My First Z Car - 260Z
Just bought my first Datsun and I'm really happy with it so thought I'd post some photos. I've still got loads to learn about these cars so I'm sure this forum will be a huge help.
1979 Datsun 260Z
Shes in great condition, only 28480 miles on her when I bought it although its not far of 29k now. She was built in 1978 but only first registered in 1979 and going by the chassis number she was one of the the last to be imported from Japan to the UK. Theres few photos with my Civic in them also, shes a 1991 Civic running a 243hp B20.
It drives beautifully, its had new bushes all round and with the low miles on the chassis it still feels really tight so its a joy to drive.
I have real big plans for her involving seam welding, cageing, hugely uprated suspension and brakes and an engine swap, I like the idea of a V10 because I love them but failing that I'd like an RB26DETT.
For now though the first mods will be:
Paint the brake calipers and drums
Polish up the lips on the wheels
Give the engine bay a good clean
Clean out the carbs
Do something with the rocker cover
Give her a full detail, I've already done the inside but the outside still needs done
After that lot I'll be fitting a bigger better airdam and a rear spoiler follwed by a good coilover setup with adjustable camber plates welded in as shes definitly too high at the moment. Then I'll have to fit the arch flares before I can fit my new wheels other wise they won't fit.
Photos
Sorry for the amount but I couldn't decide which to put up.
Beautiful car man. That is the same color as mine, and pretty soon I'm going to have those same wheels too!
Those pictures are making me want to take my car to a body shop and get it painted right now, because that car in that color is so beautiful when the paint is perfect. Mine is pretty rough.
You should have a fairly easy time getting it to run properly. Most of us start with a basket case. Your car just has a couple of minor flaw it sounds like.
Thanks for the nice comments guys, glad you like it.
Its in pretty good condition although there are a few issues I've found, the petrol tank had some rust so I stripped it back and repainted it today, I also found a small amount of rust (about a 1cm circle on the drivers door inner low down where the paint had somehow lifted a bit and allowed moisture in so I ground that back to bare metal and painted it. It doesn't look as good as it should, but its better than rust and I can make it look better some other time. I've also noticed than in some places underneath its just had underseal spayed onto bare metal which in my experience isn't good enouth, its a bit loose in some places so I'm going to chip it all off, primer it, paint it and then underseal it, the way it should have been done in the first place.
I spend most of the year working away from home so this is going to be a very slow project.
Ruesty Bomb - I think you mean RHD? The proper side to drive on, lol
wrcbonk - Good advice, I'm so happy with it as it is that I will be leaving it standard for a while as I;m enjoying it enouth as it is, if that changes than I'll start the more extreme mods. I rather like the L series so I'm thinking a better manifold and a triple carb setup might be good calls.
  • 3 weeks later...
After a proper search for rust I did manage to find some unfortunatly. I found rust on the fuel tank, one of the chassis legs in the engine bay, both rear wheel arches and a little near the radiator. I took them all back to clean metal so hopefully thats an end to it.
Fuel Tank, noticed a few tiny spots of rust, but after removing the paint from those areas I found there were rust spots all over it and ended up stripping the whole thing, I managed to wire brush them all back to cleanish metal, then treated it with Bilt Hamber Deox Gel which did a good job before snading, cleaning and priming it prior to painting. It will do for now but I'll get a new tank at some point.
After:
Bay, got rid of all the rust, one advantage of a black bay is that its easy to match, what I've done will do for now, I'll be getting a full bare metal respray in the bay in the near future.
After:
I also sanded and painted the brake booster, unfortunatly it got some rain drops on it before it had fully dried and it ruined the finish a bit, but again it will do for now, thats not rust behind it btw, just grease.
Polished up the lips on the wheels a bit:
Got to work on the rear wheel arches, any rust I found was ground back to clean metal, sanded, cleaned, primed, painted and then undersealed:
P-side before:
P- side after:
Drivers side before:
During:
After, I also painted the brake drums.
While I will definitly be changing my brake setup for something much better I thought I might aswell smarten up the stock calipers for now, brakes aren't the first thing on my list so the stock ones will be staying for a while yet.
Wire brushed and cleaned my caliprs and deck bells ready for painting.
