Ozzie831 Posted October 26, 2012 Share Posted October 26, 2012 So I posted this under the S30 section buuut I'm not sure if I posted in the wrong spot so I thought I'd try here. Hey hows it going? I have been gathering parts for a turbo build for my 77 280z. I am just wondering what I'm missing. My parts list so far: ARP head studs 240sx throttle body with TPS turbo exhaust manifold Intercooler and Piping downpipe BOV Fuel pressure regulator turbo oil pan oil lines MSD 6al and ss blaster aluminum radiator 599cc injectors Upgraded fuel pump I know I'm missing a few things such as a turbo, some electric fans, and a Megasquirt (not sure which one I need, so any help here would be really appreciated) but other then that I'm not sure on what else I need. Minds drawing a blank. Any help is appreciated Austin Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted October 26, 2012 Share Posted October 26, 2012 Don't forget. If you are converting your l28e to turbo you will need the rear sump oil pickup in order to bolt your turbo pan to the n/a block. Also don't forget about clutch upgrades, (240mm flywheel and clutch kits) Just take your time, and research EVERY aspect of the turbocharging process. I am undergoing the same project, converting my fresh n42/n42 combo. There are a lot of little things to consider. Also don't forget a nice wideband 02 sensor. Especially with your enormous injectors, tuning will be a problem without this. Quote Link to comment Share on other sites More sharing options...
redzedturbo Posted October 26, 2012 Share Posted October 26, 2012 sounds good man but like said above wide band is a must and my stock 280zxt clutch crapped out about 12 lbs so get a good one to start you should be fine. aslo why the huge injectors? i make over 300hp on 450cc dsm injectors at like 70% duty cycle. it will be hard to not run rich at idle with out crazy mods on those. good luck tho... Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 26, 2012 Share Posted October 26, 2012 http://forums.hybridz.org/index.php/topic/19918-the-ultimate-turbo-faqbeginners-guide/ Quote Link to comment Share on other sites More sharing options...
Ozzie831 Posted October 27, 2012 Author Share Posted October 27, 2012 haha thanks for the advice, I forgot about the wide band. I'm leaving the clutch for now cause it's not to bad and if stuff starts to break it's gonna be the clutch to go. yes my injectors are massive haha I got them from my buddy who put a turbo on his 633csi bmw haha but he no longer has the car so i just bought his cause they were cheap haha . I also need to know which megasquirt that i need because all the different versions and build your own are getting me all confused hahaha. Quote Link to comment Share on other sites More sharing options...
kaito Posted October 27, 2012 Share Posted October 27, 2012 I would like to chime in on this, First you WILL need a better clutch. I thought the same thing ( oh I dont need it.... its running stock boost) WRONG!!!! Started slipping about 2 weeks after the install going up a hiil. Just get a nissan hardbody d21 ka24e truck flywheel and clutch. Its under 200 for the whole kit and supports (supposedly) up to 400hp. Its definitely good to 300 though. As far as megasquirt, unless you want to spend buku money on an ms3 with expansion card and coilpacks and other crazy features just go for the ms2 v3.0 pcb. It will do everything you want it to. Quote Link to comment Share on other sites More sharing options...
rossman Posted October 27, 2012 Share Posted October 27, 2012 What are you doing for your wastegate? Quote Link to comment Share on other sites More sharing options...
Ozzie831 Posted October 27, 2012 Author Share Posted October 27, 2012 thanks for the info. my buddy suggested getting a non-wastegated turbo so i can just stick the wastegate wherever Quote Link to comment Share on other sites More sharing options...
rossman Posted October 27, 2012 Share Posted October 27, 2012 (edited) Wastegate locations are fairly limited if you're using the stock manifold. A lot of people, myself included, weld an elbow to the manifold just under the turbo flange. Take a look at post #23 from my build page. Edited October 27, 2012 by rossman Quote Link to comment Share on other sites More sharing options...
Ozzie831 Posted October 31, 2012 Author Share Posted October 31, 2012 Thanks for the link and all the info. Im probably just gonna run an internal wastegate for the time being. I'm now on the hunt for a turbo. My end game would hopefully be around the 350hp-400hp mark. if anyone could giving me some ideas for which turbo can accomplish that Id be very appreciative. No i don't expect to have 400 out the gate, I'm just looking to work my way there someday haha Quote Link to comment Share on other sites More sharing options...
Ozzie831 Posted November 3, 2012 Author Share Posted November 3, 2012 anyone have any ideas for which turbo can accomplish that, that's not ridiculously expensive? or that may be selling one that fits those standards? Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 4, 2012 Share Posted November 4, 2012 (edited) Reno, huh? Go drive around Carson City looking for a copper coloured 280ZXT with T-Tops and Convo Pros... He can tell you which one...with an internal waste gate as well! Edited November 4, 2012 by Tony D Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 4, 2012 Share Posted November 4, 2012 (edited) On 10/26/2012 at 9:53 PM, redzedturbo said: sounds good man but like said above wide band is a must and my stock 280zxt clutch crapped out about 12 lbs so get a good one to start you should be fine. aslo why the huge injectors? i make over 300hp on 450cc dsm injectors at like 70% duty cycle. it will be hard to not run rich at idle with out crazy mods on those. good luck tho... Shenanigans, My injectors flow 830cc/min, idle PW is a little low, but entirely manageable. Driving 2 hours on the highway to an autocross, had 2 drivers and let the car idle for the whole rungroup between runs, and driving 2 hours home resulted in ~24mpg. Edited November 4, 2012 by letitsnow Quote Link to comment Share on other sites More sharing options...
Ozzie831 Posted November 5, 2012 Author Share Posted November 5, 2012 haha its very far and few in between when I see another z around here. but there is a little club that we do have. I agree with the word shenanigans haha Quote Link to comment Share on other sites More sharing options...
s30red240z Posted November 5, 2012 Share Posted November 5, 2012 On 11/4/2012 at 2:04 PM, letitsnow said: Shenanigans, My injectors flow 830cc/min, idle PW is a little low, but entirely manageable. Driving 2 hours on the highway to an autocross, had 2 drivers and let the car idle for the whole rungroup between runs, and driving 2 hours home resulted in ~24mpg. How your PW idle is? 1, mine is 1.9 with 450cc DSM on L24ET Quote Link to comment Share on other sites More sharing options...
Ozzie831 Posted November 11, 2012 Author Share Posted November 11, 2012 (edited) hey has anyone heard anything about these? http://www.ebay.com/itm/T3-CAST-IRON-38MM-WASTEGATE-FLANGE-MANIFOLD-TURBO-CHARGER-TURBOCHARGER-ADAPTOR-/190753112022?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2c69c57fd6 I was just wondering if anyone has tried one or heard from someone about them. Edited November 11, 2012 by Ozzie831 Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 11, 2012 Share Posted November 11, 2012 On 11/5/2012 at 3:41 AM, s30red240z said: How your PW idle is? 1, mine is 1.9 with 450cc DSM on L24ET 1.8-1.9 hot 700rpm idle, AFR 13.0-13.5. Quote Link to comment Share on other sites More sharing options...
s30red240z Posted November 12, 2012 Share Posted November 12, 2012 On 11/11/2012 at 8:44 PM, letitsnow said: 1.8-1.9 hot 700rpm idle, AFR 13.0-13.5. Thanks! Quote Link to comment Share on other sites More sharing options...
