Zero83 Posted February 24, 2012 Share Posted February 24, 2012 Okay i can't seam to find where i read about oil dilution. The datsun service manual states to check oil for fuel but it doesn't say what to do if fuel is present. I read somewhere that the s30's have an common issue which causes fuel to get into the oil but at that time i didnt have the problem so i payed no attn. Oops. Can any one help? The head is an e88 and the block is from a 280 and now my oil smells like gas bad. Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 24, 2012 Share Posted February 24, 2012 Gas comes through the carbs. The carb guys will probably want to know what carbs you're running on your 240Z. But that's where the source of your problem is. Quote Link to comment Share on other sites More sharing options...
Zero83 Posted February 24, 2012 Author Share Posted February 24, 2012 (edited) Dual webber su carb with cannons not sure of size. I ment to look them up just haven't yet. Edited February 24, 2012 by Zero83 Quote Link to comment Share on other sites More sharing options...
Canadianz Posted February 24, 2012 Share Posted February 24, 2012 If you have a mechanical fuel pump, its possible for the diaphragm to leak fuel into the block and still function. Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 24, 2012 Share Posted February 24, 2012 Damn, I knew my definitive statement would get punished. Another possibility, apparently. Quote Link to comment Share on other sites More sharing options...
rags Posted February 24, 2012 Share Posted February 24, 2012 +1 for the mechanical fuel pump Quote Link to comment Share on other sites More sharing options...
luseboy Posted February 24, 2012 Share Posted February 24, 2012 Ya I'm almost 90% sure that it's the fuel pump. Carbs can't really get fuel into your oil unless your head is cracked/has a hole in it, or perhaps if your valve seals are really bad, but you'd be burning a lot of oil then. I can't really think of another way you can get fuel in your oil unless you accidentally poured some in. Quote Link to comment Share on other sites More sharing options...
Leon Posted February 24, 2012 Share Posted February 24, 2012 (edited) Unvented blow-by gasses or raw gas washing out the oil on the cylinder walls can make your oil smell like fuel. Check/refresh your PCV system and change your oil. Perform a compression test as well. Edited February 24, 2012 by Leon Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted February 24, 2012 Share Posted February 24, 2012 Fuel pump sounds most likely to me too. But yeah, need to change your oil since the fuel will not do your rings/cylinder walls any good. Are your Carbs running really rich? Not sure if one was leaking if it could seep into the cylinder. If you were EFI, I'd say it was a leaking injector, but you're carb'd. Quote Link to comment Share on other sites More sharing options...
Zero83 Posted February 24, 2012 Author Share Posted February 24, 2012 Ok guys thanks im going to swap out for an electric Fuel pump and hope for the best. Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 25, 2012 Share Posted February 25, 2012 Why don't you take the mechanical one off and see if there's a hole in the diaphragm? No need to buy and hope... Quote Link to comment Share on other sites More sharing options...
theghosttanker Posted March 9, 2012 Share Posted March 9, 2012 Putting in an electric pump is dangerous unless properly done, and definitely NOT a simple fix for your problem. Take your mechanical pump off, take it apart, and check for a bad diaphragm.Replace if necessary.Do NOT simply install an electric pump that comes on with the key in the "on" position....this is a very dangerous fire hazard. Quote Link to comment Share on other sites More sharing options...