Its pretty clean in the wheelarches and I didn't find any rust, however to make sure and also make the finish look a lot smarter I'll also strip it back to bare metal for a respray at the same time as I do the bay, I'll also be seam welding around that area anyway.
I polished and waxed the front end, I have since finished the car, but didn't get any chance to take photos.
I drove 1000 miles in just less than 3 weeks and loved every mile of it, unfortunatly the car is now tucked safely away in an Air chamber and I went back to work today. I'll look forward to getting her out next and getting on with some modification.
What a great find! Good for you. I see a few mods, but overall a very nice Z. Take your time and make good choices. We have some good choices and resources available to us. Paint looks really good so you're already thousands ahead of the game. Personally, I would put different wheels and tires on her. Perhaps Enkei's new Apache II 15x8's http://www.thezstore.com/page/TZS/PROD/LNP1/25-1198
Enjoy!!! Kevin
Now this is an amazing 260z; makes me want one... And nice civic, got any more pics of that to share?
Thanks, got loads of photos of the Civic, hers a few:
Custom 3" exhaust system
Engine bay currently looks like this, but its due a respray, custom intake piping and I'll be getting my new rocker cover airbrushed like the one I had the B16B.
Heres the current spec list:
Body and Misc
Resprayed Original Colour – Rio Red
Smoothed off Aerial
Smoothed off Rear Wiper
Smoothed off Rear Badge
Smoothed off Rear Fogs
Smoothed off Bootlock
Fully Undersealed
OEM Mudflaps
Honda Access Rain Visors
EK Throttle Cable
TenzoR short shift gearlever (Dual Bend)
ITR Gear Gaiter
Type R Key
Momo Boss
OMP Steering Wheel
Panasonic Head unit
Alpine Speakers
CG Lock
Custom Airbrushed Rocker cover
Jazz washer Jets
Bonnet lifters
PWJDM Bolts and washers
All other Bolts/washers changed to SS
Wire Tucked Engine Bay
EF9 Headlights (Lightweight Plastic)
Earls Fuel Fittings with Braided Hose and Inline Fuel Filter
Custom Reg Number
Performance
Quaife ATB LSD
Koyo Racing Radiator – Polished Aluminium
Slimline Fan
Odyssey PC680 Racing Battery
Customised PWJDM Holder
PW Magnetic Engine and gearbox oil Bolts
Honda MTF 94 (gearbox)
Silkolene 5W-40 (Engine)
Energy Shifter linkage Bushes
Competition Clutch – Stage 2 Carbon Kevlar clutch
Performance – Engine – B20 VTEC
B20 Block - Honed (0.5mm overbore)
Balanced B20 Crankshaft
Golden Eagle B20 Crank Girdle
RS Machine 84.5mm Pistons - 11.5:1
Blueprint H-Beam Rods
ACL Bearings
ARP Main Stud kit
ARP Head Studs
ARP 2000 Rod Bolts
Golden Eagle VTEC Conversion kit
OEM Headgasket (DNR modified)
OEM ITR Oil Pump
OEM ITR Water Pump
OEM ITR Timing Belt Kit
Competition Clutch Lightweight Flywheel
Baffled ITR Oil Sump
ITR Oil pickup and windage tray
JDM EK9 N1 Crank Pulley
B16B PR3-3 Head
OEM Honda Stem Seals
Crower Stage 3 cams
Crower Valve springs
Crower titanium retainers
Buddy Club Adjustable Cam gears
Hondata Insulating Intake Manifold Gasket
Edelbrock Victor X Inlet manifold ported to 70mm
OMNI Power 70mm Throttle body
Blox Max-flo 4-2-2-1 (Tri-Y) Header – Heatwrapped
Custom Prospeed 3" Manifold back Exhaust
AEM Hybrid Intake
BPI Velocity Stack & K&N Filter
345cc Injectors
AEM FPR
Rywire OBD0 - OBD1 Conversion Harness with lambda sensor extension
Rywire OBD0 - OBD2 Distributor convertor
OBD2 Dizzy
OBD1 ECU mapped with Neptune
Custom Crankcase breather setup
Precision Oil Catch tanks with breathers
NGK Platinum Plugs
Magnecor KV-85 ignition leads
Custom Earth leads
Handling
Meister R Coilovers
Tenzo R Front Upper strut brace
Cusco Front Under Brace
Tenzo R Rear upper strut brace
Beaks Rear Lower Tie Bar
Energy Anti-roll bar bushes
New OEM RTA bushes
Energy Poly Strut Rod bushes
Goodyear Eagle F1’s all round
Brakes
ITR Callipers and Carriers
ATR 1†Master cylinder and servo
Goodridge SS Brake Lines
Castrol DOT4. Fluid
EBC 282mm Discs
Hawk HP+ pads
EBC 242mm Discs (Rear)
Ferrodo Pads (Rear)
Edited by EF Ian
Enjoy!!! Kevin
Thanks. I will take my time with this one, want to get everything spot on, unfortunatly some things will have to come from America which will end up costing me loads in shipping and import tax.
