope I don't need spacers to fill my flares. You did a great job on the car by the way!
Edited by Nelatl
You would be fine I guess, as per your offsets, mine are poking 10mm so you would be pretty flush
Installed the Nardi steering wheel to finish it off the interior some little things pending though
Some pictures i took, car was a bit dirty though.
After driving some issues are coming up, like
1. Brakes not taking enough pressure
2. Some heat coming from from the gearbox opening
3. Clutch pedal needs a bit of alignment
4. Exhaust is too low might need working on gearbox mounting and move the exhaust up
5. Steering rod had some problem during alignment time running -1.7 camber on one end and -1.1 on other will be fixed soon
Coils, some trunk emblem, speedo GPS module and fuel sender are on order will be replaced next week. Apart from this car drives very nice suspension if a bit stiff i guess will loosen up after some driving.
