Domzs Posted November 1, 2012 Share Posted November 1, 2012 I'm thinking about getting new wheels for my 78 Z . Just wondered if anyone's running Rota RKR 17x8.5 +10 ( Ad on Ebay by Wheelbay ) . Do they require spacers ? If so , what size ? Pictures would be nice . Thanks . Quote Link to comment Share on other sites More sharing options...
Domzs Posted November 6, 2012 Author Share Posted November 6, 2012 Y'all telling me , there's no one out there running this setup ? Quote Link to comment Share on other sites More sharing options...
madkaw Posted November 6, 2012 Share Posted November 6, 2012 I'm running the same wheel size with +4 offset on a 240. You will have to have spacers up front - guessing 10mm You might just clear the rear - not sure if the 280 strut is different Quote Link to comment Share on other sites More sharing options...
Domzs Posted November 6, 2012 Author Share Posted November 6, 2012 On 11/6/2012 at 4:38 PM, madkaw said: I'm running the same wheel size with +4 offset on a 240. You will have to have spacers up front - guessing 10mm You might just clear the rear - not sure if the 280 strut is different Thanks for the input . Any photos ? Quote Link to comment Share on other sites More sharing options...
madkaw Posted November 6, 2012 Share Posted November 6, 2012 Search rota RBs 17x8.5 +4 and find my thread Pictures of what exactly Quote Link to comment Share on other sites More sharing options...
Domzs Posted November 6, 2012 Author Share Posted November 6, 2012 On 11/6/2012 at 6:43 PM, madkaw said: Search rota RBs 17x8.5 +4 and find my thread Pictures of what exactly I have Rota RB and RBR on my 83 . Tried RB 17x7.5 +4 on it . Seemed ok , just no sure about 17x8.5 +10 RKR . Thanks Quote Link to comment Share on other sites More sharing options...
brianZortiz Posted November 7, 2012 Share Posted November 7, 2012 http://www.thezstore.com/store/graphics/00000001/large501751.jpg there you go, those wheels are RKR. Quote Link to comment Share on other sites More sharing options...
Domzs Posted November 8, 2012 Author Share Posted November 8, 2012 On 11/7/2012 at 11:27 PM, brianZortiz said: http://www.thezstore...large501751.jpg there you go, those wheels are RKR. I've seen it before . Just not sure if they are RKR . Thanks . Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted November 8, 2012 Share Posted November 8, 2012 The silver Vildini shop car is sporting 16" Watanabe's. Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted November 8, 2012 Share Posted November 8, 2012 8.5" +10 will not fit a car with stock suspension, I highly doubt them to fit a car with 2.5" spring coil overs without spacers, but I could be wrong. I've got probably 1/4" - 1/2" clearance between the wheel and strut on factory 240z suspension with 8" wheel +0. 280z springs are larger if I am remembering correctly. Quote Link to comment Share on other sites More sharing options...
Domzs Posted November 8, 2012 Author Share Posted November 8, 2012 On 11/8/2012 at 4:51 AM, ModernS30 said: 8.5" +10 will not fit a car with stock suspension, I highly doubt them to fit a car with 2.5" spring coil overs without spacers, but I could be wrong. I've got probably 1/4" - 1/2" clearance between the wheel and strut on factory 240z suspension with 8" wheel +0. 280z springs are larger if I am remembering correctly. Thanks . Quote Link to comment Share on other sites More sharing options...
brianZortiz Posted November 8, 2012 Share Posted November 8, 2012 oh sorry, I thought that was RKR, but MSA 2012 there was a non running restored car running RKR. Quote Link to comment Share on other sites More sharing options...
CarJway Posted November 9, 2012 Share Posted November 9, 2012 I am currently running a 17x8.5 +20mm in the rear with a 2.5 inch spring and it clears. This is with no spacer; its a very close fit, but it does fit. I had to cut a section of the weld on ring to make this work, and clears fine with regular old lead weights too. Quote Link to comment Share on other sites More sharing options...
Domzs Posted November 9, 2012 Author Share Posted November 9, 2012 On 11/9/2012 at 3:28 AM, CarJway said: <br />I am currently running a 17x8.5 +20mm in the rear with a 2.5 inch spring and it clears. This is with no spacer; its a very close fit, but it does fit. I had to cut a section of the weld on ring to make this work, and clears fine with regular old lead weights too.<br /><br /><br /><br />Thanks . So , 17x8.5 +10 should fit ok . Quote Link to comment Share on other sites More sharing options...
CarJway Posted November 12, 2012 Share Posted November 12, 2012 Yes, if you're running coilovers... Quote Link to comment Share on other sites More sharing options...
mattausten23 Posted November 29, 2012 Share Posted November 29, 2012 Sorry to chime in, but I'm running coilovers. Would I be able to get away with a 16x8 +10 set up? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 29, 2012 Share Posted November 29, 2012 Yes, you will have 3/8" clearance to the coilover spring seat. The rear tires may scrape a little on the fender on full bump if your car is lowered. A little trimming of the fender flange may be needed, but not much. Quote Link to comment Share on other sites More sharing options...
mattausten23 Posted November 29, 2012 Share Posted November 29, 2012 On 11/29/2012 at 1:43 AM, RebekahsZ said: Yes, you will have 3/8" clearance to the coilover spring seat. The rear tires may scrape a little on the fender on full bump if your car is lowered. A little trimming of the fender flange may be needed, but not much. Cool thanks! Quote Link to comment Share on other sites More sharing options...
lorenzo Posted November 30, 2012 Share Posted November 30, 2012 (edited) I ran a 235/60/14 tire on a 14x7 positive 2 offset wheel for years on my 280z with stock suspension (front of car), car was lowered too. In comparison, a 17x8.5 positive offset wheel with a 225/45/17 tire is only 3mm closer to the suspension, so I am thinking that it may work On 11/8/2012 at 4:51 AM, ModernS30 said: 8.5" +10 will not fit a car with stock suspension, I highly doubt them to fit a car with 2.5" spring coil overs without spacers, but I could be wrong. I've got probably 1/4" - 1/2" clearance between the wheel and strut on factory 240z suspension with 8" wheel +0. 280z springs are larger if I am remembering correctly. Edited December 1, 2012 by lorenzo Quote Link to comment Share on other sites More sharing options...