I rather like the wheels, I reckon they will look even better when shes sitting a bit lower. I have thought about changing them but I think I'll just keep them for a while as the wheels I really want are RS-Watanabe R-Type but I'd need to fit arch flares first.
I've noticed that it doesn't have an electric fuel pump, I thought late 260Z's came with an electric fuel pump in addition to the mechanical one, is this correct?
If so, should I fit an electrical one aswell?
My fuel tank could od with being changed, so I was thinking of getting a custom one that I could use for the current setup but that I will also be able to use for the new motor, whether it will be a V10
My fuel tank could od with being changed, so I was thinking of getting a custom one that I could use for the current setup but that I will also be able to use for the new motor, whether it will be a V10 or an RB26DETT.
It would have to look as good as the stock tank, fill up from the stock location, hold at least as much fuel, have a decent baffle setup and be suitable for high flow fuel injection.
I was thinking of this design:
http://zclub.net/forum/attachments/s30-240z-260z-280z-tuning-upgrades/10310d1333833738-fuel-tank-options-tank1-jpg
http://zclub.net/forum/attachments/s30-240z-260z-280z-tuning-upgrades/10311d1333833738-fuel-tank-options-tank2-jpg
http://zclub.net/forum/attachments/s30-240z-260z-280z-tuning-upgrades/10312d1333833738-fuel-tank-options-tank3-jpg
I'm not sure whether to run that design which exactly replaces the stock tank, or to cut out the wheel well and move the bottom up (so you can't see it beneather the car from behing) and make it bigger.
I'm also not sure what pump setup to go for. I quite like the idea of an in tank pump setup as it saves mess outside the tank underneath the car and is probably a more simple setup but I could also go for an external pump setup which gives me the option of changing setups easily if I want/need to.
I don't want to run a fuel swirl pot idealy, but I'm not sure if thats possible, I assume a 400 - 500hp V10 or RB26 doesn't require the use of a swirl pot so long as the tank pickup is well baffled?
  • 8 months later...
I'm home for a week after finishing some more training so I got a chance to check out some of my new parts.
Airdam
Indicators for the Airdam
New PCV hose, bonnet adjusters and some new fittings for the inspection panels.
Carbon Fibre BRE style rear wing, very lightweight and rather nice looking:
Coilovers, should do a nice job, fully adjustable and the quality looks very good.
Cut off my stock shock and weld this part on
Camber plates to weld in, only fitting these to the front for now:
New fuel filter and thermostat, hood prop rod (will get this chromed) as mine is missing and second hand dome light as my switch is broken, will swap internals to my unit as its cleaner.
Relay to wire into headlights, should improve brightness and save my switch as at the moment power runs through the stalk switch to the headlights.
Red stiched gear gaiter, thought mine was a bit tatty:
Oil and Filter:
MM Billtet adaptors allow me to run a CV joint setup and get rid of the U-joints:
Z31T CV driveshafts
Billet alloy lock pulls:
Got more on the way although mostly now I just need parts for re doing the wiring, paints, ss bolts, etc. Looking to get a custom made alloy fuel tank as I haven't been able to find a decent decond hand tank, I'll get it built with a baffle setup and an in-tank Aeromotive 340lph pump.
